praegune kellaaeg 08.11.2026 11:13:57
spooky000
09.08.2009 17:27:17
Viasati Slingiga probleem |
nii probleem selles, eestis sling toimis mindi arvutiga soome seal enam ei funka...lööb selliseid errororeid
Error: 0x8007274c
Context: 1
Operation:110
Looks like there's a problem:
A property isn't loaded.
[Advanced users: the error code is 0x1234000a.]
SlingPlayer didn't load the property. It might not be supported in this version.
[Advanced users: the error code is 0x1234000b.]
A state change is needed for this property to work.
[Advanced users: the error code is 0x1234000c.]
The operation failed because of an invalid value type.
[Advan
Here are some possible reasons why this happened. This information may help you troubleshoot the problem.
The connection to the Slingbox has failed.
SlingPlayer has failed to get the needed proxy information.
Proxy setting wpad
SlingPlayer failed to resolve the address for the Slingbox.
Sending HTTP GET request
SlingPlayer wasn't able to connect with the Slingbox, possibly because of a commun
raul1978
09.08.2009 18:41:35
| kas see pole kindla tyyneriga seotud?
| Kommentaarid: 41 loe/lisa |
36 |
spooky000
09.08.2009 20:41:39
| raul1978 kirjutas: |
| kas see pole kindla tyyneriga seotud? |
tyyner on samsung
