praegune kellaaeg 08.10.2026 10:07:33
kaupz
18.09.2009 21:33:02
ibm t43 kõvakettavahetus, ütleb et ei ole sertifitseeritud |
panin t43 sisse samsungi hm080ic 80gb ide ata ketta, ning sain biosis järgmise veateate:
error 2010:
the hard drive you have installed has not been qualified for use in this computer or does not have the latest firmware.
using a drive that is not qualified may cause compatibility issues and potential data loss.
to automatically continue after this message is displayed without having to press Esc, restart the computer, press F1 during power-on and look under Startup in the bios setup utility. |
ibm heakskiidetud ketaste listis samsungi ei ole, ainult seagate ja fujitsu
http://www.thinkwiki.org/wiki/Problem_with_non-ThinkPad_hard_disks
POST warning message 2010 after BIOS upgrade or hard drive installation - ThinkPad General
Symptom
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST:
ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-60169 |
uus win on peal ja pärast Esc vajutamist läheb tööle.
aga tahaks lahti saada sellest teatest.
on kellelgi kogemusi?
_________________ O: VW T2 Hipibussi Transporter T2a VolksWagen T1 või Vana Põrnika |
| Kommentaarid: 86 loe/lisa |
Elar
18.09.2009 22:07:31
There are three possible workarounds to eliminate the error:
Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
Note: This update requires a floppy disk drive.
Replace the hard drive with one supported by the system being used.
Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
segusilm
18.09.2009 22:28:47
| biosist saad panna resume on error, siis ei pea seda eskeipi vajutama, teade jääb muidugi iseenesest alles lihtsalt peaad mõne sekundi rohkem ootama algul.
| Kommentaarid: 245 loe/lisa |
221 |
Andrus Luht
itimees.ee
318 |
frygor
18.09.2009 22:44:56
| segusilm kirjutas: |
| biosist saad panna resume on error, siis ei pea seda eskeipi vajutama, teade jääb muidugi iseenesest alles lihtsalt peaad mõne sekundi rohkem ootama algul. |
varasemad t43 biosed seda ei võimaldanud aga mingist versioonist alates tuli see võimalus sisse... kui muidu ei ole biost updateitud ,siis ibmi kodulehelt saad alla laadida ja next>next>...>Finish tagumisega ära updateida.
| Kommentaarid: 70 loe/lisa |
65 |
kaupz
19.09.2009 00:14:24
| frygor kirjutas: |
varasemad t43 biosed seda ei võimaldanud aga mingist versioonist alates tuli see võimalus sisse... kui muidu ei ole biost updateitud ,siis ibmi kodulehelt saad alla laadida ja next>next>...>Finish tagumisega ära updateida. |
tirisin ja käivitasin, ütles et ei saa, pole vajalik. ju siis on sama versioon peal.
2006 versioon on kodulehel.
2009 aga mingi "bios capture" millega saab paroole määrata, vana aga välja ei loe
