praegune kellaaeg 18.11.2026 01:38:35
wrx123
09.07.2009 13:08:47
Probleem VBA-ga |
Teen ühte macrot exceli jaoks ja tekkis arusaamatu probleem if lausega.
Viga selles, et peale if tingimust täidab ainult esimese rea ja kaks ülejäänut jäävad puutumata.
If range1.Cells(2 * range1ColCount + range1ColCount * (i - 1)) > rangeTul.Cells(j + rangeTulColCount * (j - 1) + 2) Then
rangeTul.Cells(j + rangeTulColCount * (j - 1) + 2) = range1.Cells(2 * range1ColCount + range1ColCount * (i - 1))
counter1 = counter1 + 1
MsgBox "i = " & i & " counter1 = " & counter1 & ""
End If |
Ma tean kindlalt, et programmi töös saab see tingimus mitu korda täidetud, aga counter ei suurene ja msgbox-i ei ilmu kordagi. Ehk keegi märkab mingit viga, mida minu silm ei näe.
terve sub:
Sub Vordlus(RowCount, RowCountTul, range1, rangeTul, range1ColCount, rangeTulColCount)
Dim i, j, counter1 As Integer
counter1 = 0
For i = 1 To RowCount 'liigub edasi sisestatavate andmete lahtrites
For j = 1 To RowCountTul 'liigub edasi edetabeli lahtrites
If j = 1 Then
If range1.Cells(range1ColCount + range1ColCount * (i - 1) + 2) = rangeTul.Cells(j + rangeTulColCount * (j - 1) + 1) Then
If range1.Cells(range1ColCount + range1ColCount * (i - 1) + 1) = rangeTul.Cells(j + rangeTulColCount * (j - 1)) Then
End If
End If
End If
Else
If range1.Cells(range1ColCount + range1ColCount * (i - 1) + 2) = rangeTul.Cells(1 + rangeTulColCount * (j - 1) + 1) Then
If range1.Cells(range1ColCount + range1ColCount * (i - 1) + 1) = rangeTul.Cells(1 + rangeTulColCount * (j - 1)) Then
If range1.Cells(2 * range1ColCount + range1ColCount * (i - 1)) > rangeTul.Cells(1 + rangeTulColCount * (j - 1) + 2) Then
rangeTul.Cells(1 + rangeTulColCount * (j - 1) + 2) = range1.Cells(2 * range1ColCount + range1ColCount * (i - 1))
End If
End If
End If
End If
Next j
If counter1 < i Then
rangeTul.Cells(1).Activate
ActiveCell.Offset(RowCountTul, 0).Select
ActiveCell.Value = range1.Cells(range1ColCount + range1ColCount * (i - 1) + 1)
ActiveCell.Offset(0, 1).Select
ActiveCell.Value = range1.Cells(range1ColCount + range1ColCount * (i - 1) + 2)
ActiveCell.Value = range1.Cells(2 * range1ColCount + range1ColCount * (i - 1))
'counter1 = counter1 + 1
End If
Next i
End Sub |
| Kommentaarid: 17 loe/lisa |
16 |
Le Inc
10.07.2009 10:10:20
| Kust saab RowCount oma väärtuse?
| Kommentaarid: 56 loe/lisa |
54 |
wrx123
10.07.2009 19:11:48
Üks teine funktsioon kutsub vordluse välja ja annab väärtused kaasa.
| Sub Vordlus(RowCount, RowCountTul, range1, rangeTul, range1ColCount, rangeTulColCount) |
16 |
Le Inc
13.07.2009 09:00:52
| Vaata F8 sammhaaval miks ta IF lauset ei täida, võimalik et väärtused mida ta saab on valed. Hiirega peale liikudes näed ka muutujate väärtusi. Üldjuhul arvuti ei eksi .. probleem peab kuskil mujal olema.
54 |
