aal
30.05.2003 16:08:28
backdoor.antilam |
| Mure! Mul AVG viirusetõrje peal ja uuendab ka ennast ikka ülepäeva aga backdoor.antilam sai ikka sisse. AVG leiab ta ikka üles aga startides on ta ikka olemas. Kuidas seda käsitsi lõplikult eemaldada?
| Kommentaarid: 9 loe/lisa |
9 |
Vidget
128 |
aal
06.06.2003 00:00:30
Seele lehe leidsin ma isegi ülesse aga mure selles et see ei aita. Registrist ei leidnud ka sellist asja nagu scandisk.exe.
_________________ Minu arvamus kui vale arvamus ... ma arvan!
TEL: 5662 7695 |
9 |
Celeron
07.06.2003 07:22:36
| Tee siis Format C: , kui muu ei aita...
| Kommentaarid: 41 loe/lisa |
33 |
naaskel
jooda
07.06.2003 08:31:32
Mu meelest üsna täpne õpetus, kuidas asjast lahti saada. Kui sul miskit puudu, tee niipalju kui võimalik. Ja siis vaata, kas AVG veel karjub.
To remove this Trojan:
1. Update the virus definitions, run a full system scan, and delete all files that are detected as Backdoor.AntiLam.
2. Delete the value
MS Scandisk <dropped file such as Scandisk.exe>
from to the registry key
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
and the value
Start ok
from the registry key
HKEY_LOCAL_MACHINE\Software\Microsoft\DirectX
To remove the values from the registry:
CAUTION: Symantec strongly recommends that you back up the registry before you make any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the keys that are specified. Read the document How to make a backup of the Windows registry for instructions.
1. Click Start, and click Run. The Run dialog box appears.
2. Type regedit and then click OK. The Registry Editor opens.
3. Navigate to the following key:
4. In the right pane, delete the following value:
5. Navigate to the following key:
6. In the right pane, delete the following value:
Start ok
7. Click Registry, and click Exit.
103 |
