praegune kellaaeg 13.07.2026 09:36:53
warwas
09.03.2010 15:59:12
Postgre baasi reindex ei õnnestu (Table contains duplicated values). |
Tekkis probleem ühe postgre baasiga.
Üks X hetk sai avastatud, et baas on juba kole-kole suureks kasvanud. Ajasin siis kõigepealt full vacuum'iga üle ja seejärel lasin käima reindex'i. Vacuum õnnestus edukalt, reindex aga saab errori:
ERROR: could not create unique index
DETAIL: Table contains duplicated values. |
Kogu logi:
NOTICE: table "pg_class" was reindexed
NOTICE: table "sql_packages" was reindexed
NOTICE: table "sql_parts" was reindexed
NOTICE: table "sql_sizing" was reindexed
NOTICE: table "sql_sizing_profiles" was reindexed
NOTICE: table "receipts" was reindexed
NOTICE: table "sql_features" was reindexed
NOTICE: table "sql_implementation_info" was reindexed
NOTICE: table "sql_languages" was reindexed
NOTICE: table "pg_statistic" was reindexed
NOTICE: table "receipt_sales" was reindexed
NOTICE: table "pg_type" was reindexed
NOTICE: table "pg_attribute" was reindexed
NOTICE: table "pg_proc" was reindexed
NOTICE: table "pg_autovacuum" was reindexed
NOTICE: table "pg_attrdef" was reindexed
NOTICE: table "pg_constraint" was reindexed
NOTICE: table "pg_inherits" was reindexed
NOTICE: table "pg_index" was reindexed
NOTICE: table "pg_operator" was reindexed
NOTICE: table "pg_opclass" was reindexed
NOTICE: table "pg_am" was reindexed
NOTICE: table "pg_amop" was reindexed
NOTICE: table "pg_amproc" was reindexed
NOTICE: table "pg_language" was reindexed
NOTICE: table "pg_largeobject" was reindexed
NOTICE: table "pg_aggregate" was reindexed
NOTICE: table "pg_rewrite" was reindexed
NOTICE: table "pg_trigger" was reindexed
NOTICE: table "pg_description" was reindexed
NOTICE: table "pg_cast" was reindexed
NOTICE: table "pg_namespace" was reindexed
NOTICE: table "pg_conversion" was reindexed
NOTICE: table "pg_depend" was reindexed
Küsimus siis järgmine - kuidas ma selle vigase tabeli sealt üles leian? Logist on näha, et tabeleid indexeeritakse suht kaootlises järjekorras...
224 |
wk
09.03.2010 16:55:26
Eee, kas Sa tabeleid ükshaaval indekseerida ei saa?
_________________ Kõike hääd,
WK |
| Kommentaarid: 8 loe/lisa |
warwas
09.03.2010 17:03:10
| wk kirjutas: |
| Eee, kas Sa tabeleid ükshaaval indekseerida ei saa? |
hmm.. vaatasin praegu pgAdminni liideses ringi ja tunudb, et mingi selline võimalus on isegi olemas... kuigi see ei anna mulle eriti mingit tagasisidet.
Kuna neid tabeleid on ikka paras hunnik, siis peab vist mingi skripti ehitama, mis tabeleid järjekorras läbi käima hakkab ...
224 |
ref
| Kommentaarid: 17 loe/lisa |
15 |
incx
11.03.2010 01:49:28
| SELECT 'REINDEX TABLE ' || table_schema || '.' || table_name || ';' from information_schema.tables WHERE table_type='BASE TABLE' AND table_schema IN ('public', 'teisedvajalikudschemad'); |
Ja siis copypastedkäivitad tulemuse.
Samas, kui sul unique indexiga tabelis duplikaatkirjeid on, siis selle baasi sisu küll väga usaldada ei tasu. Masendavalt vana PG versiooniga tegu või riistvara keerab oma soovi järgi bitte paremale/pahemale?
_________________ I have never understood the female capacity to avoid a direct answer to any question.
-- Spock, "This Side of Paradise", stardate 3417.3 |
| Kommentaarid: 24 loe/lisa |
24 |
