Lukksepp
03.06.2009 16:00:48
BIOS-i update keeras pekki? appi! Korras! |
tegin dfi nf4-d bios update, võtsin proge mis kodukal soovitas ja tegin õpetuse järgi, kõik läks hästi nii kaua kui tahtis resa saada, peale resa enam üless ei tule. power led vilgub, dvd rommid ka vilguvad. krt ma ei tea mis saab?
Äkki keegi oskab aidata?
viimati muutis Lukksepp 03.06.2009 17:17:05, muudetud 1 kord |
96 |
Ramm
03.06.2009 16:14:28
| uus arvuti..muu ei aita..
| Kommentaarid: 19 loe/lisa |
19 |
Lukksepp
03.06.2009 16:15:56
| et siis platte on pekkkis?
96 |
ceemic
24/7@kalal
322 |
Lukksepp
03.06.2009 16:20:25
| proovisin juba, võtsin bataka välja ja panin tagasi.
96 |
A.S.
03.06.2009 16:24:22
Väike copy -> paste ühest pdf failist
RECOVERING A CORRUPT AWARD BOOTBLOCK BIOS
With AWARD BIOS the process is similar but still a bit different. To recover an AWARD BIOS you
will need to create a floppy diskette with a working BIOS file in .BIN format, an AWARD flash
utility and an AUTOEXEC.BAT file. AWARD BIOS will not automatically restore the BIOS
information to the SYSTEM BLOCK for this reason you will need to add the commands necessary
to flash the BIOS to the AUTOEXEC.BAT file. The system will run the AUTOEXE.BAT file at
startup, which will in turn flash the BIOS. This is fairly easy. Here are the steps you need to take.
1) Create a bootable floppy disk. If you use Windows 95, 98 or DOS, this can be done by
going to the DOS prompt and typing the command. (Be sure to insert a disk first)
FORMAT A: /S
The /S switch specifies that the system files should be copied to the diskette to make it
bootable. If you are using Windows ME, Windows NT or Windows 2000 then you can not
use the /S switch with the FORMAT command. If you are unable to create a bootable
diskette because of the operating system you are using then you may download a
bootable diskette image from the BootDisk.com web site at (http://www.bootdisk.com)
2) Copy a working BIOS ROM (.BIN) file for your motherboard and an AWARD flash utility
to the floppy disk. You can usually download these files from the motherboard
manufacturer. If you need help finding these files call the motherboard manufacturer for
technical support.
3) Use a text editor or the edit command at the DOS prompt to create a text file named
AUTOEXEC.BAT and save it on the floppy disk. Make sure that the file name is
AUTOEXEC and that the extension is .BAT (nothing else). If you create this file from
RECOVERING A CORRUPT AWARD BOOTBLOCK BIOS (Cont.)
4) within Windows using a program such as NOTEPAD, you may need to change the file
extension from .TXT to .BAT
5) With the text editor add the following commands to the AUTOEXEC.BAT file on the
floppy disk and then save the changes.
@ECHO OFF
@AWDFLASH BIOSFILE.BIN /py
NOTE: The /py switch will cause the flash utility to automatically reprogram the BIOS
without any user intervention. Be sure to change the AWDFLASH to the name
of the flash utility that you are using and change the BIOSFILE.BIN to the name
of the BIOS ROM file you are using.
If you are not sure what the command line switch to automatically flash your
BIOS is, type the name of the flash utility with the /? switch after it at a DOS
prompt and a list of the available switches will be displayed.
6) Insert the diskette you created into the floppy drive A: on the system that you need to
restore the BIOS on. Turn on the system. The computer should startup, read the floppy
disk, run the commands in the AUTOEXEC.BAT file and restore the BIOS.
At this point if everything went well then the BIOS should have been restored and the
computer should restart normally. If your system still did not restart normally then go to
the TROUBLESHOOTING PROBLEMS section below. |
| Kommentaarid: 34 loe/lisa |
34 |
hashi
03.06.2009 16:43:55
Re: BIOS-i update keeras pekki? appi! |
| Lukksepp kirjutas: |
| tegin bios update.../...peale resa enam üless ei tule.../...krt ma ei tea mis saab? Äkki keegi oskab aidata? |
Heips!
Kunagi ammu, kui päike oli kollasem ja taevas sinisem ning firma nimi oli Tevalo, siis läksin peetis BIOS kiviga neile külla (prääga peaks olema nimeks Elfa Elektroonika AS) ja tehti umbes 100 kronu eest korda.
Võrumaal neil ilmselt "pesa" põle, kuid Tartu peaks sulle ligemal olema, kui Tallinn. Eelnevalt võiksid muidugi nendega kontakteeruda ja täpsemalt järgi uurida. Ühtlasi soovitan emaplaadi tootja kodukalt äärmiselt täpne BIOS otsida(mark, mudel, rev number jne) ning see mälu-kepikesel kaasa võtta, kui Elfa tehnikutega kokkuleppele saad. Kui sa BIOS-i kivi emaplaadilt maha ei saa, siis võta plate kindlasti ka kaasa
Vaevalt, et keegi foorumist "kaug-juhtimise" teel su BIOS-i korda oskab-suudab teha. Mõningate kuulduste kohaselt saavat graafikakaardi abil nässus BIOS-i üle kirjutada, kuid minul sellekohased kogemused puuduvad. Võid foorumi arhiivist ise otsida täpsemaid juht-nööre.
Jõudu tööle!
_________________ Seniks...
Hashi |
| Kommentaarid: 32 loe/lisa |
30 |
A.S.
03.06.2009 17:02:19
Vanasti oli jah asi keerulisem. Tänapäeval on juba enamasti sellega arvestatud, et suvaline tegelane üritab Windowsi all BIOS'i uuendada, pärast veidi nutab ja tahab emaplaadi jälle tööle saada. Näiteks minu arvutile annad sellisel juhul CD plaadi või disketi (kui seade oleks) kätte, kus peal siis õige nimega fail. Ülejäänu teeb arvuti ise.
34 |
Lukksepp
03.06.2009 17:14:49
uhhhhh mega hea, sain ikka lõpuks asja käima. Kuidas käima sain? Kakkusin kõik juhtmed küljest ära ja tegin siin clearmos ja opaaa:D käivitusgi. läks kuidagi vigaselt üless aga sain käima asja lõpuks.
Suured tänud kes aitasid mind sell kriitilisel momendil! Olen päris palju lugenud kuidas keegi on omal tahtnud biosi updateida ja on ka samamoodi pekki läinud, neil veits kurvemalt, biosi kivi oli altvedanud! Aga jah kõigle kes aitasid
96 |
