praegune kellaaeg 24.10.2026 09:19:42
ufo56
22.01.2010 17:55:23
Windows 2008 64bit Ioncube |
Tervist
Oleks vaja saada windows 2008 64bit serverile peale ioncube. Aga kahjuks kõike mis proovinud olen ei aita. Äkki kellelgi on idee mismoodi saada tööle 64bit windowsi peal ioncube. Olen googeldanud ja igast nippe proovinud aga tööle ei saa. Apachet ei ole proovinud , hetkel IIS7
EDIT: keegi oskaks aidata ?
PHPinfo
PHP Version 5.2.11
System Windows NT WIN-OHMJC9BTJ6Q 6.1 build 7600
Build Date Sep 16 2009 19:31:25
Configure Command cscript /nologo configure.js "--enable-snapshot-build" "--enable-debug-pack" "--with-snapshot-template=d:\php-sdk\snap_5_2\vc6\x86\template" "--with-php-build=d:\php-sdk\snap_5_2\vc6\x86\php_build" "--disable-zts" "--disable-isapi" "--disable-nsapi" "--with-pdo-oci=D:\php-sdk\oracle\instantclient10\sdk,shared" "--with-oci8=D:\php-sdk\oracle\instantclient10\sdk,shared"
Server API CGI/FastCGI
Virtual Directory Support disabled
Configuration File (php.ini) Path C:\Windows
Loaded Configuration File C:\Program Files (x86)\PHP\php.ini
Scan this dir for additional .ini files (none)
additional .ini files parsed (none)
PHP API 20041225
PHP Extension 20060613
Zend Extension 220060519
Debug Build no
Thread Safety disabled
Zend Memory Manager enabled
IPv6 Support enabled
Registered PHP Streams php, file, data, http, ftp, compress.zlib, https, ftps, zip
Registered Stream Socket Transports tcp, udp, ssl, sslv3, sslv2, tls
Registered Stream Filters convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies |
Lae pildid -> pilt.io |
