uus teema   vasta Uudised »  Riistvara »  Seagate esitles oma esimest SSD ketaste perekonda märgi kõik teemad loetuks
sõnum 09.12.2009 01:38:13 Seagate esitles oma esimest SSD ketaste perekonda vasta tsitaadiga
link :: minut.ee
Üks suurimaid kõvakettatootjaid Seagate teatas ametlikult oma esimese SSD välkmäluketaste perekonna Pulsar turulejõudmisest. Tegemist on töökindlusele mõeldud ketastega, mida pakutakse suurtele OEM tootjatele andmehoidlate loomiseks.
Huvitaval kombel tuleb teade kolm kuud peale ketaste müügi algust. Seagate Pulsar perekonna esindajateks on 2,5" mõõdus 50, 100 ja 200 gigabaidise suurusega kettad, mis põhinevad SLC NAND mälul ning evivad SATA-2 liidest koos NCQ ja Trim funktsioonidega. Seagate esindaja sõnul on hetkel turg küps üleminekuks SSD ketastele ning hästi positsioneeritud pakkumistega loodetakse oma turuosa laiendada nii serverite kui sülearvutite osas.
Key Advantages
    Single-level cell (SLC) technology optimizes SSD reliability and endurance
    0.44 percent AFR for high reliability and endurance
    Up to 200GB capacity in a 2.5-inch form factor and 7mm z-height
    Power loss data protection to ensure against data loss upon power failure
    5-Year Limited Warranty
    SATA 3Gb/s interface to support current blade server chipsets
    Leveraging industry-leading, global enterprise support
    Industry-leading SSS and SSD standards development through JEDEC and SNIA
Gizmodo.com kirjutab:
The Pulsar drives are all 3Gb/s SATA compatible, offering top read/write speeds of 240MB/s and 220MB/s, respectively. For comparison, the current market champ, Intel's X25-M, hits 250MB/s read but only 100MB/s write, and the X25-M tops out at 160GB capacity. These new Seagate drives have a lifespan of about five years, which is about average for current-gen SSDs. The Pulsars began shipping to OEMs in September, so we should start seeing them pretty soon—right now, we don't have individual prices for them, although if Intel's X25-M's prices are any indication, they won't be cheap.
Vt. Seagate Pulsar koduleht.
Manus
Lae alla
Pulsar™ Product Overview
HV-s ID-kaardiga autentimine
Noname
Noname
sõnum 09.12.2009 03:11:31 vasta tsitaadiga
Väga hea uudis, WD võiks veel parema kettaga vastata, oleks lootust hindu langemas näha thumbs_up.gif
Kommentaarid: 373 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 322
matrix
matrix
sõnum 09.12.2009 11:40:16 vasta tsitaadiga
SLC puhul on kirjutsutsüklite arv teadagi kõigest 100 000, ehk siis suht nadi intensiivse kasutuse korral. Seega ma seda ketast väga töökindlaks siiski ei nimetaks, kui nad just mingi valemiga seda kirjutamiste arvu pole tõstnud.
Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
sõnum 09.12.2009 15:24:54 vasta tsitaadiga
matrix kirjutas:
Oma elueal sa seda nulli ei kirjuta
Lisaks SLC on kiirem ja töökindlam kui MLC.Paraku ka kallim.
kaabel
sõnum 10.12.2009 16:04:41 vasta tsitaadiga
matrix kirjutas:
100000 kirjutustsüklit ei käi mitte kogu ketta kohta, vaid iga mäluelemendi ("transistori") kohta.
Tegelikkult on küll nii, et mäluelemente saab kirjutada lehekülje kaupa (tüüpiliselt 4K) aga ülekirjutamiseks tuleb nad eelnevalt kustutada, mida saab teha vaid blokkide kaupa (128*4K=512K). Opsüsteem ise opereerib sektori tasemel (512B).
Kogu selle ebakõla tõttu kirjutatakse ja kustutatakse andmeid rohkem kui optimaalne, ning seetõttu on kasulike kirjutustsüklite arv hoopis väiksem, miski 50000 on palju reaalsem.
Nii, et asi on ikka täitsa metsas? Arvutame 100GB kettaga.
Kokku saab kirjutada kettale 50000*100=5000000 GB. Mõõtmised näitavad, et keskmine Windowsiga tavarvuti kirjutab kettale 5-10GB päevas. Ehk siis peaks jaguma isegi mitmesajaks aastaks. Seega on tavakasutuseks täitsa piisav ka MLC mälu 10000 kirjutamistsüklit, miski 10 aasta ikka peab vastu.
Vastuväide: Opsüsteem ei kirjuta ühtlaselt kettale, see koht kus swap fail ja registry asub saab palju rohkem vatti ja läheb katki ?
Tavaline kui mälukaardi või pulga pealt Windowsit käitada.
Aga SSD ei ole mälupulk, see sisaldab sisseehitatud loogikat, mis jagab koormust nii, et mälu kustutatakse ja kirjutatakse võimalikult optimaalselt, ning sama mäluplokki ei kirjutata aina uuesti ja uuesti üle, vaid võetakse järgmine vaba. Ehk siis sektor ei ole alati mälus samas kohas vaid mapitakse ringi.
Siin tulebki mängu SATA Trim käsk, mille abil Windows (alates 7) teatab kettale et see piirkond on on tühi (fail kustutati), kasuta seda ruumi uute andmete kirjutamiseks. Sest ketas ise on loll ja ei tea kas sektoris on kustutatud andmed või mitte.
Kommentaarid: 8 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 6
Chaza!
Chaza!
sõnum 16.12.2009 23:59:19 vasta tsitaadiga
Võiks hinnad ka alla minna, siis saaks hea vaikse läpaka endale. icon_smile.gif
Linux - Future
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 53
