praegune kellaaeg 09.11.2026 03:35:48
solution
11.06.2009 22:40:24
Probleem DVD+R DL kirjutamisega, NEC ND-6650A kirjutajaga |
Tere taas
Mure järgmine, ostsin täna omale posu "Platinumi" DVD+R DL plaate, kuid kahjuks ei suuda minu kirjutaja kuidagi nendele midagi kirjutada Kirjutamiseks kasutan Nero 7, ultra editioni. Ning saan veateate "Could not perform start of Disc-at-once" samuti näitab iga plaadi suuruseid erinevaid. Netist lugedes tundub, et ehk on kirjutajal vana firmware?
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder: <_NEC DVD+-RW ND-6650A> Version: 102C - HA 1 TA 0 - 7.10.1.0
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD+-RW ND-6650A>Version: 102C - HA 1 TA 0 - 7.10.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD+-RW ND-6650A atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG HD080HJ/P atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD+-RW ND-6650A D: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1014MB (1038404kB)
Free physical memory: 393MB (402720kB)
Memory in use : 61 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
11.6.2009
Burn DVD Image
22:45:40 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
22:45:40 #2 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x40
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 7645116416
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name:
22:45:40 #3 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
22:45:40 #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3732966 (829:32.66, 7290MB)
22:45:40 #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
22:45:40 #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: _NEC DVD+-RW ND-6650A, Media type: DVD+R9 Double Layer
22:45:40 #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
22:45:40 #8 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 3732967 (3732967) = #3732967/829:32.67
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3732967 blocks [D: _NEC DVD+-RW ND-6650A]
22:45:40 #9 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: _NEC DVD+-RW ND-6650A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7645116416, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3732967 | 0 | 0x00
3732967 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
22:45:40 #10 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
22:45:40 #11 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
22:45:40 #12 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
22:45:40 #13 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
22:45:40 #14 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
22:45:40 #15 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11 080 KB/s)
22:45:41 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
22:45:41 #17 Text 0 File DVDPlusDualLayer.cpp, Line 494
Disc finalized, LBA total Image size: 3732967 (7290MB), Last LBA L0: 1866495 (3645MB)
22:45:44 #18 SPTI -1093 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1093)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0xBF 00 00 00 00 00 00 20 00 0C 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 02
Buffer x06534d80: Len xc
0x00 0A 00 00 00 00 00 00 00 1C 7B 00
22:45:44 #19 Text 0 File DVDPlusDualLayer.cpp, Line 670
L0 Data Zone Capacity not set.
Max LBA L0 2086911 (1FD7FFh, 4075MB), next writable address 0 (0h, 0MB)
22:45:44 #20 CDR -1093 File ThreadedTransferInterface.cpp, Line 1752
No seek complete
22:45:44 #21 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1752
22:45:44 #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
22:45:44 #23 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11 080 KB/s)
22:45:44 #24 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:45:48 #25 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
22:45:48 #26 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
| Kommentaarid: 51 loe/lisa |
41 |
Märt.
12.06.2009 13:01:32
NECiga soovitaks kasutada Verbatimi. Selles koostöös pole ei plaadi ega kribaja süül ühtegi tuksi läinud (tihendi pärast küll 8) ).
| Kommentaarid: 29 loe/lisa |
23 |
solution
12.06.2009 20:25:50
| udusiil kirjutas: |
| NECiga soovitaks kasutada Verbatimi. Selles koostöös pole ei plaadi ega kribaja süül ühtegi tuksi läinud (tihendi pärast küll 8) ). |
Ostsin täna Verbatimid, kõik töötab
41 |
Artur R.
15.06.2009 09:16:30
| Mul on sama seis HL-DT-ST DVD-RW GWA-4163B kirjutaja (LG oem toode Fujitsu Siemensile) ja Philipsi DVD+R DL toorikuga...
| Kommentaarid: 94 loe/lisa |
85 |
