Satakas
06.09.2009 10:24:37
Universaalset skänneri softi? |
Minu HP Scanjet G3010 soft keeldub Win7 all töötamast (kodukalt kah ei saa) - karjub vaid installimise ajal, et vale opsüsteem on mul. Seetõttu on mul nüüd skännimine pehmelt öeldes raskendatud. Ei, skänner ise töötab ja skännib, aga see toimub ainult ühe pildi haaval ja ma ei saa valida ka mingeid lisafunktsioone (näiteks slaidivalgustamist, mitme pildi eristamist jmt).
Mõtlesin, et äkki on liikvel ka mingeid universaalseid skännerisofte, mis need funktsioonid enda kanda võtaks? Oskab ehk keegi soovitada?
time123
06.09.2009 10:52:55
HP sucks so they are not providing Vista drivers for the 3400c scanner (and most older products). Here is a workaround. It absolutely works for my Scanjet 3400c scanner and may for many other types. Buttons on scanner no longer work but at least you can scan something and not have to buy a new scanner (as HP suggests).
1. If your scanner is connected to your computer (USB) uninstall it using the device manager, be sure to check the box that says "delete the driver." Unplug the USB when it is uninstalled.
2. Download the sj652 installer packaged from HP. http://h10025.www1.hp.com/ewfrf/wc/softwar...228&lang=en
Extract it to a folder.
3. Select the "setup" app and right click on it to get properties. Change the compatibility to XP. Then run it and click "OK" on any warnings from Vista.
4. Now, go to the HP folder in your Program Files directory, there will be a "HP PrecisionScan" folder. It will be the only one unless you have other HP products. Open the PrecisionScan LTX folder and change all apps to XP compatibility.
5. Plug in your scanner via USB and let it install.
The scanner will now work using the LTX software installed on your computer. Like I said, the buttons on the front do not work, and you can't do anything with it by going to "scanners and cameras" in your control panel. Windows Fax and Scan also does not work. BUT, it seems to work great and all the functionality is there in the LTX software.
Obviously HP sees the release of Vista as an excuse for a cash grab and assumes everyone will buy a new product from them (as if). HP also suggests that you donate or recycle your old scanner. Why didn't I think of that?!?! I just love trashing a perfectly good scanner and shelling out more money... to HP they presume. Screw HP! Boycott HP! As god is my witness, I will never buy another frickin' HP product as long as I live! thmbdn.gif |
Kasulike näpunäidete alla tegin sellest ka teema, aga enam seda üles leida ei õnnestu.
| Kommentaarid: 205 loe/lisa |
180 |
Satakas
06.09.2009 11:13:34
| Tänan, aga see pole vist päris selle mure rohi. Mul skänneri nupud töötavad, draiver on peal ja puha. Skännida kah saab, aga ainult ükshaaval, ilma lisaoptsioonideta (no pildiparameetreid ikka saab kah valida) ja peale igast skännimist peab selle uuesti käima panema. Puudu on aga see asi: link - suurem vidin (Varem, Vista all töötas probleemideta), mis erinevat mängimist võimaldab. Noh, nagu näiteks ABBY softis, mis omast tarkusest võimaldab järjest skännida, automaatselt jnejne.
time123
06.09.2009 11:26:26
| Aga selle vidina installeerimisel on ehk eelnimetet nippidest abi?
180 |
Satakas
06.09.2009 11:33:15
Võib ju proovida...ehkki see jutt, nii palju kui ma aru saan, kehtib siiski skännerile üleüldise eluvaimu sissepuhumiseks. Mul aga probleem rohkem selles, et mitte draiver vad suht tavaline proge keeldub opsüsteemi all töötamas
kaspar00
102 |
Satakas
06.09.2009 13:40:16
| Ma siin jah püüangi juba pool päeva leida, milline neist parim on, et sis mida osta jne. silma on jäänud see silverfast ja vuescan. Kahjuks ei oska vue kohta trialversiooni põhjal midagi arvata ja silverit pole veel kätte saanud...
09.09.2009 18:41:15
vuescan on vägagi 5+. samas ka suht keeruline (vähemalt siis kui ma ca 4a tagasi teda kasutasin)
Aga proovi nt. seda - http://icopy.sourceforge.net/?page_id=72
160 |
Satakas
18.04.2010 17:11:29
| märgin igaks juhuks ära, et HP G3010 jaoks on nüüd täiesti töötav ja pädev win7 (32/64) soft olemas.
