sõnum  |
d_m
09.08.2012 12:34
Kas tõesti Desire S saab sellisel kujul uuenduse??? Sellisel juhul HTC seletus mitte uuendada HD-d tundub aina jaburam...
"On August 20 HTC will release an official update for developers which anyone can download from the HTC's dev site. The update containes final version of ICS 4.0.4 and Sense 3.6. No FOTA update is been released because the update requires repartitioning of the internal memory."
| Kommentaarid: 10 loe/lisa |
Lauri0112
12.08.2012 11:29
No on sead. Uut telefoni ikka ostma ei hakkaks, et ICS saada. Nii et lasku aga DHD-le see välja.
| Kommentaarid: 61 loe/lisa |
61 |
-RaiTz-
12.08.2012 18:48
| Lauri0112 kirjutas: |
No on sead. Uut telefoni ikka ostma ei hakkaks, et ICS saada. Nii et lasku aga DHD-le see välja.  |
For more background, due to how storage on the HTC Desire HD is partitioned – and the larger size of Android 4.0 – it would require re-partitioning device storage and overwriting user data in order to install this update. While technically advanced users might find this solution acceptable, the majority of customers would not. We also considered ways to reduce the overall size of the software package, but this would impact features and functionality that customers are currently using. Even after installing the update, there were other technical limitations which we felt negatively impacted the user experience.
Minu arust igati mõistlik põhjus.
| Kommentaarid: 31 loe/lisa |
25 |
d_m
13.08.2012 12:12
| Seletus on ju hea aga HTC käitumine nõme. Desire S-i samamoodi ei saa OTA upgrade-iga ICS peale, vaid RUU-ga tehakse wipeout olemasolevale customeri datale!
Olaf
13.08.2012 13:35
| d_m kirjutas: |
| Seletus on ju hea aga HTC käitumine nõme. Desire S-i samamoodi ei saa OTA upgrade-iga ICS peale, vaid RUU-ga tehakse wipeout olemasolevale customeri datale! |
Mina selles sada prossu kindel poleks.
Tundub, et see kõlakas läks lahti HTC rumalast suppordist, kes ajas Desire ja Desire S omavahel segi. Sest tol korral kui sellest räägiti, siis räägiti ka seda, et see uuendus on juba kodulehelt saadaval.
Samuti oleks see veider ka sel põhjusel, et hiinas lasti OTA välja ja probleeme polnud.
| Kommentaarid: 80 loe/lisa |
74 |
d_m
13.08.2012 15:37
| Sa pead silmas vana Desire Froyo -> GB uuendust ja seda tehti ka OTA-na?
erko
21.08.2012 11:36
| d_m kirjutas: |
"On August 20 HTC will release an official update for developers which anyone can download from the HTC's dev site. The update containes final version of ICS 4.0.4 and Sense 3.6. No FOTA update is been released because the update requires repartitioning of the internal memory." |
20. augustil pandi htcdev'i välja ainult CHS regiooni (mis iganes see ka pole) ICS 4.0 tar file. RUU'd ikka veel ei ole. This sucks
| Kommentaarid: 25 loe/lisa |
25 |
sasskinn12
21.08.2012 11:54
| erko kirjutas: |
| d_m kirjutas: |
20. augustil pandi htcdev'i välja ainult CHS regiooni (mis iganes see ka pole) ICS 4.0 tar file. RUU'd ikka veel ei ole. This sucks  |
ees ootustest...
| Kommentaarid: 30 loe/lisa |
26 |
Olaf
21.08.2012 12:54
Kergelt veider on see, et erinevate maade supportid ei tea ise ka asjast mitte midagi.
Ühe maa support ütleb, et tuleb raudselt OTA ja teise maa support ütleb, et tuleb RUU ja ainult "arendajatele".
Jätkuvalt loodan OTA peale, sest Inc S on ju sama rauaga, lihtsalt parema kaamera ja suurema ekraaniga .. Ja sellele tuli uuendus üle õhu.
74 |
striker13
21.08.2012 18:41
kas keegi oskab soovitada mõnda moodust, kuidas levi statsionaarsel desire-l parandada? kasutaks teda neti jaoks, aga natuke jääb puudu, et saada H kiirust. olen leidnud mingeid õpetusi, kuidas lihtsalt mingi lisaantenn teha, aga see eeldab antenni ühendamist mingisse välisesse antenni pessa, aga sellist asja leida ei suuda.
_________________ Sarcasm is just one of the many services I offer to people who ask stupid questions. |
| Kommentaarid: 94 loe/lisa |
89 |
mhei
Olaf
22.08.2012 15:01
Päris armas info, muidugi 100% uskuda ei saa.
By Team Club SFR-Android
The 22/08/2012 at 11: 03
@ Sned: we are in direct contact with the HTC teams we confirm that there will be no update to Android 4.0.3 (ICS) for Desire S and Desire HD. |
The 22/08/2012 at 10: 57
@ Sned: We have received confirmation as what the HTC Desire S's AJ was canceled in early August |
74 |
mhei
22.08.2012 16:59
kui mu telo oli enne flashimist rootidud, kas pean nüüd rootimiseks m2luka j2lle gold cardiks tegema? m2lukat muutnud ple ja ta oli flashimise ajal eemaldatud...
_________________ ツ |
MultiUser
22.08.2012 18:49
Kolmas link peaks olema see, mida ilmselt vajad.
Aga miks Froyo (Android 2.2)? Ehk tasuks vähemalt 2.3 peale lasta. Vaata siia
| mhei kirjutas: |
| kui mu telo oli enne flashimist rootidud, kas pean nüüd rootimiseks m2luka j2lle gold cardiks tegema? m2lukat muutnud ple ja ta oli flashimise ajal eemaldatud... |
Mis põhjusel seda goldcardi vaja peaks olema? Minuteada on seda vaja vaid SIM lukuga telefonide jaoks...
mhei
23.08.2012 08:39
Seda pare siis thx
d_m
23.08.2012 09:01
| Olaf kirjutas: |
ja siis on veel selline info:
Thank you for contacting HTC.
This is in continuation to our previous correspondence regarding HTC Desire HD device.
Please accept our sincere apologies for the less satisfactory service you have experienced with HTC. Be assured that we will put our best efforts in restoring your trust in HTC products and services.
In regards to your email, although ICS update is canceled for HTC Desire HD device, our technical team is still working on the possibility of releasing the upgrade for the device.
We appreciate you for giving us your valuable time and patience.
If you have any further questions or comments, please feel free to email us or call us at our contact center 1800-266-3566, Monday to Sunday – 9:00 am to 8:00 pm.
Thank you for your continued patronage.
ja tahaks official statementi nüüd HTC poolt Desire S kohta IRW IRW
Draqula
27.08.2012 08:12
| d_m kirjutas: |
| Sa pead silmas vana Desire Froyo -> GB uuendust ja seda tehti ka OTA-na? |
Vana Desire 2.2 > 2.3 kindlasti ei tehtud OTA.
Fail pandi üles HTC lehele, koos hirmujuttudega, et ainult advanced tegelased saavad sellega hakkama ning mis kõik võib katki minna.
Endal see 2.3 kasutusel vana Desire peal ning täitsa kenasti töötab.
_________________ Kõik ülalpool öeldu on minu isiklik arvamus, ei vastuta kõikide faktide korrektsuse eest. |
| Kommentaarid: 34 loe/lisa |
d_m
27.08.2012 16:38
| nu vot, miks siis HTC ei suuda teha seda HD-le ja arvatavasti tabab sama saatus ka nüüd S-i omanikke. uskumatult kahepalgeline on see HTC...
-RaiTz-
27.08.2012 20:00
| d_m kirjutas: |
| nu vot, miks siis HTC ei suuda teha seda HD-le ja arvatavasti tabab sama saatus ka nüüd S-i omanikke. uskumatult kahepalgeline on see HTC... |
Kui üteldi, et HD-l on partitsioonid halva suurusega ja uuenduse käigus võib palju kasutaja asju kaduma minna. Kui Desire S-il oleks
partitsioonid sama suurusega oleks sellest ammu juba räägitud. Mis kuradi kahepalgelisus?! Sa ole õnnelik, et üldse üritavad vanale rauale seda arendada. Vabalt võiksid minna seda teed, et vana rauda ei uuenda ja
kõik. Kui nad ei taha uuendada oma vana rauda põhjusel "KASUTAJA ASJAD LÄHEVAD KADUMA" ja telefoni kasutamine ei ole enam mugav/sujuv, siis ei olegi midagi rohkem küsidagi.
Usu või mitte, aga kui nad vana rauda ei uuendaks ja miks peaksidki, siis ei jää nende uued mudelid müümata sinusuguste pärast. S*ta maitse on suus juba sellest kuradi vingumisest.
See jutt ei käinud ainult sinule vaid üldiselt vingujatele.
25 |
namstoop
27.08.2012 20:37
| -RaiTz- kirjutas: |
| d_m kirjutas: |
See jutt ei käinud ainult sinule vaid üldiselt vingujatele. |
pahad päevad või lihtsalt liiga palju s*ta söönud, et paha maitse suus? Ega jah ei olegi tootja huvides, et keegi rohkem kui aasta vanat mudelit ei kasutaks vaid uue ostaks. Kõik puhtalt kliendi huvides
| Kommentaarid: 72 loe/lisa |
63 |
-RaiTz-
27.08.2012 23:12
| namstoop kirjutas: |
| -RaiTz- kirjutas: |
| d_m kirjutas: |
pahad päevad või lihtsalt liiga palju s*ta söönud, et paha maitse suus? Ega jah ei olegi tootja huvides, et keegi rohkem kui aasta vanat mudelit ei kasutaks vaid uue ostaks. Kõik puhtalt kliendi huvides  |
Mis paha päev? Pigem pahad kuud, kui seda jama igalt poolt peale peksab Mitte ei tuleks küsida "Miks ei uuenda" vaid "Miks peaks uuendama".
Kliendi huvides on pakkuda parimat kasutus mugavust ja elamust mitte vana raua peal jooksutada uuta tarkvara mis kogu ürituse ära rikub.
Te ei jõuaks ise ka seda p*ska ära lugeda, kui pooltel vendadel ei jookse uus tarkvara ALLES KAKS AASTAT TAGASI ostetud telefoni peal sujuvalt ja kõiges on süüdi HTC, ning "CyaGAY Mod" on ikkagi üle pragi
25 |
kriist
27.08.2012 23:24
Oot, aga kuidas Desire C ikkagi ICS´i ja Sense 4 välja veab? Hullem vana raud ju kui DS
| Kommentaarid: 96 loe/lisa |
87 |
-RaiTz-
27.08.2012 23:44
| kriist kirjutas: |
Oot, aga kuidas Desire C ikkagi ICS´i ja Sense 4 välja veab? Hullem vana raud ju kui DS  |
Millest sa sa kulla inimene järeldad, et DS ei saa ICSi? Sa ise ka usud seda jama mis netis liikvel on? Ei ole ühtegi ametliku väidet, et seda ei tule.
Seda enam, et Desire C suudab seda välja vedada, mis paneb sind kahtlema, et Desire S seda ei suuda? On juba ammu öeldud miks HD on ainuke mis seda hetke seisuga ei saa.
Mis sulle arusaamatuks hetkel jääb?
25 |
kriist
28.08.2012 06:07
| -RaiTz-, ma pole seda kordagi järeldanud. Mainisin DC rauda kuna sa korduvalt nimetasid DHd ja DSi vanarauaks.
87 |
namstoop
28.08.2012 07:51
| -RaiTz- kirjutas: |
| -RaiTz- kirjutas: |
| d_m kirjutas: |
Te ei jõuaks ise ka seda p*ska ära lugeda, kui pooltel vendadel ei jookse uus tarkvara ALLES KAKS AASTAT TAGASI ostetud telefoni peal sujuvalt ja kõiges on süüdi HTC, ning "CyaGAY Mod" on ikkagi üle pragi  |
tss nüüd, prohvet on rääkinud. Rohkem ei tohi keegi nurised, sest tootjal on alati õigus ja mingid kaks aastat vanade rontidega vennad võiks ennast ju üldse põlema panna, krdi vanarauafriigid.
Mis sa tõemeeli usud, et tootja tõesti ikka ja ainult kasutaja heaolu ja mugavuse peale mõeldes uuendamise ära lõpetab või
63 |
