Dude .
13.12.2009 15:38:26
[X360] Fable III |
Fable III
The fables of Fable continue to be told with this third series entry -- a revolution for the series that gives you power over your character and environment like never before. In this new adventure, players will witness tyranny, poverty and injustice plague their land. They will see a people divided, and they will be compelled to stand up for change. They will also be forced to answer a question: What would you sacrifice to secure the crown of Albion? Will you uphold the values and principles that led to your ascension, or will you be corrupted by the station you’ve strived to acquire? Will you be a monarch of the people, or bring the entirety of Albion to the brink of collapse?
The journey to rule the throne of Albion begins five decades after the events of the last chapter, and you play as the child of your hero from Fable II. As you rule your kingdom as king or queen, you will be called upon to make choices and sacrifices that will test your morality and can affect your entire kingdom. Themes of heroism, leadership and consequence are taken to a grand scale as you fight to unite a divided people. |
Multiplayer: Jah
Uudised ja eelvaade: IGN
Ülevaade: [url=Siia sisesta mängu ülevaate aadress]IGN[/url]
Screenshotid: IGN
Videod: Gametrailers
| Kommentaarid: 15 loe/lisa |
15 |
estplayer
13.12.2009 22:38:53
| Loodetavasti kolmas osa tuleb sama hea kui teine, väga loodan sellelt mängult parimat, kuna teist osa sai ikka tervelt 6 kuud järjest mängitud, kuni vähehaaval ära tüdinesin.
| Kommentaarid: 30 loe/lisa |
26 |
313 |
estplayer
26 |
313 |
estplayer
26 |
Dude .
15 |
Tical
| Kommentaarid: 4 loe/lisa |
Dude .
15 |
estplayer
28.11.2010 01:40:21
| Keegi on seda mänginud ka üldse? Ise plaanin lähiajal osta.
26 |
firemark
24.06.2011 13:26:45
| Keegi pole veel küsinud, kuid rääkige oma muljeid sellest mängust?
92 |
angel
25.06.2011 15:31:48
mängu map ja maailm on üli kena ja hästi tehtud. mõnus keskkond jne.
rohkem midagi head selle mängu kohta pole öelda.
gameplay on derpidi derpidi derpidi derp ehk siis idootne. võitlus on -> kasuta ainult relva, teised mõttetud. Mapi mängus ei ole pead kogu aeg seda debiilset "varjupaika" vms kasutama, mäng hoiab sul pidevalt käest kinni iga samm. Kogu võlu ja headus mis Fable 1 oli on pms kadunud gameplay osas. Fable 1 oli imo isegi päris hea mäng... see aga on mingi ülim allakäik ühe firma poolt kes kunagi paremat kraami tegi.
http://www.youtube.com/watch?v=oSaw85bliyQ --> pms selline ta ongi
157 |
Alvaaro
25.06.2011 23:27:20
| Minu arvates on täitsa hea mäng.
| Kommentaarid: 217 loe/lisa |
182 |
angel
26.06.2011 00:17:36
tore, aga see mapi puudumine, iga asi 10x seal "varjupaigas" tegemine jms on imo on vist tehtud kellegi poolt kes üldse ei mängi või üritas mingit uut teha ehk siis keeras kõik peeti. 1 osas ikka oli kaaslane häppy et andsid mingit nänni (andsid, mitte nagu selles juras), vaatasid mapi (siin peab leiva puru maha panema muidu ei leia muhvigi ülesse kuna mapi ei ole), võitlesid kuidas tahtsid (ainuke mõttekas relv on püss või maagia), hoidsid mitut spelli korraga jne jne jne.
aga jah... visuaalselt on asi tõesti meeldiv nagu 1 osagi.
raha teenimine on kah 3 osas ÜLI kerge... mingi täristad pilli visuaalselt ja toksid klahve ja juba esimese hetkega oli mul raha nii palju et ei olnud taga midagi teha... tea kas tüübid seda mängu üldse testisid kah või lihtsalt viskasid valmis.
157 |
firemark
26.06.2011 12:01:52
| Praegu mängin Fable2 ning see väga meeldib, loodetavasti fable3 samuti
92 |
Ravenclaw
27.06.2011 13:37:37
Fabel 2 on kordades parem kui Fable 3, mul jäi Fable 3 mängides selline mulje et mängu hakati tegema ja siis kui oli mingi näiteks aastake tehtud öeldi mängu tegijatele et nii, nüüd on 3 kuud aega siis peab mäng väljas olema. Mängu lõpp on täpselt selline hirmus rush.
Relvadest kasutasin ainult maagiat, aoe spellid on nii owerpower et kui olid ennast teise lvl peale upgradenud siis muutus combat nii igavaks et hirmus lausa.
Mina igastahes väga pettusin selles mängus
29 |
firemark
27.06.2011 14:21:39
| Kui keegi tahab müüa oma fable 3 ära, siis oleksin nõus ostma
92 |
sten260
27.06.2011 17:44:18
See pole veel kõige hullem ,Fable 4 tuleb tõsine crap kinecti mäng
firemark
27.06.2011 19:39:30
| Fable Journeys for kinect ei pidanud olema Fable 4
92 |
Ravenclaw
28.06.2011 00:04:59
| Kui oma konsooli korda ei saa siis on mul üks Fable 3 pakkuda, suhtleme PS teel edasi mingi aja pärast.
29 |
Shade
28.06.2011 09:31:12
| sten260 kirjutas: |
See pole veel kõige hullem ,Fable 4 tuleb tõsine crap kinecti mäng |
paari video põhjal koheselt paika panna, et tuleb saast mäng on tõsine oskus ikka.
Tulles Fable 3 juurde - endal siis läbi uhatud, koos DLC-ga. Hea mäng. Teine oli natukene parem, kuid 3 on ka hea. Combat on igavam kui teises osas.
_________________ GT: janrist
PSN: janrist
Just for fun: Mängupunker |
| Kommentaarid: 23 loe/lisa |
21 |
sten260
28.06.2011 15:08:27
| Shade kirjutas: |
| sten260 kirjutas: |
ei pea just eriline geenius olema ise ikka vaatasid E3 videot? Isegi see tüüp kes mängis seda ,oli sellise näoga
Shade
28.06.2011 16:02:10
| sten260 kirjutas: |
| Shade kirjutas: |
| sten260 kirjutas: |
ei pea just eriline geenius olema ise ikka vaatasid E3 videot? Isegi see tüüp kes mängis seda ,oli sellise näoga  |
Videosid vaatasin küll tagantjärgi ja viibisin kohapeal. Kuid esimeste impressionite põhjal kohe paika panna et tuleb kõnts on ka naljakas. Samasugune lähenemine nagu väikesed lapsed jooksevad mängu leti juurde, rabavad jumala suvalise mängu näpu vahele ja siis targutavad - vaata kui ilusad pildid see on kindlasti väga hea mäng.
PSN: janrist
21 |
Ravenclaw
28.06.2011 16:19:51
| ot: |
| Shade kirjutas: |
| sten260 kirjutas: |
| Shade kirjutas: |
| sten260 kirjutas: |
Videosid vaatasin küll tagantjärgi ja viibisin kohapeal. Kuid esimeste impressionite põhjal kohe paika panna et tuleb kõnts on ka naljakas. Samasugune lähenemine nagu väikesed lapsed jooksevad mängu leti juurde, rabavad jumala suvalise mängu näpu vahele ja siis targutavad - vaata kui ilusad pildid see on kindlasti väga hea mäng. |
aga kuidas siis veel mänge valida?  |
29 |
sten260
28.06.2011 16:36:28
| Shade kirjutas: |
| sten260 kirjutas: |
| Shade kirjutas: |
| sten260 kirjutas: |
eks me näeme, kui aeg käes
/end of OT
