uus teema   vasta Tarkvara »  Linux & UNIX »  fedora 10 resolutsiooni jama märgi kõik teemad loetuks
kalle78
sõnum 20.05.2009 13:52:46 fedora 10 resolutsiooni jama vasta tsitaadiga
monitor samsung 2243sn , 22" native reso 1920x1080
fedora ise ei tunnista seda resot üldse ja pakub maksimumiks 1440x1050
system-config-display'ga sama jama
mõlemad arvavad,et on tegu 17" monitoriga
proovisin gtf 1920 1080 60 ning editisin xorg.confi
# Xorg configuration created by system-config-display
Section "ServerLayout"
   Identifier     "single head configuration"
   Screen      0  "Screen0" 0 0
   InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "InputDevice"
# keyboard added by rhpxl
   Identifier  "Keyboard0"
   Driver      "kbd"
   Option       "XkbModel" "pc105"
   Option       "XkbLayout" "ee"
EndSection
Section "Monitor"
   [b]# 1920x1080 @ 60.00 Hz (GTF) hsync: 67.08 kHz; pclk: 172.80 MHz
   Identifier   "Monitor0"
   ModeLine     "1920x1080_60.00" 172.8 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync[/b]
EndSection
Section "Device"
   Identifier  "Videocard0"
   Driver      "intel"
EndSection
Section "Screen"
   Identifier "Screen0"
   Device     "Videocard0"
   Monitor    "Monitor0"
   DefaultDepth     24
   SubSection "Display"
      Viewport   0 0
      Depth     24
Modes     "1920x1080_60.00"
   EndSubSection
EndSection
nüüd op annab valida 1920x1080 kuid monitori äärde jäävad paksud mustad triibud, ehk pole full screenis
system-config-display ikka ei tunnista , et tegu on 22" monitoriga, isegi kui muuta seadedid siis need ei salvestu peale x sessioni restarti
Kuidas saada native resoga tööle ?
lspci
[00:00.0 Host bridge: Intel Corporation 82945G/GZ/P/PL Memory Controller Hub (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82945G/GZ Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 01)
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) SATA IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
kaabakas
kaabakas
sõnum 21.05.2009 13:40:24 vasta tsitaadiga
anna /var/log/Xorg.0.log
kalle78
sõnum 21.05.2009 13:57:55 vasta tsitaadiga
viimati muutis kalle78 21.05.2009 16:44:17, muudetud 1 kord
kaabakas
kaabakas
sõnum 21.05.2009 15:20:23 vasta tsitaadiga
See ei näe päris õige välja. Oled kindel et said puhtalt kopitud?
Enivei, taasta esialgne konf, restardi X ja anna uus log. Ja pane logid spoiler tagide vahele, on veidi inimlikum.
kalle78
sõnum 21.05.2009 16:49:59 vasta tsitaadiga
ok,post ületab täheliimiiti . uppisin
kaabakas
kaabakas
sõnum 21.05.2009 19:19:54 vasta tsitaadiga
Paistab et see geenereeritud modeline üritab suruda peale 172.80Mhz pixel clocki aga kaart lubab kuni 160:
(II) intel(0): SDVOB: device VID/DID: 02:C2.02, clock range 25.0MHz - 160.0MHz
Proovi 'gtf 1920 1080 50'
Kasuks võib tulla info: 'get-edid | parse-edid'
kalle78
sõnum 21.05.2009 21:16:52 vasta tsitaadiga
ok editisin xorg.congi gtf 1920 180 50 modeline'ga , nüüd on ekraan piisavalt suur kuid paremale lükatud (monitor ei kannata piisavalt vasakule viia)
kuid get-edid | parse-edid käsk ei funka küll aga monitor-edid
tegelik screen size on 48.0 cm x 27.0 cm
DisplaySize muutmine 380 270 ei muutnud midagi
kaabakas
kaabakas
sõnum 21.05.2009 23:18:26 vasta tsitaadiga
kalle78 kirjutas:
Kas monitoril autoadjust nuppu pole?
Sellel lehel saad modeline muuta, et pilti liigutada. http://www.tkk.fi/Misc/Electronics/faq/vga2rgb/calc.html
kalle78
sõnum 22.05.2009 00:59:25 vasta tsitaadiga
tänan väga,sellega sai enam-vähem paika lükatud , kahtlaselt on pilt liiga lai, et ära mahtuda (paremastäärest on paar millimeetrit ekraani ääre taga)
ning verbose mode boodiga on paljud vasakult sama kogus mis ennem oli musta randiga kaetud , ikka kaetud
sellest autoadjustist niipalju,et ta adjustis küll, aga ainult nende mustade juttide vahel siiski
lõpuks sain
Modeline "1920x1080"   160   1920 2200 2400 2544   1080 1081 1084 1112  -hsync +vsync
kaabakas
kaabakas
sõnum 22.05.2009 01:42:14 vasta tsitaadiga
Sinu modelines tundub see 160 veidi kahtlane, mina alustaks sellisest:
Modeline "1920x1080_50.00" 141.45 1920 2032 2232 2544 1080 1081 1084 1112 -HSync +Vsync
ja sama kaugele vasakule tuunides oleks siis selline:
Modeline "1920x1080_50.00" 141.45 1920 2200 2400 2544 1080_50.00 1081 1084 1112 -hsync +vsync
Lisaks aga, kuna edid ütleb sul monitori bandwidthi kuni 140 olevat siis on võibolla vaja hertsi veel veidi alla ajada. Huvitav kas 49 töötab?
Modeline "1920x1080_49.00" 138.49 1920 2032 2232 2544 1080 1081 1084 1111 -HSync +Vsync
kalle78
sõnum 22.05.2009 11:41:55 vasta tsitaadiga
esimesed kaks töötavad samamoodi nagu gtf 1920 1080 60
esimene paremale lükatud
teises parem äär kaetud sutsu
ja viímast ei võta monitor vastu ja peksab, et optimum range"192x1080 60hz"
küll proovisin Modeline "1920x1080" 140 1920 2200 2400 2544 1080 1081 1084 1112 -hsync +vsync,siis näitas, et töötab 49 hz peal kuid väljanägi sama mis 160'ga
millegi pärast on gtf'i poolt loodud modeline'ga pilt tunduvalt teravam, väiksem kiri jne kui selle leheküljega loodud, nii et tundub, et süntaksi vahe siiski on
kaabakas
kaabakas
sõnum 22.05.2009 16:49:33 vasta tsitaadiga
Võib proovida veel madalama hertsiga, 40 peaks madalamatest standardne olema. Näppida saab veel miinuse ja plussiga rea lõpu poole.
945 datasheet oli üsna hägune resolutsiooni koha pealt, võib juhtuda et ei olegi korralikult toetatud. Sellisel juhul tasuks vaadata kangema kaardi poole.
Igaks juhuks, kui kasutad vga kaablit, kas on võimalus minna üle dvi'le?
kalle78
sõnum 22.05.2009 19:17:37 vasta tsitaadiga
2048x1536 at 75 Hz maximum resolution peaks olema võimalik, vähemalt nii intel kirjutab
kuid kahjuks ei saa kasutada dvi'd väljund vga ja monitoril ainult vga sisend.
monitor ei tunnista 40hz'i kohe üldse, kangem kaart jääb hetkel kahjuks välja ,ma elan üle selle paari kadunud millimeetriga. Kui vaja võin seada 1400 x 1050 , monitor venitab ise paika
