praegune kellaaeg 20.11.2026 18:33:33
K3891
25.07.2009 23:24:48
Zyxel modem-ruuteri logi |
Tere!
Oskab keegi selgitada mis on Zyxel modem-ruuteri logis täpselt kirjas.
Modem-ruuteriks on Zyxel P-660HW-D1
Log:
No. Time Source IP Destination IP Note
1|07/25/2009 02:08:03 | | |
ppp:IPCP Opening
2|07/25/2009 02:08:03 | | |
ppp:IPCP Starting
3|07/25/2009 02:08:03 | | |
ppp:PAP Opening
4|07/25/2009 02:08:02 | | |
ppp:LCP Opening
5|07/25/2009 02:08:02 | | |
ppp:LCP Starting
6|07/25/2009 02:08:02 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1257, C02 OutCall Connected 512000
7|07/25/2009 02:08:02 | | |PACKET TRIGGER
Packet Trigger: Protocol=1, Data=Packet Trigger: Protocol=1, Dat
8|07/25/2009 02:08:02 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1257, C01 Outgoing Call dev=6 ch=0
9|07/25/2009 02:08:02 | | |
ppp:IPCP Closing
10|07/25/2009 02:08:02 | | |
ppp:LCP Closing
11|07/25/2009 02:08:02 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1256, C02 Call Terminated
12|07/25/2009 02:03:42 | | |
ppp:IPCP Opening
13|07/25/2009 02:03:42 | | |
ppp:IPCP Starting
14|07/25/2009 02:03:42 | | |
ppp:PAP Opening
15|07/25/2009 02:03:42 | | |
ppp:LCP Opening
16|07/25/2009 02:03:42 | | |
ppp:LCP Starting
17|07/25/2009 02:03:42 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1256, C02 OutCall Connected 512000
18|07/25/2009 02:03:42 | | |PACKET TRIGGER
19|07/25/2009 02:03:42 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1256, C01 Outgoing Call dev=6 ch=0
20|07/25/2009 02:03:42 | | |
ppp:IPCP Closing
21|07/25/2009 02:03:42 | | |
ppp:LCP Closing
22|07/25/2009 02:03:42 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1253, C02 Call Terminated
23|07/25/2009 00:22:36 | | |
ppp:IPCP Opening
24|07/25/2009 00:22:36 | | |
ppp:IPCP Starting
25|07/25/2009 00:22:36 | | |
ppp:PAP Opening
26|07/25/2009 00:22:36 | | |
ppp:LCP Opening
27|07/25/2009 00:22:36 | | |
ppp:LCP Starting
28|07/25/2009 00:22:36 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1253, C02 OutCall Connected 512000
29|07/25/2009 00:22:34 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1255, C01 Incoming Call 1500000
30|07/25/2009 00:22:32 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1252, C02 Call Terminated
31|07/25/2009 00:22:32 | | |PACKET TRIGGER
32|07/25/2009 00:22:32 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1254, C01 Outgoing Call dev=6 ch=1
33|07/25/2009 00:22:22 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1253, C01 Outgoing Call dev=6 ch=0
34|07/25/2009 00:22:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1252, C01 Incoming Call 1500000
35|07/25/2009 00:22:18 | | |PACKET TRIGGER
36|07/25/2009 00:22:18 | | |PACKET TRIGGER
37|07/25/2009 00:22:18 | | |PACKET TRIGGER
38|07/25/2009 00:22:18 | | |PACKET TRIGGER
39|07/25/2009 00:22:18 | | |PACKET TRIGGER
40|07/25/2009 00:22:18 | | |PACKET TRIGGER
41|07/25/2009 00:22:18 | | |PACKET TRIGGER
42|07/25/2009 00:22:17 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 148, C02 Call Terminated
43|07/25/2009 00:22:17 | | |PACKET TRIGGER
44|07/25/2009 00:22:17 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1251, C01 Outgoing Call dev=6 ch=0
45|07/25/2009 00:22:12 | | |PACKET TRIGGER
46|07/25/2009 00:22:12 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1250, C01 Outgoing Call dev=6 ch=0
47|07/25/2009 00:22:12 | | |
ppp:IPCP Closing
48|07/25/2009 00:22:12 | | |
ppp:LCP Closing
49|07/25/2009 00:22:12 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 150, C02 Call Terminated
50|07/25/2009 00:22:07 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1249, C01 Outgoing Call dev=6 ch=1
51|07/25/2009 00:21:34 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1248, C01 Outgoing Call dev=6 ch=1
52|07/25/2009 00:21:01 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1247, C01 Outgoing Call dev=6 ch=1
53|07/25/2009 00:20:28 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1246, C01 Outgoing Call dev=6 ch=1
54|07/25/2009 00:19:55 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1245, C01 Outgoing Call dev=6 ch=1
55|07/25/2009 00:19:22 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1244, C01 Outgoing Call dev=6 ch=1
56|07/25/2009 00:18:49 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1243, C01 Outgoing Call dev=6 ch=1
57|07/25/2009 00:18:16 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1242, C01 Outgoing Call dev=6 ch=1
58|07/25/2009 00:17:43 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1241, C01 Outgoing Call dev=6 ch=1
59|07/25/2009 00:17:10 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1240, C01 Outgoing Call dev=6 ch=1
60|07/25/2009 00:16:37 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1239, C01 Outgoing Call dev=6 ch=1
61|07/25/2009 00:16:04 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1238, C01 Outgoing Call dev=6 ch=1
62|07/25/2009 00:15:31 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1237, C01 Outgoing Call dev=6 ch=1
63|07/25/2009 00:14:58 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1236, C01 Outgoing Call dev=6 ch=1
64|07/25/2009 00:14:25 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1235, C01 Outgoing Call dev=6 ch=1
65|07/25/2009 00:13:52 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1234, C01 Outgoing Call dev=6 ch=1
66|07/25/2009 00:13:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1233, C01 Outgoing Call dev=6 ch=1
67|07/25/2009 00:12:46 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1232, C01 Outgoing Call dev=6 ch=1
68|07/25/2009 00:12:13 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1231, C01 Outgoing Call dev=6 ch=1
69|07/25/2009 00:11:40 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1230, C01 Outgoing Call dev=6 ch=1
70|07/25/2009 00:11:07 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1229, C01 Outgoing Call dev=6 ch=1
71|07/25/2009 00:10:34 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1228, C01 Outgoing Call dev=6 ch=1
72|07/25/2009 00:10:01 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1227, C01 Outgoing Call dev=6 ch=1
73|07/25/2009 00:09:28 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1226, C01 Outgoing Call dev=6 ch=1
74|07/25/2009 00:08:55 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1225, C01 Outgoing Call dev=6 ch=1
75|07/25/2009 00:08:22 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1224, C01 Outgoing Call dev=6 ch=1
76|07/25/2009 00:07:49 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1223, C01 Outgoing Call dev=6 ch=1
77|07/25/2009 00:07:16 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1222, C01 Outgoing Call dev=6 ch=1
78|07/25/2009 00:06:43 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1221, C01 Outgoing Call dev=6 ch=1
79|07/25/2009 00:06:10 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1220, C01 Outgoing Call dev=6 ch=1
80|07/25/2009 00:05:37 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1219, C01 Outgoing Call dev=6 ch=1
81|07/25/2009 00:05:04 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1218, C01 Outgoing Call dev=6 ch=1
82|07/25/2009 00:04:31 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1217, C01 Outgoing Call dev=6 ch=1
83|07/25/2009 00:03:58 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1216, C01 Outgoing Call dev=6 ch=1
84|07/25/2009 00:03:25 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1215, C01 Outgoing Call dev=6 ch=1
85|07/25/2009 00:02:52 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1214, C01 Outgoing Call dev=6 ch=1
86|07/25/2009 00:02:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1213, C01 Outgoing Call dev=6 ch=1
87|07/25/2009 00:01:46 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1212, C01 Outgoing Call dev=6 ch=1
88|07/25/2009 00:01:13 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1211, C01 Outgoing Call dev=6 ch=1
89|07/25/2009 00:00:40 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1210, C01 Outgoing Call dev=6 ch=1
90|07/25/2009 00:00:07 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 1209, C01 Outgoing Call dev=6 ch=1
End of Logs
1|07/25/2009 23:08:28 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 11, C01 Incoming Call 1500000
2|07/25/2009 23:08:18 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1, C02 Call Terminated
3|07/24/2009 12:38:28 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 2, C02 Call Terminated
4|07/24/2009 12:38:25 | | |
ppp:IPCP Opening
5|07/24/2009 12:38:25 | | |
ppp:IPCP Starting
6|07/24/2009 12:38:25 | | |
ppp:PAP Opening
7|07/24/2009 12:38:25 | | |
ppp:LCP Opening
8|07/24/2009 12:38:25 | | |
ppp:LCP Starting
9|07/24/2009 12:38:25 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 9, C02 OutCall Connected 512
10|07/24/2009 12:38:22 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 10, C01 Outgoing Call dev=6 ch=1
11|07/24/2009 12:38:19 | | |PACKET TRIGGER
12|07/24/2009 12:38:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 9, C01 Outgoing Call dev=6 ch=0
13|07/24/2009 12:38:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 1, call 2, C01 Incoming Call 1500000
14|07/24/2009 12:38:19 | | |CALL DETAIL RECORD
board 0 line 0 channel 0, call 1, C01 Incoming Call 1500000
End of Logs
Mis toimub ruuteriga või liinidega?
_________________ lapsesuu: "kui sa surnud oled, siis ei saa sa ise sellest aru, ainult teistel on raske. samamoodi on siis, kui sa loll oled"
viimati muutis K3891 26.07.2009 11:31:30, muudetud 1 kord |
| Kommentaarid: 60 loe/lisa |
49 |
Pailaps
25.07.2009 23:45:56
Re: Zyxel modem-ruuteri logi |
| KimsSky kirjutas: |
Tere!
Log:
ppp:IPCP Opening
ppp:IPCP Starting
ppp:PAP Opening
ppp:LCP Opening
ppp:LCP Starting
ppp:IPCP Closing
ppp:LCP Closing
ppp:IPCP Opening
ppp:IPCP Starting
ppp:PAP Opening
ppp:LCP Opening
ppp:LCP Starting
ppp:IPCP Closing
ppp:LCP Closing
ppp:IPCP Opening
ppp:IPCP Starting
ppp:PAP Opening
ppp:LCP Opening
ppp:LCP Starting
ppp:IPCP Closing
ppp:LCP Closing
End of Logs
Mis toimub ruuteriga või liinidega? |
ppp sessioon kustub ja algab uuesti, sa näed ühenduse katkemist ja sitta latentsust, torgi oma kohalikku ISPi
show dslstatus && show conn abiks veel mulle
| Kommentaarid: 56 loe/lisa |
52 |
K3891
26.07.2009 11:29:48
ISP on hispaania firma ja ma tõesti ei oska neile hispaania keeles selgekas teha, et nett jamab
Pailaps, mis sa arvad kui laseksin ruuteril ISP emaili postkasti pommitada ruuteri log failidega? Eks nad siis näevad ja uurivad et miks nii? 8)
_________________ lapsesuu: "kui sa surnud oled, siis ei saa sa ise sellest aru, ainult teistel on raske. samamoodi on siis, kui sa loll oled" |
49 |
Pailaps
26.07.2009 12:18:58
Ma arvan, et võid julgelt kirjutada inglise keeles või lasta mõnel kohalikul it-taustaga inimesel ära tõlkida ning kindlasti lisada ruuteri logi faili.
Millegi pärast arvan, et selleks teenusepakkujaks on Telefonica.
52 |
K3891
26.07.2009 13:33:47
Pailaps, sa arvasid täiseti õieti. Hispaania keeles räägivad ainult ja inglise keeles ei taha sinuga keegi suhelda.
Sul omal ka kogemused Telefonica'ga?
49 |
Pailaps
26.07.2009 20:50:59
| KimsSky kirjutas: |
Sul omal ka kogemused Telefonica'ga? |
Jah, on, ei saa paraku avalikustada, mis küsimustega seonduvalt.
Suvaline hispaanlasest itimees/tehnik/tõlk vms abiks ja kiri Telefonicale. Võid lihtsalt google translate kasutades kirjutada vingukirja, et krt nett jebib, tulge vaadake ja tehke korda.
Ruuteri logid neid ei koti, vaevalt keegi neid lugedagi viitsib.
52 |
