praegune kellaaeg 14.11.2026 00:00:37
Kitsekyla
22.09.2009 17:11:36
DELL Inspiron 1501 - tahaks vahetada XP vista vastu aga ei suuda vistat bootida |
| Tegemist siis rüperaaliga DELL Inspiron 1501. Probleem selles et XP-ga hakkas arvuti segast panema - aeglane, ei taha laadjat taha võtta. Mõtlesin et proovin vistat, aga ei saa seda kuidagi üles bootitud. Vista asub siis Recovery drivel. Kuidas ma saan vista üles bootida??
Kalle
22.09.2009 19:43:37
Muidu peaks Dell Inspiron peal recovery partitionilt OS taastamine käima sellist rada mööda:
Using Dell Factory Image Restore in Windows Vista
Notice:
Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1. Turn on the computer.
2. As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
Note:
You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7. In the Dell Factory Image Restore window, click Next.
8. Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9. Click Next.
The computer is restored to the default factory configuration.
10. When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
Kuna Sull on XP peale installitud ja recovery DVD puudub arvatavasti (masinas on recovery partition) siis ei saa ka sinna recovery consooli peale pärast bootimist (kui ta HDD peale ikka alles jätsid). Siit lingilt leiad vajaliku info, et oma masina uuesti sealt recovery partitioni pealt bootima seada ja taastada selle pealt Vista. Laadi allpool olevatelt linkidelt siis vastavalt vajalik ''Windows Vista Recovery CD'' torrent alla kas x64 või x86 Vista jaoks (vaata kleepsult järgi kumb sull peal oli) ja kõrveta see ISO plaadile. Siis boodid masina sellelt plaadilt ülesse ja pääsed Vista recovery konsooli sätete kallale, kust siis saad anda installimiseks tee recovery partitioni peale või kui ei leita siis saad bootfix kasutades uuesti nähtavaks teha selle recovery partitioni (ei viitsi pikalt õpetada sest kõik vajalikud õpetused nendel 2 lehel olemas)
Windows Vista 32-Bit (x86) Recovery Disc Torrent - http://neosmart.net:6969/torrent.html?info_hash=c7411cffb5b0c27b28d0ec080af55ea0016f7b7b
Windows Vista 64-Bit (x64) Recovery Disc Torrent - http://neosmart.net:6969/torrent.html?info_hash=fbf47dd7d63708ea2e7acac1709747c5f7eb94b5
Kogu protsessi õpetus: http://blogs.techrepublic.com.com/window-on-windows/?p=622
Kitsekyla
22.09.2009 22:33:26
| tegin selle bootdiski ära nüüd, aga nüüd ongi see probleem et see bootdisk ei suuda leida recover hard drivied. Kuidas see käib?
Kalle
22.09.2009 23:25:21
| Kui boodid sellelt Cd'lt ''F8'' siis ''Repair your computer'' ja jõuad ''System Recovery Options'' peale, valid esmalt ''Startup Repair'' - kui see on oma fixid ära teinud siis tahab restarti ja nüüd teistkordsel ''System Recovery Options'' sisenemisel peab ''CompletePC Restore'' käivitamisel pakkuma võimaluse taastada OS Dell Factory Image Restore pealt.
Kitsekyla
23.09.2009 17:50:59
| startup repair annab veateate et windows startup repair cant run automatically. Ja lõpuks siis et kas tahan selle veateate microsftile saata või mitte
Kalle
23.09.2009 18:51:23
| Kas BIOS'i laadimisel Ctrl+F11 kah ei toimi ?
