praegune kellaaeg 18.11.2026 02:12:51
telestar
23.12.2009 23:15:29
exe fail jääb tõmmates BC! failina |
Kõik exe failid mida tirin torrentitest jäävad BC! failina.
Miks need nii jäävad ja kuidas saaks teha seda tavaliseks exe-ks?
andrusny
23.12.2009 23:24:14
Cannot access BC! files on windows?
When windows gives you an error message saying that it
"Cannot open BC! files", this means either:
A. You need to identify a program that can open the file
B. Or your registry may be damaged
RECOMMENDED:
In both cases it is strongly recommended that you
run a free scan for registry errors. |
| Kommentaarid: 7 loe/lisa |
NATAS999
23.12.2009 23:24:42
faili nimi ise on exe?
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
| Kommentaarid: 41 loe/lisa |
39 |
Max Powers
23.12.2009 23:28:29
See on poolik file.
BC - bitcomet.
182 |
telestar
23.12.2009 23:53:54
| aga miks aint siis exe failid poolikusks jäävad ?
Pätu
24.12.2009 00:00:47
| telestar, kui muudad faili laiendi ära .exe ümber ?
89 |
telestar
24.12.2009 00:12:55
| mul on ju see lõpp .exe ?
