praegune kellaaeg 06.11.2026 01:52:34
danny
10.12.2009 15:08:31
Palun abi prestashopi mooduli koodi muutmisel. |
Nii, oleks vaja veidi abi ühe mooduli koodis, ehk siis reklaami moodul mis lisab prestashopile reklaami.
Allpool toodud kood lisab reklaami vasakule ja paremale, aga sama reklaami, peale pikka pusimist ei saanud ma eraldada seda rightcolumn ja leftcolumni.
Oleks siis vaja nii, et antud koodiga saaks lisada kahte erinevat bannerit.
<?php
class BlockAdvertising extends Module
function __construct()
$this->name = 'blockadvertising';
$this->tab = 'Blocks';
$this->version = 0.1;
parent::__construct();
$this->displayName = $this->l('Block advertising');
$this->description = $this->l('Adds a block to display an advertising');
function install()
if (!parent::install())
return false;
if (!$this->registerHook('rightColumn') OR !$this->registerHook('leftColumn'))
return false;
return true;
* Returns module content
* @param array $params Parameters
* @return string Content
function hookRightColumn($params)
global $smarty, $protocol_content, $server_host;
$smarty->assign('image', $protocol_content.$server_host.__PS_BASE_URI__.'/modules/'.$this->name.'/advertising.jpg');
return $this->display(__FILE__, 'blockadvertising.tpl');
function hookLeftColumn($params)
return $this->hookRightColumn($params);
Näide praegusel kujul asub siin: http://www.ricky.pri.ee/prestashop/
Tänan abi eest.
| Kommentaarid: 49 loe/lisa |
42 |
Renka
10.12.2009 16:37:50
Re: Palun abi prestashopi mooduli koodi muutmisel. |
| php:
<?php class BlockAdvertising extends Module { function __construct() { $this->name = 'blockadvertising'; $this->tab = 'Blocks'; $this->version = 0.1; parent::__construct(); $this->displayName = $this->l('Block advertising'); $this->description = $this->l('Adds a block to display an advertising'); } function install() { if (!parent::install()) return false; if (!$this->registerHook('rightColumn') OR !$this->registerHook('leftColumn')) return false; return true; } /** * Returns module content * * @param array $params Parameters * @return string Content */ function hookRightColumn($params) { global $smarty, $protocol_content, $server_host; $smarty->assign('image', $protocol_content.$server_host.__PS_BASE_URI__.'/modules/'.$this->name.'/advertising.jpg'); return $this->display(__FILE__, 'blockadvertising.tpl'); } function hookLeftColumn($params) { global $smarty, $protocol_content, $server_host; $smarty->assign('image', $protocol_content.$server_host.__PS_BASE_URI__.'/modules/'.$this->name.'/advertising_left.jpg'); return $this->display(__FILE__, 'blockadvertising.tpl'); } } ?>
61 |
danny
10.12.2009 17:08:10
| Tänud Renka ise proovisin umbes samamoodi, aga reklaami asemel näitas ainult tühja kasti.
42 |
