praegune kellaaeg 05.11.2026 23:59:50
Plondiin
27.08.2009 16:36:56
doc ja pdf failid veebi, passwordi lisamine failidele |
Kuidas saaks doc ja pdf failidele passwordi lisada?
Vaja need veebi üles panna (kui lingil klikid, siis ei ava enne wordi/acrobati kui parool sisestatud) aga ei taha, et kõik lahti saavad.
Absona
| Kommentaarid: 11 loe/lisa |
Plondiin
28.08.2009 14:47:01
Kuidas saab kausta .htaccess'i kaudu parooli alla panna? |
Hea mõte, aga kuidas see täpselt käib?
Serveris ei ole .htaccess faili, on htaccess.txt. Pole võimalik htaccess.txt faili .htaccess-ks ka ümber nimetada. Kas faili nimes on muidu vahet?
kausta nimi on files ja asub wwwroot sees. (Faili aadress: http://www.sait.ee/files/pohikiri.pdf)
htaccess.txt faili sisu on siin, mida ja kuhu ma nüüd htaccess.txt sees kirjutan?
| html:
## # @version $Id: htaccess.txt 10492 2008-07-02 06:38:28Z ircmaxell $ # @package Joomla # @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved. # Joomla! is Free Software ## ##################################################### # READ THIS COMPLETELY IF YOU CHOOSE TO USE THIS FILE # # The line just below this section: 'Options +FollowSymLinks' may cause problems # with some server configurations. It is required for use of mod_rewrite, but may already # be set by your server administrator in a way that dissallows changing it in # your .htaccess file. If using it causes your server to error out, comment it out (add # to # beginning of line), reload your site in your browser and test your sef url's. If they work, # it has been set by your server administrator and you do not need it set here. # ##################################################### ## Can be commented out if causes errors, see notes above. Options +FollowSymLinks # # mod_rewrite in use RewriteEngine On ########## Begin - Rewrite rules to block out some common exploits ## If you experience problems on your site block out the operations listed below ## This attempts to block the most common type of exploit `attempts` to Joomla! # # Block out any script trying to set a mosConfig value through the URL RewriteCond %{QUERY_STRING} mosConfig_[a-zA-Z_]{1,21}(=|\%3D) [OR] # Block out any script trying to base64_encode crap to send via URL RewriteCond %{QUERY_STRING} base64_encode.*\(.*\) [OR] # Block out any script that includes a <script> tag in URL RewriteCond %{QUERY_STRING} (\<|%3C).*script.*(\>|%3E) [NC,OR] # Block out any script trying to set a PHP GLOBALS variable via URL RewriteCond %{QUERY_STRING} GLOBALS(=|\[|\%[0-9A-Z]{0,2}) [OR] # Block out any script trying to modify a _REQUEST variable via URL RewriteCond %{QUERY_STRING} _REQUEST(=|\[|\%[0-9A-Z]{0,2}) # Send all blocked request to homepage with 403 Forbidden error! RewriteRule ^(.*)$ index.php [F,L] # ########## End - Rewrite rules to block out some common exploits # Uncomment following line if your webserver's URL # is not directly related to physical file paths. # Update Your Joomla! Directory (just / for root) # RewriteBase / ########## Begin - Joomla! core SEF Section # RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_URI} !^/index.php RewriteCond %{REQUEST_URI} (/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$ [NC] RewriteRule (.*) index.php RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L] # ########## End - Joomla! core SEF Section
| Absona kirjutas: |
| Pane terve kaust .htaccess'i kaudu parooli alla. |
viimati muutis Plondiin 28.08.2009 15:08:03, muudetud 1 kord |
| Kommentaarid: 85 loe/lisa |
Plondiin
31.08.2009 13:37:25
Apachet serveris pole, windows server on. Kas see muudab midagi kui htaccess.txt fail on ja seda .htaccess ümber nimetada ei saa?
Absona
31.08.2009 14:27:20
| Plondiin kirjutas: |
Kui on Windows Server ja jookseb IIS'i peal, siis ei saa .htaccess'i kasutada. Sellejaoks on olemas hoopis web.config (saab projekti ka manuaalselt lisada ning iga kausta eraldi)
Üks võimalus on kasutada HttpHandlers, aga see läheb vist liiga keeruliseks (kui oskad juba piisavalt koodi kirjutada, siis on mingil määral isegi lihtsam).
Teine võimalus on web.config'is määratleda ära kes saavad kaustadele ligi, kes mitte (lihtsam on ka nii teha, et kõik on keelatud ja ftp kaudu saab ainult ligi).
<configuration xmlns="http://schemas.microsoft.com/.NetConfiguration/v2.0">
<location path="kausta_aadress">
<system.web>
<authorization>
<allow roles="Admin, mingi_teine, kolmas jne" /> <!--kõik kes tohivad kaustale ligi saada, paroolid paned paika koodis -->
<deny users="*" /> <!-- kõik võõrad blokeeritakse-->
<authorization>
</system.web>
</configuration>
Täpsem info asub siin: http://support.microsoft.com/kb/301240/EN-US/ ja ka siin: http://weblogs.asp.net/gurusarkar/archive/2008/09/29/setting-authorization-rules-for-a-particular-page-or-folder-in-web-config.aspx
Kui omad Windows serverit materiaalse varana, siis on asi suht lihtne. Ja ainuke soovitus on: tutvu võimalustega.
_________________ Veebilehed, veebiprogrammeerimine, veebilahendused
Erinevad rakendused ja skriptid. |
Plondiin
31.08.2009 15:48:16
Kasutajaid pole. Iga inimene näeb veebilehel linki ja selle klikkimisel (enne kui pdf avatakse) küsitakse parooli.
Saan aru et mina pean oma web.config failis siis lisama <system.webServer></system.webServer>vahele <location path="http://www.sait.ee/files">
<system.webServer>
</system.webServer>
kas ma saan siin web.config failis ka parooli paika panna, et kõikide files kaustas olevate failide avamisel küsitakse parooli?
minu web.config sisu:
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
<system.webServer>
<rewrite>
<rules>
<rule name="Security Rule" stopProcessing="true">
<match url="^(.*)$" ignoreCase="false" />
<conditions logicalGrouping="MatchAny">
<add input="{QUERY_STRING}" pattern="mosConfig_[a-zA-Z_]{1,21}(=|\%3D)" ignoreCase="false" />
<add input="{QUERY_STRING}" pattern="base64_encode.*\(.*\)" ignoreCase="false" />
<add input="{QUERY_STRING}" pattern="(\<|%3C).*script.*(\>|%3E)" />
<add input="{QUERY_STRING}" pattern="GLOBALS(=|\[|\%[0-9A-Z]{0,2})" ignoreCase="false" />
<add input="{QUERY_STRING}" pattern="_REQUEST(=|\[|\%[0-9A-Z]{0,2})" ignoreCase="false" />
</conditions>
<action type="CustomResponse" url="index.php" statusCode="403" statusReason="Forbidden" statusDescription="Forbidden" />
</rule>
<rule name="SEO Rule">
<match url="(.*)" ignoreCase="false" />
<conditions logicalGrouping="MatchAll">
<add input="{REQUEST_FILENAME}" matchType="IsFile" negate="true" pattern="" ignoreCase="false" />
<add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" pattern="" ignoreCase="false" />
<add input="{URL}" negate="true" pattern="^/index.php" ignoreCase="false" />
<add input="{URL}" pattern="(/|\.php|\.html|\.htm|\.feed|\.pdf|\.raw|/[^.]*)$" />
</conditions>
<action type="Rewrite" url="index.php" />
</rule>
</rules>
</rewrite>
<security>
<authentication>
<basicAuthentication enabled="false" />
</authentication>
</security>
<defaultDocument>
<files>
<clear />
<add value="index.php" />
</files>
</defaultDocument>
<httpRedirect enabled="false">
<clear />
</httpRedirect>
<httpProtocol>
<customHeaders>
<clear />
<add name="X-Powered-By" value="ASP.NET" />
</customHeaders>
</httpProtocol>
<handlers>
<remove name="PHP via CGI" />
<add name="PHP via FastCGI (*.php)" path="*.php" verb="GET,HEAD,POST,DEBUG" modules="FastCgiModule" scriptProcessor="C:\PHP5\php-cgi.exe" resourceType="File" />
<add name="ASPClassic (*.htr)" path="*.htr" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="C:\Windows\system32\inetsrv\asp.dll" resourceType="File" />
<add name="ASPClassic (*.cdx)" path="*.cdx" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="C:\Windows\system32\inetsrv\asp.dll" resourceType="File" />
<add name="ASPClassic (*.asa)" path="*.asa" verb="GET,HEAD,POST,DEBUG" modules="IsapiModule" scriptProcessor="C:\Windows\system32\inetsrv\asp.dll" resourceType="File" />
</handlers>
</system.webServer>
</configuration> |
| Absona kirjutas: |
<system.web>
<authorization>
<authorization>
</system.web>
</configuration>
Kui omad Windows serverit materiaalse varana, siis on asi suht lihtne. Ja ainuke soovitus on: tutvu võimalustega. |
Absona
Plondiin
01.09.2009 10:12:24
Veebileht on joomlaga tehtud, ise pole lehe juures midagi programmeerinud ja kahjuks ei oska ASP.NET/ VB.NET teemal kaasa rääkida.
Kui web.config failiga asja lahendamine liiga keeruliseks läheb, siis otsin mõne Joomla plugina.
