22.07.2009 11:55:18
Intel Delivers Industrys First 34-Nanometer NAND Flash Solid-State Drives; Advancement Lowers Prices by Up to 60 Percent |
link :: Intel
Intelilt siis esimesed 34nm tehnoloogiaga NAND SSD välkmälu seadmed, hinnad peaks alanema kuni 60%, Intel pressiteade ->
SANTA CLARA, Calif., July 21, 2009 Intel Corporation is moving to a more advanced, 34- nanometer (nm) manufacturing process for its leading NAND flash-based Solid State Drive (SSD) products, which are an alternative to a computers hard drive. The move to 34nm will help lower prices of the SSDs up to 60 percent for PC and laptop makers and consumers who buy them due to the reduced die size and advanced engineering design.
The multi-level cell (MLC) Intel® X25-M Mainstream SATA SSD is aimed at laptop and desktop PCs and available in 80 Gigabyte (GB) and 160GB versions. SSDs are data storage devices found inside computers. Because SSDs have no moving parts they offer faster performance and greater energy efficiency and durability than traditional hard disk drives (HDDs). A draw for gamers, media creators and technology enthusiasts, SSDs have also played a key role in the emergence of ultra-thin and light notebook PCs that are becoming increasingly popular due to their design, size and longer battery life.
Our goal was to not only be first to achieve 34nm NAND flash memory lithography, but to do so with the same or better performance than our 50nm version, said Randy Wilhelm, Intel vice president and general manager, Intel NAND Solutions Group. We made quite an impact with our breakthrough SSDs last year, and by delivering the same or even better performance with todays new products, our customers, both consumers and manufacturers, can now enjoy them at a fraction of the cost.
The Intel X25-M on 34nm flash memory is drop-in compatible with the current 50nm version and will continue to be drop-in compatible to replace existing hard disk drives (HDDs).
Compared to its previous 50nm version, the new Intel X25-M offers improved latency and faster random write Input/Output Operations Per Second (IOPS). Specifically, Intels new SSD provides a 25 percent reduction in latency, for quicker access to data, operating at 65-microsecond latency compared to approximately 4,000 microseconds for an HDD.
Random write performance increases twofold, further separating the X25-M from other competing SSDs. By delivering up to 6,600 4KB write IOPS and up to 35,000 read IOPS, the X25-M continues to set the bar for SSDs, while leapfrogging HDDs which only operate at several hundred IOPS. This provides for markedly faster system and application responsiveness. These improvements in latency and IOPS not only benefit desktop and notebook users, but also server and workstation users, as they utilize Intels cost-effective, yet performance-oriented, MLC SSDs for enterprise computing.
New channel prices for the X25-M 80GB are $225 for quantities up to 1,000 units (a 60 percent reduction from the original introduction price of $595 a year ago). The 160GB version is $440 (down from $945 at introduction) for quantities up to 1,000 units. The X25-M comes in a standard 2.5-inch form factor. The X18-M, in a 1.8-inch form factor, will begin shipping on 34nm later in the quarter.
Drop-in compatible with SATA-based HDDs and all operating systems, the X25-M will also support Microsoft Windows 7 when it becomes available. At that time, Intel plans to deliver a firmware update to allow support of the Windows 7 Trim command, along with an end user tool, to allow users to optimize the performance of their SSD on Windows XP and Vista operating systems.
For further information on Intels High Performance line of solid-state drives, including the Intel X25-M Mainstream and the Intel® X25-E Extreme SATA SSD targeted for server, workstation and enterprise storage applications, visit www.intel.com/go/ssd
Intel [NASDAQ: INTC], the world leader in silicon innovation, develops technologies, products and initiatives to continually advance how people work and live. Additional information about Intel is available at www.intel.com/pressroom and blogs.intel.com
_________________ HV-s ID-kaardiga autentimine
HV valuutakursid |
7 :: |
360 |
| Kommentaarid: 92 loe/lisa |
7 :: |
360 |
ufo56
22.07.2009 15:49:13
Maximum Sustained Read and Write Bandwidth
Access Type MB/s
Sequential Read up to 250
Sequential Write up to 170
Lae pildid -> pilt.io |
| Kommentaarid: 78 loe/lisa |
67 |
otipoiss
22.07.2009 20:05:52
| Mis hetkel üldse sellised mõistlikud SSD kettad on, millel hind ja omadused paigas?
| Kommentaarid: 14 loe/lisa |
14 |
wrx123
22.07.2009 20:08:10
| SIIN on üks asjalik artikkel inteli SSD teisest põlvkonnast.
| Kommentaarid: 17 loe/lisa |
16 |
ufo56
67 |
HighEnd
24.07.2009 12:44:59
hind võiks veel sama palju alla minna siis juba ostaks
| Kommentaarid: 11 loe/lisa |
10 |
ihvike
24.07.2009 13:03:10
| Järgmise aasta lõpp-ülejärgmise algus, siis peaks 320 giga vast nii 3 poole 4 kiloga kätte saama. Siis on paras aeg rongile hüpata.
| Kommentaarid: 12 loe/lisa |
12 |
oncleuno
| Kommentaarid: 34 loe/lisa |
33 |
