praegune kellaaeg 12.10.2026 10:19:44
twist
21.10.2009 15:58:53
Probleem Solid Edge v19-ga |
Jama on selles, et võtan proge lahti, teen mõne liigutuse ja siis lööb sellise kasti ette ja sulgeb ennast.
Olen mitu korda uuesti installinud, aga ei mingit muutust.
_________________ Nothing will work unless you do |
| Kommentaarid: 16 loe/lisa |
16 |
Absona
| Kommentaarid: 11 loe/lisa |
twist
21.10.2009 16:10:10
Ta ei salvesta logi kuhugi, kohe saadab ära
16 |
Absona
twist
21.10.2009 16:51:54
Nähtamatut folderid oli vaja nähtavateks muuta, siis leidsin My bad, pole veel Vistaga harjunud.
Mida see siis tähendama peaks?? Solid Edge crash occurred because of a write access violation inside a display related event
Solid Edge crash occurred on 10/21/2009 at 16:05:15 because of a write access violation inside a display related event.
Elapsed session time: 0:00:00:47
Cumulative session time: 0:00:00:47
Exception code: 0xc0000005 (Access violation).
Attempted to write at 0x10f00000.
Solid Edge version: 19.00.00.66
OS version: Estonian Windows Vista Professional.
Number processors: 2
Video adapter information:
Display: 1280x800x32 @ 60Hz
GDI Driver: cdd.dll (6.0.6000.16517)
Display preferences:
AppDisplay(GCD+),Culling(Yes,20%),DynTransition(Yes,50%),Shaded(RefPlane,Hilite),Stereo(No)
Crash ID: {19B5F88D-53D1-47FC-867F-D8A23FEC6792}
Sold-To ID:
Owner: XXXXX
Company: HP
User: XXXXXX
Computer: XXXXXXX-PC
Critical
System DLL Version
ntdll.dll 6.0.6000.16386
gdi32.dll 6.0.6000.16766
ole32.dll 6.0.6000.16386
comcat.dll 6.0.6000.16386
user32.dll 6.0.6000.16438
shell32.dll 6.0.6000.16774
oleaut32.dll 6.0.6000.16609
comdlg32.dll 6.0.6000.16386
comctl32.dll 6.10.6000.16386
opengl32.dll 6.0.6000.16386
kernel32.dll 6.0.6000.16820
mfc42.dll 6.6.8063.0
msvcrt.dll 7.0.6000.16386
mfc71.dll 7.10.3077.0
msvcr71.dll 7.10.3052.4
msvcr70.dll 7.0.9955.0
cdd.dll 6.0.6000.16517
Most recent command: 0x4adf070b CmdExe cmdId = 10202 cmdEnv = "Profile" cmdTip = "Fit"
Command usage sequence:
Most recent events: 28 of 32
Ord Time Event Data
00 0x4adf06e1 CmdExe cmdId = 57617 cmdEnv = "Application" cmdTip = ""
01 0x4adf06e1 DocCtor docNum = 0x0b54d668 docNam = "Untitled"
02 0x4adf06e1 DocChg docNumAct = 0x0b54d668 docNumDeact = 0x00000000 docNamAct = "C:\Users\Uno Mikker\Documents\Part1.par" docNamDeact = ""
03 0x4adf06e2 EnvChg envAct = "Part" envDeact = ""
04 0x4adf06e2 DocOpn docNum = 0x0b54d668 docNam = "C:\Users\Uno Mikker\Documents\Part1.par"
05 0x4adf06e3 CmdExe cmdId = 45000 cmdEnv = "Part" cmdTip = "Select Tool"
06 0x4adf06e3 CmdExe cmdId = 0 cmdEnv = "Part" cmdTip = ""
07 0x4adf06e3 CmdExe cmdId = 0 cmdEnv = "Part" cmdTip = ""
08 0x4adf06e4 CmdExe cmdId = 32821 cmdEnv = "Part" cmdTip = "Fit"
09 0x4adf06e7 CmdExe cmdId = 45001 cmdEnv = "Part" cmdTip = "Cutout"
10 0x4adf06e8 EnvChg envAct = "LayoutInPart" envDeact = "Part"
11 0x4adf06e9 CmdExe cmdId = 25010 cmdEnv = "Profile" cmdTip = "Line"
12 0x4adf06eb CmdExe cmdId = 25010 cmdEnv = "Profile" cmdTip = "Line"
13 0x4adf06f2 CmdExe cmdId = 45000 cmdEnv = "Profile" cmdTip = "Select Tool"
14 0x4adf06f8 CmdExe cmdId = 57643 cmdEnv = "Profile" cmdTip = "Undo"
15 0x4adf06f8 CmdExe cmdId = 45000 cmdEnv = "Profile" cmdTip = "Select Tool"
16 0x4adf06f9 CmdExe cmdId = 57643 cmdEnv = "Profile" cmdTip = "Undo"
17 0x4adf06f9 CmdExe cmdId = 45000 cmdEnv = "Profile" cmdTip = "Select Tool"
18 0x4adf06f9 CmdExe cmdId = 57643 cmdEnv = "Profile" cmdTip = "Undo"
19 0x4adf06f9 CmdExe cmdId = 45000 cmdEnv = "Profile" cmdTip = "Select Tool"
20 0x4adf06fb CmdExe cmdId = 25010 cmdEnv = "Profile" cmdTip = "Line"
21 0x4adf0702 EnvChg envAct = "Part" envDeact = "LayoutInPart"
22 0x4adf0703 CmdExe cmdId = 45001 cmdEnv = "Part" cmdTip = "Cutout"
23 0x4adf0705 CmdExe cmdId = 45000 cmdEnv = "Part" cmdTip = "Select Tool"
24 0x4adf0707 CmdExe cmdId = 45001 cmdEnv = "Part" cmdTip = "Cutout"
25 0x4adf0709 EnvChg envAct = "LayoutInPart" envDeact = "Part"
26 0x4adf0709 CmdExe cmdId = 25010 cmdEnv = "Profile" cmdTip = "Line"
27 0x4adf070b CmdExe cmdId = 10202 cmdEnv = "Profile" cmdTip = "Fit"
Global memory utilization:
Total phys: 1,99 GB Avail phys: 487,05 MB
Total pg file: 3,99 GB Avail pg file: 2,63 GB
Total virt: 1,99 GB Avail virt: 1,34 GB
Percent phys used: 76
Process memory utilization:
Reserved: 227,04 MB Committed: 443,94 MB Free: 1,34 GB Largest Free: 938,12 MB Free Blocks: 928
GUI handle utilization:
GDI objects in use: 758 USER objects in use: 502
Loaded modules:
(0x00a60000 - 0x00a77000) APSHook.dll 2.5.0.29 Bioscrypt Inc.
(0x015c0000 - 0x015c8000) jutil.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x01dc0000 - 0x0217b000) separt.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x02cb0000 - 0x04266000) PSKERNEL.dll 0.18.0.168 UGS Corp.
(0x042e0000 - 0x042e3000) ChangeLog.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x04400000 - 0x04403000) umacro.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x04420000 - 0x0446d000) cntlrc.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x044a0000 - 0x044da000) RFMSSVS.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x044f0000 - 0x04525000) jdocres.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x04550000 - 0x04564000) RFMSDCX.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x045c0000 - 0x045d4000) engine.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x06720000 - 0x06725000) DraftRc.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x06770000 - 0x06995000) MINIEMS.DLL 1.0.0.1 Unigraphics Solutions, Inc.
(0x06d90000 - 0x070ef000) dcu2d49.dll 49.3.1.0 <unknown>
(0x07160000 - 0x0729d000) psbodyshop.dll 0.8.0.111 UGS Corp.
(0x072b0000 - 0x07314000) partPS.dll 1.0.0.1 Unigraphics Solutions, Inc.
(0x07350000 - 0x07d9a000) LightWorksDLL.dll 19.0.0.23 Unigraphics Solutions, Inc.
(0x07de0000 - 0x07de3000) OLEDMUI.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07e00000 - 0x07e04000) olesite.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07e20000 - 0x07e28000) EdgeBar.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07e40000 - 0x07e43000) copy.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07e60000 - 0x07e68000) expr.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07e80000 - 0x07e84000) csymdlg.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07ea0000 - 0x07ea6000) shlyhp.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07ed0000 - 0x07ed4000) CNSTRBMP.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07ef0000 - 0x07ef4000) GRPMGRRC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07f10000 - 0x07f13000) jfilsup.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07f30000 - 0x07f33000) DOCEXTRC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x07f50000 - 0x07fd7000) 2D.DRX 19.0.0.66 Unigraphics Solutions, Inc.
(0x07ff0000 - 0x07ff8000) dslctrl.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08010000 - 0x08013000) DRGNDRP.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08030000 - 0x08056000) 2DLC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08070000 - 0x08098000) 2DSC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x080b0000 - 0x080c1000) 2DLM.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x080e0000 - 0x080ec000) 2DSM.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08100000 - 0x0811c000) VWCMDS.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08160000 - 0x0818f000) STDDLL.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x081a0000 - 0x081a8000) STDNAMES.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x081c0000 - 0x08436000) STDPART.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08460000 - 0x084e2000) PDCXBMP.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08560000 - 0x085c1000) STDPARTBitmaps.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x085d0000 - 0x0863a000) SMTLCMD.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08640000 - 0x08651000) WELDCMD.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08670000 - 0x086f9000) SEPARTLC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08710000 - 0x0874f000) SEPARTSC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08760000 - 0x08763000) SEPARTLM.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x08780000 - 0x08783000) SEPARTSM.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x092d0000 - 0x092f7000) PROFCMD.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x094b0000 - 0x09549000) profile.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x09be0000 - 0x09bfa000) CNSTR2D.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x0a900000 - 0x0accc000) dcu3d34.dll 34.101.4.0 <unknown>
(0x0ace0000 - 0x0add8000) dcuaem34.dll 34.101.4.0 <unknown>
(0x0adf0000 - 0x0b0c8000) dcud3e34.dll 34.101.4.0 <unknown>
(0x0b0e0000 - 0x0b0ee000) dcucdm34.dll 34.101.4.0 <unknown>
(0x0b120000 - 0x0b220000) asm.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0b230000 - 0x0b2a3000) AsmDvx.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0b2e0000 - 0x0b3c9000) ACASM.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0b3e0000 - 0x0b3ee000) vwstyle.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0b400000 - 0x0b41b000) studio.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0b830000 - 0x0bbf8000) detail.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0bd00000 - 0x0bd77000) mshtmled.dll 7.0.6000.16916 Microsoft Corporation
(0x0d750000 - 0x0d753000) BLOCKSRC.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0d7b0000 - 0x0d7c5000) PropMgr.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x0fe70000 - 0x0fe73000) PROFDAP.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x10000000 - 0x1000c000) Edge.exe 19.0.0.66 Unigraphics Solutions, Inc.
(0x11160000 - 0x11168000) GaugeMgr.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x111e0000 - 0x111ee000) MFC71ENU.DLL 7.10.3077.0 Microsoft Corporation
(0x11360000 - 0x1157d000) GRA8E1~1.DLL 12.0.4518.1014 Microsoft Corporation
(0x115d0000 - 0x11684000) publish.dll 18.0.0.1 Immersive Design, Inc.
(0x11690000 - 0x1173e000) publishres.dll 18.0.0.1 Immersive Design, Inc.
(0x11850000 - 0x119d8000) System.Drawing.ni.dll 2.0.50727.3053 Microsoft Corporation
(0x15c40000 - 0x16737000) mscorlib.ni.dll 2.0.50727.3603 Microsoft Corporation
(0x16780000 - 0x16f05000) System.ni.dll 2.0.50727.3053 Microsoft Corporation
(0x16f10000 - 0x170b6000) Microsoft.VisualBasic.ni.dll 8.0.50727.3053 Microsoft Corporation
(0x170f0000 - 0x17100000) SEERStartUp.drx <unknown> <unknown>
(0x17610000 - 0x17613000) styles.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x17720000 - 0x182fe000) System.Windows.Forms.ni.dll 2.0.50727.3053 Microsoft Corporation
(0x18300000 - 0x18e43000) System.Web.ni.dll 2.0.50727.3074 Microsoft Corporation
(0x19b50000 - 0x19cc5000) ig4dev32.dll 7.14.10.1272 Intel Corporation
(0x19f80000 - 0x1a1cb000) ig4icd32.dll 7.14.10.1272 Intel Corporation
(0x1d5e0000 - 0x1d61d000) PSHRDCX.drx 19.0.0.66 Unigraphics Solutions, Inc.
(0x5d360000 - 0x5d36e000) MFC80ENU.DLL 8.0.50727.42 Microsoft Corporation
(0x60000000 - 0x6017d000) JUtil.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60290000 - 0x602d9000) sestartup.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60300000 - 0x60340000) separt.dnx 19.0.0.66 Unigraphics Solutions, Inc.
(0x60360000 - 0x603ad000) ASM.DNX 19.0.0.66 Unigraphics Solutions, Inc.
(0x60400000 - 0x60423000) DETAIL.dnx 19.0.0.66 Unigraphics Solutions, Inc.
(0x60500000 - 0x6055d000) COREVW.DVX 19.0.0.66 Unigraphics Solutions, Inc.
(0x60560000 - 0x6059a000) EXPRDVX.DVX 19.0.0.66 Unigraphics Solutions, Inc.
(0x60610000 - 0x60646000) VIEW.DVX 19.0.0.66 Unigraphics Solutions, Inc.
(0x606a0000 - 0x607ee000) acmdutl.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x607f0000 - 0x608dc000) AddInlm.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60920000 - 0x60966000) asmapp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60b10000 - 0x60b71000) asmds.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60dc0000 - 0x60dd3000) autools.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60e30000 - 0x60e39000) AutoUtils.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60e40000 - 0x60e47000) avwsdlg.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60e70000 - 0x60e7a000) bindex.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60e80000 - 0x60e89000) bitarry.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60e90000 - 0x60ec4000) BoltedConnSrv.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60f30000 - 0x60f88000) Cell.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60f90000 - 0x60f9c000) ChangeLog.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60fa0000 - 0x60fba000) cmdspt.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x60fc0000 - 0x61006000) CMDSPT2D.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61010000 - 0x61016000) cnstbmp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61020000 - 0x6102d000) config.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61030000 - 0x61142000) control.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61170000 - 0x6117b000) D3DGLST.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x611a0000 - 0x611b5000) Daxutil.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x611c0000 - 0x61212000) DBATCH.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x61220000 - 0x6129e000) DCM_IMP.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61b80000 - 0x61c2c000) dethook.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61c30000 - 0x61c3a000) detline.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61d50000 - 0x61d65000) Displst.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61dd0000 - 0x61f05000) DOCMGMT.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x61f10000 - 0x61f4e000) DocUpdate.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61f50000 - 0x61f5b000) DOCXSH.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x61f70000 - 0x61f89000) drgndrp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61f90000 - 0x61fd0000) dslctrl.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x61fd0000 - 0x62021000) dslutil.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62030000 - 0x62057000) EdgeBar.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62090000 - 0x620b3000) EMS2SE.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x620f0000 - 0x620fa000) emstrns.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62110000 - 0x6214b000) EXPRDEX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x62150000 - 0x62188000) familya.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62190000 - 0x62197000) famsvcs.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62250000 - 0x62270000) fontmgr.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62270000 - 0x62283000) Frustrm.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62290000 - 0x6232b000) FWKAUTO.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x62490000 - 0x624bc000) GAUGMGR.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x625a0000 - 0x625c9000) GenLink.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x625d0000 - 0x62619000) GEOM2DSVC.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62700000 - 0x62732000) hcnstr.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62740000 - 0x62749000) hslvr.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62750000 - 0x6284e000) i9cflc01.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62850000 - 0x6285f000) idsapi.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62c90000 - 0x62cc6000) jdchlp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62ce0000 - 0x62d91000) JDVSvcs.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x62da0000 - 0x630a2000) jengine.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x630b0000 - 0x630bd000) JFILSUP.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63120000 - 0x63149000) jmcmddcx.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63190000 - 0x631b0000) LINKOLE.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x631b0000 - 0x631c3000) LiteDataServer.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x631d0000 - 0x631ed000) liteidsapi.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x631f0000 - 0x6323d000) LITPRT.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63240000 - 0x63265000) LITPSUP.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x632b0000 - 0x632b6000) log.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x632c0000 - 0x632cf000) ltqry.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x632e0000 - 0x6330e000) MatTable.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63450000 - 0x63458000) OLEDMUI.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63480000 - 0x63557000) OLESITE.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x635a0000 - 0x63886000) partbrp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63890000 - 0x63bc4000) partDax.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x63bd0000 - 0x640dd000) partDcx.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x640e0000 - 0x643ba000) partDex.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x643c0000 - 0x643cf000) PARTDVX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x643d0000 - 0x64492000) partmnk.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x644a0000 - 0x64796000) partSvc.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x647a0000 - 0x64873000) partutl.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x64880000 - 0x648a5000) PipeDBAccess.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65500000 - 0x65526000) ProbeUtilities.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65550000 - 0x655a6000) PROFDAX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x655b0000 - 0x6564a000) PROFDCX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65650000 - 0x65719000) profDex.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65720000 - 0x6573c000) profhlp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65780000 - 0x65850000) PROPMGR.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65850000 - 0x65bd2000) PRTAUTO.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65be0000 - 0x65c0d000) PRTDAT.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65c10000 - 0x65c37000) PSCVT.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65c40000 - 0x65da2000) PSHRDCX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65de0000 - 0x65dea000) ptrnsup.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x65e10000 - 0x65f67000) RENDER.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65f70000 - 0x65fb0000) RENDEX.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x65fb0000 - 0x6606b000) RFMSDCX.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x66070000 - 0x6655e000) RFMSsvs.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x66c70000 - 0x66c84000) seinstalldata.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x66cc0000 - 0x66cd0000) SELINKINFO.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x66d60000 - 0x66d79000) sensor.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67960000 - 0x67982000) Seprop.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x679e0000 - 0x679f2000) sexpk.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67a00000 - 0x67a09000) shake.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67a10000 - 0x67a3d000) shlyhp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67a50000 - 0x67a6d000) skpref.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67a70000 - 0x67a82000) SMART.DLL 19.0.0.66 Unigraphics Solutions, Inc.
(0x67ab0000 - 0x67d83000) smtlbrp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x67d90000 - 0x67e8c000) smtldcx.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x681b0000 - 0x681bc000) splash.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x681f0000 - 0x68217000) sprfhlp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68250000 - 0x6825d000) stylspt.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x682e0000 - 0x682eb000) taglist.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x682f0000 - 0x68302000) timeutl.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68370000 - 0x68501000) tubing.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68510000 - 0x6861a000) ubspm2d.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68620000 - 0x68754000) ubspm3d.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68760000 - 0x687e7000) ugeom.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x687f0000 - 0x6885f000) ugeom2d.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68860000 - 0x68888000) ugsm.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x688a0000 - 0x688aa000) umacro.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x688b0000 - 0x688ce000) umath.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x688f0000 - 0x688fb000) Uprfhlp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68900000 - 0x6890f000) upstgt.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68910000 - 0x68916000) uwmath.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68920000 - 0x68935000) vhlsupp.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68960000 - 0x68c36000) Visual.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68cc0000 - 0x68d1e000) vwsedlg.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68d20000 - 0x68d33000) WebClientConsumer.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68d40000 - 0x68daa000) welddcx.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68e50000 - 0x68e5e000) XProbeUtilities.dll 19.0.0.66 Unigraphics Solutions, Inc.
(0x68ef0000 - 0x68fe1000) GrooveUtil.DLL 12.0.4518.1014 Microsoft Corporation
(0x68ff0000 - 0x68ff7000) GrooveNew.DLL 12.0.4518.1014 Microsoft Corporation
(0x69030000 - 0x690ef000) GEOM2D.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x690f0000 - 0x69109000) group.dax 19.0.0.66 Unigraphics Solutions, Inc.
(0x69110000 - 0x6920b000) HANNOT.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x69210000 - 0x6927d000) hdrvw.dax 19.0.0.66 Unigraphics Solutions, Inc.
(0x692b0000 - 0x692be000) HLAYER.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x69340000 - 0x69353000) HSTYL3D.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x69370000 - 0x6937e000) HVWSTYL.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x693b0000 - 0x693cd000) STYLES.DAX 19.0.0.66 Unigraphics Solutions, Inc.
(0x69a00000 - 0x69a0a000) cmdactv.dcx 19.0.0.66 Unigraphics Solutions, Inc.
(0x69a10000 - 0x69a23000) copy.dcx 19.0.0.66 Unigraphics Solutions, Inc.
(0x69df0000 - 0x6a3b5000) i2d.dcx 19.0.0.66 Unigraphics Solutions, Inc.
(0x6a470000 - 0x6a4fd000) studio.dcx 19.0.0.66 Unigraphics Solutions, Inc.
(0x6a540000 - 0x6a5b4000) VWCMDS.DCX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6a5c0000 - 0x6a5dd000) VWSCMDS.DCX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6a5e0000 - 0x6aa3f000) AEASM.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6aa40000 - 0x6ad6b000) ANNOT.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6ad70000 - 0x6adc8000) BLOCKS.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6ae20000 - 0x6ae86000) DOCEXT.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6ae90000 - 0x6ae98000) FSOVER.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6aea0000 - 0x6b075000) GRAPH2D.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b080000 - 0x6b0a0000) grp_dex.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b0a0000 - 0x6b0b7000) Grpmgr.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b1b0000 - 0x6b214000) Interop.SolidEdgeFramework.dll 1.0.0.0 <unknown>
(0x6b680000 - 0x6b6e7000) jgeom3d.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b700000 - 0x6b71d000) lyrmgr.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b720000 - 0x6b72a000) NAMEDVW.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b730000 - 0x6b73c000) NAMEMGR.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b790000 - 0x6b7e7000) STYLE.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b7f0000 - 0x6b804000) STYLE3D.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b810000 - 0x6b82f000) stylmgr.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b840000 - 0x6b882000) symbol.dex 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b8d0000 - 0x6b8e5000) VWSTYLE.DEX 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b900000 - 0x6b908000) ssymbol.dsx 19.0.0.66 Unigraphics Solutions, Inc.
(0x6b960000 - 0x6b98a000) profile.dnx 19.0.0.66 Unigraphics Solutions, Inc.
(0x6ba10000 - 0x6ba39000) SEListCtrlX.ocx 19.0.0.66 Unigraphics Solutions, Inc.
(0x6bea0000 - 0x6c215000) mshtml.dll 7.0.6000.16916 Microsoft Corporation
(0x6c2a0000 - 0x6c36b000) OPENGL32.dll 6.0.6000.16386 Microsoft Corporation
(0x6d5e0000 - 0x6d608000) SEERStartUp.dll 1.0.0.1 UGS PLM Solutions
(0x6d6d0000 - 0x6d72b000) mscorjit.dll 2.0.50727.3074 Microsoft Corporation
(0x6db50000 - 0x6db62000) ntlanman.dll 6.0.6000.16386 Microsoft Corporation
(0x6db70000 - 0x6db7f000) davclnt.dll 6.0.6000.16386 Microsoft Corporation
(0x6db80000 - 0x6db88000) drprov.dll 6.0.6000.16386 Microsoft Corporation
(0x6dc90000 - 0x6dd76000) DDRAW.dll 6.0.6000.16386 Microsoft Corporation
(0x6e060000 - 0x6e5f0000) mscorwks.dll 2.0.50727.3603 Microsoft Corporation
(0x6e760000 - 0x6e7dd000) jscript.dll 5.7.0.16865 Microsoft Corporation
(0x6eea0000 - 0x6eec3000) GLU32.dll 6.0.6000.16386 Microsoft Corporation
(0x6f620000 - 0x6f649000) msls31.dll 3.10.349.0 Microsoft Corporation
(0x6f930000 - 0x6fefd000) ieframe.dll 7.0.6000.16916 Microsoft Corporation
(0x6ffc0000 - 0x6fff0000) mlang.dll 6.0.6000.16386 Microsoft Corporation
(0x70030000 - 0x7003b000) msimtf.dll 6.0.6000.16386 Microsoft Corporation
(0x706a0000 - 0x706ea000) ntshrui.dll 6.0.6000.16386 Microsoft Corporation
(0x70810000 - 0x70819000) LINKINFO.dll 6.0.6000.16386 Microsoft Corporation
(0x70830000 - 0x70837000) midimap.dll 6.0.6000.16386 Microsoft Corporation
(0x70840000 - 0x70855000) MSACM32.dll 6.0.6000.16386 Microsoft Corporation
(0x70950000 - 0x709e5000) cscui.dll 6.0.6000.16386 Microsoft Corporation
(0x70bf0000 - 0x70c56000) audioeng.dll 6.0.6000.16386 Microsoft Corporation
(0x70c90000 - 0x70cb1000) audioses.dll 6.0.6000.16386 Microsoft Corporation
(0x70cd0000 - 0x70cd9000) msacm32.drv 6.0.6000.16386 Microsoft Corporation
(0x70e40000 - 0x70f85000) browseui.dll 6.0.6000.16386 Microsoft Corporation
(0x710b0000 - 0x710b9000) CSCDLL.dll 6.0.6000.16386 Microsoft Corporation
(0x71120000 - 0x71124000) ksuser.dll 6.0.6000.16386 Microsoft Corporation
(0x71130000 - 0x71160000) wdmaud.drv 6.0.6000.16386 Microsoft Corporation
(0x71930000 - 0x71936000) DCIMAN32.dll 6.0.6000.16870 Microsoft Corporation
(0x71a50000 - 0x71a5c000) dwmapi.dll 6.0.6000.16386 Microsoft Corporation
(0x71a60000 - 0x71a79000) cryptnet.dll 6.0.6000.16386 Microsoft Corporation
(0x71c00000 - 0x71c46000) mscoree.dll 2.0.50727.3053 Microsoft Corporation
(0x72280000 - 0x723a7000) msxml3.dll 8.100.1048.0 Microsoft Corporation
(0x72690000 - 0x726ce000) PortableDeviceApi.dll 6.0.6000.16767 Microsoft Corporation
(0x726d0000 - 0x726d6000) sensapi.dll 6.0.6000.16386 Microsoft Corporation
(0x73120000 - 0x731a7000) MSVCP80.dll 8.0.50727.3053 Microsoft Corporation
(0x73220000 - 0x73243000) MSVFW32.dll 6.0.6000.16868 Microsoft Corporation
(0x73250000 - 0x73260000) SEERCommon.dll 1.0.0.1 <unknown>
(0x732a0000 - 0x732b8000) AVIFIL32.dll 6.0.6000.16868 Microsoft Corporation
(0x732d0000 - 0x732da000) CSCAPI.dll 6.0.6000.16386 Microsoft Corporation
(0x732e0000 - 0x73321000) WINSPOOL.DRV 6.0.6000.16386 Microsoft Corporation
(0x73330000 - 0x733cb000) MSVCR80.dll 8.0.50727.3053 Microsoft Corporation
(0x73c90000 - 0x73e94000) msi.dll 4.0.6000.16386 Microsoft Corporation
(0x73ea0000 - 0x73f7c000) dbghelp.dll 6.0.6000.16386 Microsoft Corporation
(0x73fd0000 - 0x74001000) TAPI32.dll 6.0.6000.16386 Microsoft Corporation
(0x74010000 - 0x74057000) RASAPI32.dll 6.0.6000.16386 Microsoft Corporation
(0x742b0000 - 0x742c4000) rasman.dll 6.0.6000.16386 Microsoft Corporation
(0x742f0000 - 0x742fc000) rtutils.dll 6.0.6000.16386 Microsoft Corporation
(0x74550000 - 0x74602000) WindowsCodecs.dll 6.0.6000.16740 Microsoft Corporation
(0x74a80000 - 0x74b37000) PROPSYS.dll 6.0.6000.16386 Microsoft Corporation
(0x74cf0000 - 0x74e9a000) gdiplus.dll 5.2.6000.16782 Microsoft Corporation
(0x74f60000 - 0x74f74000) Cabinet.dll 6.0.6000.16386 Microsoft Corporation
(0x74fd0000 - 0x74ff7000) MMDevAPI.DLL 6.0.6000.16386 Microsoft Corporation
(0x75020000 - 0x75050000) DUser.dll 6.0.6000.16386 Microsoft Corporation
(0x75050000 - 0x7508f000) uxtheme.dll 6.0.6000.16386 Microsoft Corporation
(0x75180000 - 0x7519c000) oledlg.dll 6.0.6000.16386 Microsoft Corporation
(0x75200000 - 0x75208000) Interop.SEInstallDataLib.dll 1.0.0.0 <unknown>
(0x752b0000 - 0x752b7000) msiltcfg.dll 4.0.6000.16386 Microsoft Corporation
(0x75420000 - 0x755b4000) comctl32.dll 6.10.6000.16386 Microsoft Corporation
(0x755d0000 - 0x755d7000) AVRT.dll 6.0.6000.16386 Microsoft Corporation
(0x755f0000 - 0x7561d000) WINTRUST.dll 6.0.6000.16386 Microsoft Corporation
(0x75730000 - 0x75751000) NTMARTA.DLL 6.0.6000.16386 Microsoft Corporation
(0x75760000 - 0x75798000) OLEACC.dll 4.2.5406.0 Microsoft Corporation
(0x757a0000 - 0x757d3000) WINMM.dll 6.0.6000.16386 Microsoft Corporation
(0x75810000 - 0x75825000) GPAPI.dll 6.0.6000.16386 Microsoft Corporation
(0x75850000 - 0x75888000) rsaenh.dll 6.0.6000.16386 Microsoft Corporation
(0x758c0000 - 0x75905000) schannel.dll 6.0.6000.16870 Microsoft Corporation
(0x75a80000 - 0x75a85000) MSIMG32.dll 6.0.6000.16386 Microsoft Corporation
(0x75ae0000 - 0x75ae8000) VERSION.dll 6.0.6000.16386 Microsoft Corporation
(0x75bc0000 - 0x75bc7000) credssp.dll 6.0.6000.16386 Microsoft Corporation
(0x75bd0000 - 0x75c14000) BCRYPT.dll 6.0.6000.16386 Microsoft Corporation
(0x75c20000 - 0x75c52000) ncrypt.dll 6.0.6000.16386 Microsoft Corporation
(0x75c80000 - 0x75ca0000) dhcpcsvc6.DLL 6.0.6000.16512 Microsoft Corporation
(0x75ca0000 - 0x75ca7000) WINNSI.DLL 6.0.6000.16386 Microsoft Corporation
(0x75cb0000 - 0x75ce5000) dhcpcsvc.DLL 6.0.6000.16512 Microsoft Corporation
(0x75cf0000 - 0x75d09000) iphlpapi.dll 6.0.6000.16386 Microsoft Corporation
(0x75d60000 - 0x75d99000) slc.dll 6.0.6000.16509 Microsoft Corporation
(0x75da0000 - 0x75e91000) CRYPT32.dll 6.0.6000.16425 Microsoft Corporation
(0x75ea0000 - 0x75eb4000) MPR.dll 6.0.6000.16386 Microsoft Corporation
(0x75ee0000 - 0x75ef2000) MSASN1.dll 6.0.6000.16922 Microsoft Corporation
(0x75f00000 - 0x75f11000) SAMLIB.dll 6.0.6000.16386 Microsoft Corporation
(0x75f20000 - 0x75f4b000) DNSAPI.dll 6.0.6000.16615 Microsoft Corporation
(0x76120000 - 0x7618a000) NETAPI32.dll 6.0.6000.16764 Microsoft Corporation
(0x76190000 - 0x761ef000) SXS.DLL 6.0.6000.16386 Microsoft Corporation
(0x76250000 - 0x7627c000) apphelp.dll 6.0.6000.16386 Microsoft Corporation
(0x762e0000 - 0x762f4000) Secur32.dll 6.0.6000.16870 Microsoft Corporation
(0x76300000 - 0x7631e000) USERENV.dll 6.0.6000.16386 Microsoft Corporation
(0x763b0000 - 0x763b7000) PSAPI.DLL 6.0.6000.16386 Microsoft Corporation
(0x76450000 - 0x764cd000) USP10.dll 1.626.6000.16386 Microsoft Corporation
(0x764d0000 - 0x764fd000) WS2_32.dll 6.0.6000.16386 Microsoft Corporation
(0x76500000 - 0x76555000) SHLWAPI.dll 6.0.6000.16386 Microsoft Corporation
(0x76560000 - 0x765e4000) CLBCatQ.DLL 2001.12.6930.16386 Microsoft Corporation
(0x765f0000 - 0x766b7000) MSCTF.dll 6.0.6000.16386 Microsoft Corporation
(0x766c0000 - 0x76705000) iertutil.dll 7.0.6000.16916 Microsoft Corporation
(0x76710000 - 0x767ba000) msvcrt.dll 7.0.6000.16386 Microsoft Corporation
(0x767c0000 - 0x76949000) SETUPAPI.dll 6.0.6000.16609 Microsoft Corporation
(0x76950000 - 0x769c4000) comdlg32.dll 6.0.6000.16386 Microsoft Corporation
(0x769d0000 - 0x76af8000) urlmon.dll 7.0.6000.16916 Microsoft Corporation
(0x76b00000 - 0x76bbf000) ADVAPI32.dll 6.0.6000.16386 Microsoft Corporation
(0x76bc0000 - 0x76c5e000) USER32.dll 6.0.6000.16438 Microsoft Corporation
(0x76c60000 - 0x76d23000) RPCRT4.dll 6.0.6000.16850 Microsoft Corporation
(0x76d30000 - 0x777fe000) SHELL32.dll 6.0.6000.16774 Microsoft Corporation
(0x77800000 - 0x7788c000) OLEAUT32.dll 6.0.6000.16609 Microsoft Corporation
(0x77890000 - 0x77968000) kernel32.dll 6.0.6000.16820 Microsoft Corporation
(0x77970000 - 0x77ab4000) ole32.dll 6.0.6000.16386 Microsoft Corporation
(0x77ac0000 - 0x77b91000) WININET.dll 7.0.6000.16916 Microsoft Corporation
(0x77ba0000 - 0x77cbe000) ntdll.dll 6.0.6000.16386 Microsoft Corporation
(0x77cc0000 - 0x77cc6000) NSI.dll 6.0.6000.16386 Microsoft Corporation
(0x77cd0000 - 0x77cee000) IMM32.DLL 6.0.6000.16386 Microsoft Corporation
(0x77cf0000 - 0x77d3b000) GDI32.dll 6.0.6000.16766 Microsoft Corporation
(0x77d40000 - 0x77d49000) LPK.DLL 6.0.6000.16870 Microsoft Corporation
(0x77d50000 - 0x77d99000) WLDAP32.dll 6.0.6000.16386 Microsoft Corporation
(0x77da0000 - 0x77dc9000) imagehlp.dll 6.0.6000.16470 Microsoft Corporation
(0x77dd0000 - 0x77dd3000) Normaliz.dll 6.0.6000.16386 Microsoft Corporation
(0x781d0000 - 0x782dd000) MFC80.DLL 8.0.50727.42 Microsoft Corporation
(0x7c140000 - 0x7c243000) MFC71.DLL 7.10.3077.0 Microsoft Corporation
(0x7c340000 - 0x7c396000) MSVCR71.dll 7.10.3052.4 Microsoft Corporation
(0x7c3a0000 - 0x7c41b000) MSVCP71.dll 7.10.3077.0 Microsoft Corporation
(0x7c630000 - 0x7c64b000) ATL80.DLL 8.0.50727.42 Microsoft Corporation
Register dump:
Context flags: 0001003f
Floating point registers:
cw: ffff027f sw: ffff0120 tw: ffffffff eo: 19bd3545 es: 035c001b
do: 00a2b548 ds: ffff0023 ns: 00000000
Segment registers:
gs: 00000000 fs: 0000003b es: 00000023 ds: 00000023
Integer registers:
eax: 10f00000 ebx: 04f82000 ecx: 0e0150f0 edx: 10f00004 edi: 00000001 esi: 1c9ad828
Control registers:
ebp: 00000068 eip: 19b88ced esp: 00a2b560
sc: 0000001b ef: 00010206 ss: 00000023
Stack trace for thread 0x00000fe4:
Instruction Address Param 1 Param 2 Param 3 Param 4 Ins Offset DLL Name Function Name
0x19b88ced (0001:00037ced) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 ig4dev32.dll ???
System Log File Contents:
System logging is not enabled.
16 |
Absona
twist
21.10.2009 18:22:42
Seal oli soovitus Nortonit update-da. Selle tegin ära. Jooksutasin ka adminnina proget, kuid mitte mingit muutust
16 |
teretalv
25.10.2009 17:21:16
mis süsteemi kasutad vista 7 xp? mul lambis jooksis kokku vista all
_________________ Ära usu kes kutsuvad kuskile raha investeerima. Suurt tootlust ei tule keegi kandikul kätte tooma! Head ja kindlat tootlust saab ainult siis, kui ise enda kontrolli all on kogu protsess või enamus sellest.
Teen Hobikorras Audio, Video, Foto ja Trükiettevalmistust/Kujundust ja Python Scripte |
| Kommentaarid: 51 loe/lisa |
44 |
twist
26.10.2009 18:57:01
Eks ta üks Vistarämps ole.
16 |
dzombe
27.10.2009 18:26:19
Ehk kas videodraivereid oled kontrollinud? Solidedge Vista vaikimisi VESA ajuriga on üldse nõus käima minema? Igatahes katseta. Ja ilmselt töö käigus vahet küll pole, kas mällu kirjutamisel tuleb viga admini või tavakasutaja all.
_________________ -- |
