uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3/X360] Operation Flashpoint: Dragon Rising märgi kõik teemad loetuks
beastbeats
beastbeats
sõnum 22.10.2009 13:14:43 [PS3/X360] Operation Flashpoint: Dragon Rising vasta tsitaadiga
Ametlik leht: http://www.codemasters.com/flashpoint/
Väljaandja / arendaja: Codemasters
Stiil: Modern Tactical Shooter
Väljalaske kuupäev:
06.10.2009 (USA)
08.10.2009 (EU)
Kirjeldus:
Codemasters kirjutas:
The island of Skira has been a disputed territory since the end of World War II. Officially, it falls under the sovereignty of the Russian Federation, but a U.S. and Japanese presence has been there following the discovery of extremely rich and viable oil fields. On September 23rd at 0800 hours, under the guise of ensuring his people's prosperity, General Zheng ordered an airborne division of the People's Liberation Army of China (PLA) to execute a lightning invasion, claiming Skira Island for the People's Republic. As you are aware, the Russian Federation has requested U.S. military support. In response, the USS Iwo Jima has been deployed. You and your fellow Marines should expect to engage scattered but heavily entrenched PLA positions. Our success on Skira could avert total war on the mainland.
Multiplayer: Jah
Uudised / screenshotid / videod: http://www.gamespot.com/xbox360/action/operationflashpoint2/index.html
EDIT:
http://www.joystiq.com/2009/10/21/operation-flashpoint-patch-coming-alongside-first-dlc/
M: Cannondale Tract MIPSkiiver (uus; Polar White; Large) - 40€
Rajareits
Rajareits
sõnum 15.11.2009 22:29:18 vasta tsitaadiga
Kuidas kurat ma 3nda missiooni lõpust, küla kaitsmisest läbi peaks saama?
Mingi 30 korda teinud seda juba, täiesti võimatu.. :S
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 69
leki
leki
sõnum 16.11.2009 22:55:26 vasta tsitaadiga
mul oli samuti esimene raskem koht seal. Probleemne minu jaoks oli just külale lähenemine, sest see oli vaenlasi täis. Minul kandis vilja lõpuks see, kui suunasin teamikaaslasi rohkem vastasele tuld andma ja rünnakule, mitte ei püüdnud neid ise kõiki maha nottida. Seejärel külasse jõudes, varjusin mingisse hütti ja käsutasin kaasvõitlejaid külale lähenejaid tulistama, samas ka ise ühte ilmakaart enda tule all hoides. ja mingi hetk oligi missioon läbi.
Rajareits
Rajareits
sõnum 17.11.2009 00:07:20 vasta tsitaadiga
leki, külla sisse sain suht lihtsalt (peale mingit viiendat korda vast, vb rohkem), aga küla kaitsmisega ei saa kuidagi hakkama.. icon_neutral.gif
Kuidas kaitsesid? Kuhu mehed saatsid jne?
leki
leki
sõnum 17.11.2009 09:43:03 vasta tsitaadiga
mehi suunasin sinna, kust vastaseid peale tuli. meeste kamandamiseks ei kasutanud mitte visuaalset vaadet vaid kaarti, sest vastasel juhul lasti mind kohe sodiks. ise pesitsesin ühes majakeses, enamus aega lamavas asendis. kaardilt vaatasin, kui mõni vastane majale ohtlikult lähedal, siis andisn talle akna või ukse vahelt tuld. parem on omada kahte assult relva- optilise sihikuga ja tavalist. Muidugi oleneb, mis raskusastmega mängid. Ma mängin normal tasemega ja sel juhul näitab kaart inffi rohkem.
Rajareits
Rajareits
sõnum 17.11.2009 19:24:14 vasta tsitaadiga
leki, ma kõige nõrgemaga. Siiamaani Marksman relva kasutanud ja mehed enne paika pannud. Aga tänud, lähen proovin. thumbs_up.gif
Tipp
Tipp
sõnum 27.10.2010 13:53:22 vasta tsitaadiga
Kas keegi mängib veel seda? Tahaks abi, et teha see achievement ära, kus peab kopteriga vastase ära tapma vms.
EDIT: Heh, ajasin jälle xkasti tööle ja küsiks üle, ega keegi ei mängi seda? Võiks onlines lasta natukene.
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
