praegune kellaaeg 25.09.2026 04:44:33
d-scorpion
22.05.2009 19:26:09
Probleem driveritega (Mobile Intel Pentium M 775) |
Tere selline mure, et ei leia läptopile drivereid, puudu on video ja helikaardi omad.
Äkki keegi oskaks aidata?
Everesti report
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Report Wizard
Computer TEETPEET
Generator teet
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP Retail)
Date 2009-05-22
Time 19:19
--------[ Summary ]-----------------------------------------------------------------------------------------------------
Computer:
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name TEETPEET
User Name teet
Motherboard:
CPU Type Mobile Intel Pentium M 755, 2000 MHz (20 x 100)
Motherboard Name Intel Corporation Alviso
Motherboard Chipset Intel Alviso-G i915GM
System Memory 1015 MB (DDR2-533 DDR2 SDRAM)
BIOS Type Insyde (07/12/04)
Display:
Video Adapter Intel GMA 900
3D Accelerator Intel GMA 900
Multimedia:
Audio Adapter Intel 82801FBM ICH6-M - AC'97 Audio Controller [B-2]
Storage:
IDE Controller Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Disk Drive SAMSUNG HM120JC (111 GB, IDE)
Disk Drive USB2.0 (FS) FLASH DISK USB Device (243 MB, USB)
Optical Drive TSSTcorp CD/DVDW SN-S082D
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 114463 MB (111814 MB free)
Input:
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse PS/2 Compatible Mouse
Network:
Network Adapter Realtek RTL8139 Family PCI Fast Ethernet NIC
Peripherals:
USB1 Controller Intel 82801FBM ICH6-M - USB Universal Host Controller [B-2]
USB2 Controller Intel 82801FBM ICH6-M - Enhanced USB2 Controller [B-2]
USB Device USB Mass Storage Device
Battery Microsoft AC Adapter
Battery Microsoft ACPI-Compliant Control Method Battery
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Vendor Insyde Software Corporation
Version 1.01A
Release Date 04/25/2006
Size 512 KB
Boot Devices Floppy Disk, Hard Disk, CD-ROM
Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS, Smart Battery
Supported Standards DMI, ACPI, PnP
Expansion Capabilities ISA, PCI, AGP, PCMCIA, USB
[ System ]
System Properties:
Manufacturer COMPAL
Product IAL55
Universal Unique ID C949FB35-F23811DA-BCB40016-D412850B
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Manufacturer Intel Corporation
Product Alviso
Version V1.0
[ Chassis ]
Chassis Properties:
Manufacturer COMPAL
Chassis Type Notebook
Boot-Up State Safe
Power Supply State Safe
Thermal State Safe
Security Status None
[ Processors / Processor #1 ]
Processor Properties:
Manufacturer GenuineIntel
External Clock 133 MHz
Maximum Clock 2000 MHz
Current Clock 2000 MHz
Type Central Processor
Voltage 2.9 V
Status Enabled
Upgrade None
Socket Designation JCPU1A
[ Caches / L1 Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 32 KB
Installed Size 32 KB
Supported SRAM Type Asynchronous, Burst, Pipeline Burst
Current SRAM Type Burst
Error Correction None
Socket Designation L1 Cache
[ Caches / L2 Cache ]
Cache Properties:
Type Internal
Status Enabled
Maximum Size 2048 KB
Installed Size 2048 KB
Socket Designation L2 Cache
[ Memory Devices / DRAM Slot 0 ]
Memory Device Properties:
Form Factor SO-DIMM
Type Detail Synchronous
Size 1024 MB
Speed 400 MHz
Total Width 64-bit
Data Width 64-bit
Device Locator DRAM Slot 0
Bank Locator Banks 0/1
[ Memory Devices / DRAM Slot 1 ]
Form Factor SO-DIMM
Total Width 64-bit
Data Width 64-bit
Device Locator DRAM Slot 1
Bank Locator Banks 2/3
[ System Slots / PCMCIA Slot ]
System Slot Properties:
Slot Designation PCMCIA Slot
Type PC Card (PCMCIA)
Data Bus Width 32-bit
Length Long
[ Port Connectors / SVGA-Out ]
Port Connector Properties:
Port Type Video Port
Internal Reference Designator JCRT1
Internal Connector Type None
External Reference Designator SVGA-Out
External Connector Type DB-15 pin female
[ Port Connectors / 1394 ]
Port Type FireWire (IEEE P1394)
Internal Reference Designator J1394A1
External Reference Designator 1394
External Connector Type 1394
[ Port Connectors / MICPHONE ]
Port Type MIDI Port
Internal Reference Designator JMIC1
External Reference Designator MICPHONE
[ Port Connectors / HEADPHONE ]
Port Type MIDI Port
Internal Reference Designator JHP1
External Reference Designator HEADPHONE
[ On-Board Devices / VGA Controller ]
On-Board Device Properties:
Description VGA Controller
[ On-Board Devices / 10/100M Ethernet Controller ]
Description 10/100M Ethernet Controller
[ On-Board Devices / AC97 Codec Controller ]
Description AC97 Codec Controller
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Dothan
CPU Stepping B1
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) M processor 2.00GHz
CPUID Revision 000006D6h
Core Voltage 1.340 V
CPU Speed:
CPU Clock 1994.83 MHz (original: 2000 MHz)
CPU Multiplier 20.0x
CPU FSB 99.74 MHz (original: 100 MHz)
Memory Bus 199.48 MHz
CPU Cache:
L1 Code Cache 32 KB
L1 Data Cache 32 KB
L2 Cache 2 MB (On-Die, ATC, Full-Speed)
Motherboard ID <DMI>
Chipset Properties:
Memory Timings 4-3-3-9 (CL-RCD-RP-RAS)
SPD Memory Modules:
DIMM1 1 GB DDR2-533 DDR2 SDRAM (5.0-4-4-12 @ 266 MHz) (4.0-4-4-12 @ 266 MHz) (3.0-3-3-9 @ 200 MHz)
BIOS Properties:
System BIOS Date 07/12/04
Video BIOS Date 10/21/20
DMI BIOS Version 1.01A
Graphics Processor Properties:
Video Adapter Intel 82915GM Graphics Controller 0
GPU Code Name Alviso-GM (Integrated 8086 / 2592, Rev 04)
--------[ Power Management ]--------------------------------------------------------------------------------------------
Power Management Properties:
Current Power Source AC Line
Battery Status 77 % (High Level, Charging)
Full Battery Lifetime Unknown
Remaining Battery Lifetime Unknown
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensor Properties:
Sensor Type HDD
Temperatures:
SAMSUNG HM120JC 29 °C (84 °F)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Alias Dothan
CPU Stepping B1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 2000 MHz
L1 Code Cache 32 KB
L1 Data Cache 32 KB
CPU Physical Info:
Package Type 479 Ball uFCBGA / 478 Pin uFCPGA
Transistors 140 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 88 mm2
Core Voltage 0.988 - 1.340 V
I/O Voltage 0.988 - 1.340 V
Typical Power 3.0 - 21.0 W (depending on clock speed)
Maximum Power 3.3 - 28.1 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
IA Brand ID 16h (Intel Pentium M)
Platform ID 06h (Mobile uPGA2)
IA CPU Serial Number Unknown
Microcode Update Revision 17
HTT / CMP Units 0 / 0
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
MONITOR / MWAIT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Supported, Enabled
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
36-bit Page Size Extension Not Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
CPUID Registers (CPU #1):
CPUID 00000000 00000002-756E6547-6C65746E-49656E69
CPUID 00000001 000006D6-00000816-00000180-AFE9FBBF
CPUID 00000002 02B3B001-000000F0-00000000-2C04307D
CPUID 80000000 80000004-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-00000000
CPUID 80000002 20202020-20202020-65746E49-2952286C
CPUID 80000003 6E655020-6D756974-20295228-7270204D
CPUID 80000004 7365636F-20726F73-30302E32-007A4847
MSR Registers:
MSR 00000017 0014-0000-D024-8A28
MSR 0000002A 0000-0000-4508-0000
MSR 0000008B 0000-0017-0000-0000
MSR 000000CD 0000-0000-0000-0000
MSR 0000011E 0000-0000-0034-272B
MSR 00000198 0612-1428-0600-1428
MSR 00000199 0000-0000-0000-1428
MSR 0000019A 0000-0000-0000-0002
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 0000019D 0000-0000-0000-0612
MSR 000001A0 0000-0000-0011-1488
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Bandwidth 3200 MB/s
Chipset Bus Properties:
Bus Type Intel Direct Media Interface
Motherboard Manufacturer:
Product Information http://www.intel.com/design/motherbd/index.htm
BIOS Download http://www.intel.com/design/motherbd/genbios.htm
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 1015 MB
Used 194 MB
Free 821 MB
Utilization 19 %
Swap Space:
Total 2446 MB
Used 101 MB
Free 2344 MB
Utilization 4 %
Virtual Memory:
Total 3461 MB
Used 295 MB
Free 3165 MB
Utilization 9 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU No
Active No
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: 1 GB DDR2-533 DDR2 SDRAM ]
Memory Module Properties:
Serial Number None
Manufacture Date Week 48 / 2006
Module Size 1024 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR2 SDRAM
Memory Speed DDR2-533 (266 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 266 MHz 5.0-4-4-12 (CL-RCD-RP-RAS)
@ 266 MHz 4.0-4-4-12 (CL-RCD-RP-RAS)
@ 200 MHz 3.0-3-3-9 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Not Supported
Redundant Row Address Not Supported
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Alviso-G i915GM ]
North Bridge Properties:
North Bridge Intel Alviso-G i915GM
Revision 04
Package Type 1210 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
Memory Timings:
CAS Latency (CL) 4T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 9T
Error Correction:
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 1024 MB (DDR2-533 DDR2 SDRAM)
Integrated Graphics Controller:
Graphics Controller Type Intel GMA 900
Graphics Controller Status Enabled
Graphics Frame Buffer Size 8 MB
Chipset Manufacturer:
Product Information http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm
[ South Bridge: Intel 82801FBM ICH6-M ]
South Bridge Properties:
South Bridge Intel 82801FBM ICH6-M
Revision / Stepping D4 / B2
Package Type 609 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
AC'97 Audio Controller:
Audio Controller Type Intel 82801FB(M) ICH6
Codec Name Avance Logic ALC250
Codec ID 414C4752h
S/PDIF Output Supported
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Insyde
BIOS Manufacturer:
Company Name Insyde Technology, Inc.
Product Information http://www.insydetech.com/products/products-bios.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Problems & Suggestions:
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Suggestion System BIOS is more than 2 years old. Update it if necessary.
--------[ PCI / AGP Video ]---------------------------------------------------------------------------------------------
Intel GMA 900 Video Adapter
Intel GMA 900 3D Accelerator
--------[ GPU ]---------------------------------------------------------------------------------------------------------
[ Integrated: Intel 82915GM Graphics Controller 0 ]
PCI Device 8086 / 2592
Bus Type Integrated
RAMDAC Clock 400 MHz
Pixel Pipelines 4
TMU Per Pipeline 1
Vertex Shaders 1 (v2.0)
Pixel Shaders 1 (v2.0)
DirectX Hardware Support DirectX v9.0
Graphics Processor Manufacturer:
Driver Download http://support.intel.com/support/graphics
--------[ Desktop ]-----------------------------------------------------------------------------------------------------
Desktop Properties:
Device Technology Raster Display
Resolution 1024 x 768
Color Depth 32-bit
Color Planes 1
Font Resolution 96 dpi
Pixel Width / Height 36 / 36
Pixel Diagonal 51
Vertical Refresh Rate Default
Desktop Wallpaper C:\WINDOWS\web\wallpaper\Bliss.bmp
Desktop Effects:
Combo-Box Animation Enabled
Drop Shadow Effect Enabled
Flat Menu Effect Enabled
Font Smoothing Enabled
Full Window Dragging Enabled
Gradient Window Title Bars Enabled
Hide Menu Access Keys Enabled
Hot Tracking Effect Enabled
Icon Title Wrapping Enabled
List-Box Smooth Scrolling Enabled
Menu Animation Enabled
Menu Fade Effect Enabled
Minimize/Restore Animation Enabled
Mouse Cursor Shadow Enabled
Selection Fade Effect Enabled
ShowSounds Accessibility Feature Disabled
ToolTip Animation Enabled
ToolTip Fade Effect Enabled
Windows Plus! Extension Disabled
--------[ Multi-Monitor ]-----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Yes (0,0) (1024,768)
--------[ PCI / PnP Audio ]---------------------------------------------------------------------------------------------
Intel 82801FBM ICH6-M - AC'97 Audio Controller [B-2] PCI
--------[ Windows Storage ]---------------------------------------------------------------------------------------------
[ SAMSUNG HM120JC ]
Device Properties:
Driver Description SAMSUNG HM120JC
Driver Date 7/1/2001
Driver Version 5.1.2535.0
Driver Provider Microsoft
INF File disk.inf
Device Manufacturer:
Company Name Samsung
Product Information http://www.samsung.com/Products/HardDiskDrive/index.htm
[ USB2.0 (FS) FLASH DISK USB Device ]
Device Properties:
Driver Description USB2.0 (FS) FLASH DISK USB Device
INF File disk.inf
[ TSSTcorp CD/DVDW SN-S082D ]
Device Properties:
Driver Description TSSTcorp CD/DVDW SN-S082D
INF File cdrom.inf
[ Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Device Properties:
Driver Description Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Driver Version 5.1.2600.2180
INF File mshdc.inf
Device Resources:
Port 1100-110F
[ Primary IDE Channel ]
Device Properties:
Driver Description Primary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ Secondary IDE Channel ]
Device Properties:
Driver Description Secondary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 15
Port 0170-0177
Port 0376-0376
--------[ Logical Drives ]----------------------------------------------------------------------------------------------
C: Local Disk NTFS 114463 MB 2648 MB 111814 MB 98 % 347F-9B8B
D: Optical Drive
E: Removable Disk FAT 245 MB 46028 KB 200 MB 82 % 446B-A7A0
--------[ Physical Drives ]---------------------------------------------------------------------------------------------
[ Drive #1 - SAMSUNG HM120JC (111 GB) ]
#1 (Active) NTFS C: 0 MB 114463 MB
[ Drive #2 - USB2.0 (FS) FLASH DISK USB Device (243 MB) ]
#1 FAT16 E: 0 MB 245 MB
--------[ Optical Drives ]----------------------------------------------------------------------------------------------
Optical Drive Properties:
Device Description TSSTcorp CD/DVDW SN-S082D
--------[ ASPI ]--------------------------------------------------------------------------------------------------------
00 00 00 Disk Drive SAMSUNG HM120JC
00 01 00 Optical Drive TSSTcorp CD/DVDW SN-S082 D
00 07 00 Host Adapter atapi
--------[ ATA ]---------------------------------------------------------------------------------------------------------
[ SAMSUNG HM120JC (S0A0J10L625525) ]
ATA Device Properties:
Model ID SAMSUNG HM120JC
Serial Number S0A0J10L625525
Revision YL100-13
Parameters 232581 cylinders, 16 heads, 63 sectors per track, 554 bytes per sector
LBA Sectors 234441648
Buffer 8 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 4
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 5 (ATA-100)
Active UDMA Transfer Mode UDMA 5 (ATA-100)
Unformatted Capacity 123864 MB
ATA Device Features:
SMART Supported
Security Mode Supported
Power Management Supported
Advanced Power Management Supported
Write Cache Supported
Host Protected Area Supported
Power-Up In Standby Not Supported
Automatic Acoustic Management Supported
48-bit LBA Supported
Device Configuration Overlay Supported
ATA Device Manufacturer:
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 51 253 70 0 OK: Value is normal
03 Spin Up Time 25 100 100 3008 OK: Value is normal
04 Start/Stop Count 0 99 99 1115 OK: Always passing
05 Reallocated Sector Count 10 60 60 373 OK: Value is normal
07 Seek Error Rate 0 253 253 0 OK: Always passing
08 Seek Time Performance 0 253 253 0 OK: Always passing
09 Power-On Time Count 0 98 98 1410328 OK: Always passing
0A Spin Retry Count 0 253 253 0 OK: Always passing
0C Power Cycle Count 0 100 100 542 OK: Always passing
BF G-Sense Error Rate 0 83 83 173765 OK: Always passing
C0 Power-Off Retract Count 0 253 253 0 OK: Always passing
C2 Temperature 0 151 103 29 OK: Always passing
C3 Hardware ECC Recovered 0 100 100 69650 OK: Always passing
C4 Reallocation Event Count 0 60 60 373 OK: Always passing
C5 Current Pending Sector Count 0 89 89 103 OK: Always passing
C6 Off-Line Uncorrectable Sector Count 0 253 253 0 OK: Always passing
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passing
C8 Write Error Rate 0 253 100 0 OK: Always passing
C9 <vendor-specific> 0 253 253 0 OK: Always passing
DF Load Retry Count 0 100 100 5 OK: Always passing
E1 Load Cycle Count 0 1 1 1012865 OK: Always passing
FF <vendor-specific> 0 253 98 0 OK: Always passing
--------[ Windows Network ]---------------------------------------------------------------------------------------------
[ Realtek RTL8139 Family PCI Fast Ethernet NIC ]
Network Adapter Properties:
Interface Type Ethernet
Hardware Address 00-16-D4-12-85-0B
Connection Name Local Area Connection
Connection Speed 10 Mbps
MTU 1500 bytes
DHCP Lease Obtained 5/22/2009 4:48:38 PM
DHCP Lease Expires 5/22/2009 4:53:38 PM
Bytes Received 0
Bytes Sent 0
Network Adapter Addresses:
DHCP 88.196.48.196
DNS 195.250.187.46
DNS 194.126.101.34
Network Adapter Manufacturer:
Company Name Realtek Semiconductor Corp.
Product Information http://www.realtek.com.tw/products/products1-1.aspx?lineid=1
Driver Download http://www.realtek.com.tw/downloads/downloads1-1.aspx?lineid=1
--------[ PCI / PnP Network ]-------------------------------------------------------------------------------------------
Intel PRO/Wireless 2915ABG Network Connection PCI
Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] PCI
--------[ DirectX Video ]-----------------------------------------------------------------------------------------------
[ Primary Display Driver ]
DirectDraw Device Properties:
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver vga.dll
Hardware Description
--------[ DirectX Sound ]-----------------------------------------------------------------------------------------------
[ Primary Sound Driver ]
DirectSound Device Properties:
Device Description Primary Sound Driver
Driver Module
Primary Buffers 0
Min / Max Secondary Buffers Sample Rate 0 / 0 Hz
Primary Buffers Sound Formats None
Secondary Buffers Sound Formats None
Total / Free Sound Buffers 0 / 0
Total / Free Static Sound Buffers 0 / 0
Total / Free Streaming Sound Buffers 0 / 0
Total / Free 3D Sound Buffers 0 / 0
Total / Free 3D Static Sound Buffers 0 / 0
Total / Free 3D Streaming Sound Buffers 0 / 0
DirectSound Device Features:
Certified Driver No
Emulated Device No
Precise Sample Rate Not Supported
DirectSound3D Not Supported
Creative EAX 1.0 Not Supported
Creative EAX 2.0 Not Supported
Creative EAX 3.0 Not Supported
--------[ DirectX Music ]-----------------------------------------------------------------------------------------------
[ Microsoft Synthesizer ]
DirectMusic Device Properties:
Device Description Microsoft Synthesizer
Synthesizer Type Software
Device Class Output Port
Device Type User-Mode Synthesizer
Audio Channels 2
MIDI Channels 16000
Voices 1000
Available Memory System Memory
DirectMusic Device Features:
Built-In GM Instrument Set No
Built-In Roland GS Sound Set No
DirectSound Supported
DLS L1 Sample Collections Supported
DLS L2 Sample Collections Supported
External MIDI Port No
Fixed DLS Memory Size No
Port Sharing Not Supported
Chorus Effect Not Supported
Delay Effect Not Supported
Reverb Effect Supported
--------[ DirectX Input ]-----------------------------------------------------------------------------------------------
[ Mouse ]
DirectInput Device Properties:
Device Description Mouse
Device Type Unknown
Device Subtype Unknown
Axes 2
Buttons/Keys 2
DirectInput Device Features:
Emulated Device Yes
Alias Device No
Polled Device No
Polled Data Format No
Attack Force Feedback Not Supported
Deadband Force Feedback Not Supported
Fade Force Feedback Not Supported
Saturation Force Feedback Not Supported
+/- Force Feedback Coefficients Not Supported
+/- Force Feedback Saturation Not Supported
[ Keyboard ]
Device Description Keyboard
Device Type Unknown
Buttons/Keys 128
Emulated Device Yes
Alias Device No
Polled Device No
--------[ Windows Devices ]---------------------------------------------------------------------------------------------
[ Devices ]
Batteries:
Microsoft AC Adapter 5.1.2535.0
Microsoft ACPI-Compliant Control Method Battery 5.1.2535.0
Computer:
ACPI Uniprocessor PC 5.1.2600.0
Disk drives:
SAMSUNG HM120JC 5.1.2535.0
USB2.0 (FS) FLASH DISK USB Device 5.1.2535.0
DVD/CD-ROM drives:
TSSTcorp CD/DVDW SN-S082D 5.1.2535.0
IDE ATA/ATAPI controllers:
Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F5.1.2600.2180
Primary IDE Channel 5.1.2600.2180
Secondary IDE Channel 5.1.2600.2180
IEEE 1394 Bus host controllers:
VIA OHCI Compliant IEEE 1394 Host Controller 5.1.2535.0
Keyboards:
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard5.1.2600.2180
Mice and other pointing devices:
PS/2 Compatible Mouse 5.1.2600.0
Network adapters:
1394 Net Adapter 5.1.2535.0
Direct Parallel 5.1.2535.0
Realtek RTL8139 Family PCI Fast Ethernet NIC 5.398.613.2003
Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport5.1.2535.0
WAN Miniport (IP) 5.1.2535.0
WAN Miniport (IP) - Packet Scheduler Miniport 5.1.2535.0
WAN Miniport (L2TP) 5.1.2535.0
WAN Miniport (PPPOE) 5.1.2535.0
WAN Miniport (PPTP) 5.1.2535.0
Non-Plug and Play Drivers:
1394 ARP Client Protocol
AFD
Beep
dmboot
dmload
Fips
Generic Packet Classifier
HTTP
IP Network Address Translator
IPSEC driver
ksecdd
mnmdd
mountmgr
NDIS System Driver
NDIS Usermode I/O Protocol
NDProxy
NetBios over Tcpip
Null
PartMgr
ParVdm
PCIIde
RDPCDD
Remote Access Auto Connection Driver
Remote Access IP ARP Driver
Remote Access NDIS TAPI Driver
Serial
TCP/IP Protocol Driver
VgaSave
VolSnap
Other devices:
Multimedia Audio Controller
Network Controller
PCI FLASH Memory
PCI FLASH Memory
PCI Modem
Video Controller
Video Controller (VGA Compatible)
PCMCIA adapters:
Generic CardBus Controller 5.1.2600.0
Processors:
Intel(R) Pentium(R) M processor 2.00GHz 5.1.2600.0
Secure Digital host controllers:
SDA Standard Compliant SD Host Controller 6.0.4069.1
Sound, video and game controllers:
Audio Codecs 5.1.2535.0
Legacy Audio Drivers 5.1.2535.0
Legacy Video Capture Devices 5.1.2535.0
Media Control Devices 5.1.2535.0
Video Codecs 5.1.2535.0
Storage volumes:
Generic volume 5.1.2600.0
System devices:
ACPI Fixed Feature Button 5.1.2600.2180
ACPI Lid 5.1.2600.2180
ACPI Power Button 5.1.2600.2180
ACPI Sleep Button 5.1.2600.2180
Direct memory access controller 5.1.2600.2180
Intel(R) 82801 PCI Bridge - 2448 5.1.2600.2180
Intel(R) 82801FB/FBM SMBus Controller - 266A 5.1.2600.2180
Intel(R) 82801FBM LPC Interface Controller - 2641 5.1.2600.2180
ISAPNP Read Data Port 5.1.2600.2180
Microcode Update Device 5.1.2600.2180
Microsoft ACPI-Compliant Embedded Controller 5.1.2535.0
Microsoft ACPI-Compliant System 5.1.2535.0
Microsoft Composite Battery 5.1.2535.0
Microsoft System Management BIOS Driver 5.1.2600.2180
Motherboard resources 5.1.2600.2180
Numeric data processor 5.1.2600.2180
PCI bus 5.1.2600.2180
PCI standard host CPU bridge 5.1.2600.2180
Plug and Play Software Device Enumerator 5.1.2600.2180
Programmable interrupt controller 5.1.2600.2180
System CMOS/real time clock 5.1.2600.2180
System timer 5.1.2600.2180
Terminal Server Keyboard Driver 5.1.2600.2180
Terminal Server Mouse Driver 5.1.2600.2180
Volume Manager 5.1.2600.2180
Universal Serial Bus controllers:
Intel(R) 82801FB/FBM USB Universal Host Controller - 26585.1.2600.2180
Intel(R) 82801FB/FBM USB Universal Host Controller - 26595.1.2600.2180
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A5.1.2600.2180
Intel(R) 82801FB/FBM USB Universal Host Controller - 265B5.1.2600.2180
Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C5.1.2600.0
USB Mass Storage Device 5.1.2600.0
USB Root Hub 5.1.2600.2180
[ Batteries / Microsoft AC Adapter ]
Device Properties:
Driver Description Microsoft AC Adapter
INF File battery.inf
Hardware ID ACPI\ACPI0003
[ Batteries / Microsoft ACPI-Compliant Control Method Battery ]
Device Properties:
Driver Description Microsoft ACPI-Compliant Control Method Battery
Hardware ID ACPI\PNP0C0A
PnP Device Control Method Battery
[ Computer / ACPI Uniprocessor PC ]
Device Properties:
Driver Description ACPI Uniprocessor PC
Driver Version 5.1.2600.0
INF File hal.inf
Hardware ID acpiapic_up
[ Disk drives / SAMSUNG HM120JC ]
Device Properties:
INF File disk.inf
Hardware ID IDE\DiskSAMSUNG_HM120JC_________________________YL100-13
Location Information 0
[ Disk drives / USB2.0 (FS) FLASH DISK USB Device ]
Device Properties:
INF File disk.inf
Hardware ID USBSTOR\DiskUSB2.0__(FS)_FLASH_DISK_1.00
[ DVD/CD-ROM drives / TSSTcorp CD/DVDW SN-S082D ]
Device Properties:
INF File cdrom.inf
Hardware ID IDE\CdRomTSSTcorp_CD/DVDW_SN-S082D_______________SS02____
Location Information 1
[ IDE ATA/ATAPI controllers / Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Device Properties:
INF File mshdc.inf
Hardware ID PCI\VEN_8086&DEV_266F&SUBSYS_001214C0&REV_04
Location Information PCI bus 0, device 31, function 1
PCI Device Intel 82801FBM ICH6-M - ATA-100 IDE Controller [B-2]
Device Resources:
Port 1100-110F
[ IDE ATA/ATAPI controllers / Primary IDE Channel ]
Device Properties:
INF File mshdc.inf
Hardware ID Intel-266f
Location Information Primary Channel
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ IDE ATA/ATAPI controllers / Secondary IDE Channel ]
Device Properties:
INF File mshdc.inf
Hardware ID In
ViskeRelv
d-scorpion
22.05.2009 19:53:58
| Tänud, video sai korda aga seal chipseti all ei ole audio drivereid :O või ma ei leia
siLc
d-scorpion
23.05.2009 17:59:16
Suured tänud nüüd kõik korras.
