uus teema   vasta Raud »  Rauafoorum »  Error 0x0000009c Kas keegi analüüsiks minidumpi? märgi kõik teemad loetuks
aap14
aap14
sõnum 18.05.2009 02:08:50 Error 0x0000009c Kas keegi analüüsiks minidumpi? vasta tsitaadiga
Tere
Varemgi arvuti siis BSOD-i ette visanud ja Machine_check_exception tekkinud. Tahaks teada, milles asi ja tõenäoliselt on minidumpis vajalik info olemas. Kahjuks ei oska ma seda infot kätte saada.
Windows debuggerile muretsesin sümbolid ja näitasin talle kätte, kus need sümbolid asuvad, kuid ikka viskas mingi errori.
http://www.upload.ee/files/81824/Mini051809-01.dmp.html Siin siis minidump.
Slow is smooth and smooth is fast
sõnum 18.05.2009 04:29:38 vasta tsitaadiga
Alustuseks kontrollid toiteploki yle.
Postitatud mobile device
aap14
aap14
sõnum 18.05.2009 22:58:00 vasta tsitaadiga
Kuidas ma seda kontrollin? Lahti teen, siis lõppeb garantii ju icon_confused.gif
edit: kas keegi analüüsiks minudumpi enne kui see teema liiga kaugele esilehelt liigub, et keegi märkaks?
afex
afex
sõnum 19.05.2009 00:02:35 vasta tsitaadiga
temperatuurid? overclock maha?
Machine check exceptions are frequently caused by one of the following conditions:
* You are running the processor or mainboard beyond its specifications. For example, you are overclocking the processor or bus. We recommend that you run your hardware at the manufacturer-rated speeds.
* Noisy power, overstressed power strips, outmatched power supplies and failing power supplies can destabilize your computer. Make sure that you have a stable, reliable power supply to your computer.
* Extreme thermal conditions caused by the failure of cooling devices such as fans may damage your computer. Make sure that your cooling devices are all working.
* You have damaged memory or memory that is not the correct type for your computer. If you recently changed the memory configuration, revert to the previous configuration to determine what is wrong. Make sure that you are using the correct memory for your computer.
artur-
artur-
sõnum 19.05.2009 00:07:44 vasta tsitaadiga
Kui garantii on siis miks Sa seda garantiisse ei vii?
Kommentaarid: 82 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 72
aap14
aap14
sõnum 19.05.2009 00:22:48 vasta tsitaadiga
artur- kirjutas:
Sest kui garantiisse viin ja välja tuleb, et sellega kõik korras (või kui nad sealsete testimismeetoditega ei koorma asja piisavalt vms.), siis maksan hooldustasu.
Lootsin, et äkki keegi teadjam inimene oskab mingidumpist välja lugeda, milles tõenäoliselt asi on. Machine_check_exception võib ju muidu olla jumal teab millest.
Temperatuurid on kusjuures täitsa normis. Alles hiljuti puhastasin arvuti ära ja sellega pole probleeemi. Prose overclock ei ole varem asja mõjutanud (asi on olnud 3Ghz peal kaua ja nüüd äkki selline probleem).
Toiteplokk on 850W - kui just mingit viga kuskil pole, siis peaks ilusti mu süsteemi välja vedama.
Mäludega on nii, et töötavad hetkel 2.0V peal. Pole neid kuidagi kellanud, kuid võin ju tõsta pinget 0.1V võrra ja vaadata, mis siis juhtub.
Lisainfoks veel niipalju, et arvuti bootimiseks on mul vaja toiteplokk nupuga välja lülitada, oodata umbes 10 sekki, uuest toitekas sisse lülitada ja alles seejärel bootib arvuti normaalselt (käib see piiks käivitamisel). Kui seda protseduuri ei tee, siis piiksu ei tule ja pilti samuti ette mitte. Mina ei tea, kas asi on toitekas, emaplaadis või selles, et mingi juhe on halvasti kuskil joodetud.
Machine_check_exception tuli ette Supreme Commander Forged Alliance-is replaysid vaadates. Peale mingit aega viskas BSOD-i teema kirjelduses mainitud error koodiga.
Aga muidu väga hea - vaikselt hakkan juba mõtlema toiteka garantiisse viimise peale. Samas muidu arvuti töötab perfektselt. Ainult see bootimise protseduur ja nüüd viimasel ajal see BSOD.
Keegi mini-dumpist midagi välja luges?
afex
afex
sõnum 19.05.2009 00:39:07 vasta tsitaadiga
vaevalt et minidump miskit täpsemat ütleb. eriti kui sul masin pärast ülesse ei tule. overclocki võid ju maha võtta, väga lihtne välistada.
muidu jah - toide, emme, video ...
hea oleks POST kaardiga vaadata siis kui masin enam ülesse ei tule, sealt võib-olla annab midagi välja lugeda
aap14
aap14
sõnum 19.05.2009 00:47:32 vasta tsitaadiga
afex kirjutas:
Masin ei tule ilma selle toiteploki protseduurita üles ka siis kui BSOD-i pole varem olnud. See mul juba tavapäraseks muutunud - ei märkagi enam, et seda teen.
Seega overclocki nii kerge päris välistada ei ole.
Piinlik tunnistada, kuid ma ei tea, mida sa selle "POST kaardiga" all mõtlesid icon_redface.gif
afex
afex
sõnum 19.05.2009 00:54:12 vasta tsitaadiga
http://en.wikipedia.org/wiki/POST_card
Noname
Noname
sõnum 19.05.2009 23:10:17 vasta tsitaadiga
minidump näitab 1% juhtudest midagi, eriti kui tegu riistvaralise veaga, sama oleks kui hull inimene endale ise diagnoosi paneks vms
Kommentaarid: 373 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 322
aap14
aap14
sõnum 20.05.2009 11:42:38 vasta tsitaadiga
Kas keegi oskaks mulle näitada, kust saaks neid POST kaarte osta?
Lõin google-isse sisse ja see ei osanud mulle muud näitada kui Postkaarte ja muud asjasse mitte puutuvat icon_lol.gif
Äkki müüb neid keegi siin HV foorumis?
sõnum 20.05.2009 11:46:17 vasta tsitaadiga
post kaardid pole abiks. need ei oska suurt midagi asjalikumat näidata. vanasti müüs .scorps. miskeid kaarte aga need olid BS. toite pärast otseselt masin PSOD i ei anna, kui masin psodi annab toitest tulenevalt, siis saadab toide talle vale voolu aga mingit muud signaali sealt tulla ei saa. kas masin on klokitud kusagilt?
aap14
aap14
sõnum 20.05.2009 11:55:55 vasta tsitaadiga
Prose on kellatud 3Ghz peale @ 1.35V, kuid see peaks olema antud isendi kohta mõõdukas overclock. Temperatuurid on normis - üle 60C ei kipu minema.
Videokaardi temperatuur on samuti hea - memio e. kõige kuumem osa ei kipu üle 80C minema (mis on 4870X2-he kohta hea). Kellanud ma videot kõrgemale ei ole.
Mäludele andsin nüüd 0.1V veel juurde. Ennem oli 2.0V kui BSOD-i andis, eks vaatab, kas sellest piisab või kas üldse asi selles on.
CPU Northbridge-ile andsin samuti 0.25V juurde, et prose overclocki kaasa aidata.
sõnum 20.05.2009 11:57:52 vasta tsitaadiga
volte ka tõstsid?
sõnum 20.05.2009 13:03:46 vasta tsitaadiga
aap14: Kui tahad klokkida, siis pead minema poodi ja ostma kõigepealt toiteploki, mis ka klokkimist üleüldse suudab välja vedada. Ja kui Sa sellist toiteplokki ei osta, siis jäädki vesistama, et miks arvuti klokkimisega "kinni jookseb" ja Erroreid ning BSO-d loobib.
Nii, et pane kirja siia:
- toiteploki tootja, markeering koos sellega, et palju on Power Output võimsus.
- Siis pane veel kirja ka ,et mitu +12V ahelat (Raili) on ja mis on iga sellise Raili vool.
Kogu see info on kirjas sellel kleepsul, mis on toiteka peale kleebitud.
Ja veel - kui liialt palju "kräunutad" klokkimistega sellist toitekat, mis ei sobi klokkimiseks, siis selline toiteplokk võib kättemaksuks Su emaplaadi ka maha tappa. icon_smile.gif icon_smile.gif icon_smile.gif
sõnum 20.05.2009 13:09:06 vasta tsitaadiga
Toiteplokk on 850W
eeldatavasti nimega firma oma, " noname " sellsieid pole veel ette jäänud.
aap14
aap14
sõnum 20.05.2009 13:21:10 vasta tsitaadiga
Aga olgu, vaatamata sellele, et mul on PSU mudel profiili all ilusti kirjas, panen info siis siia ka üles:
PSU on siis rated 880W, peak load peaks olema 1040W.
Asjal on neli 12V iseseisvat raili:
+12V 1 (± 5%) 1 ~ 18 A
+12V 2 (± 5%) 1 ~ 18 A
+12V 3 (± 5%) 1 ~ 30 A
+12V 4 (± 5%) 1 ~ 30 A
ja
12V1 & 12V2&12V3 &12V4 < 768 W
Kleepsu toiteplokil kõrval ei olnud. Aga revüüsid lugedes näeb, et selle isendi puhul nii ongi.
Spetsifikatsioonide poolest peaks enam kui piisav olema mu süsteemi jaoks, kas pole?
Hetkel on aga veider see, et kui AMD Overdrive-i ja CPU-Z-ga oma kellasid vaatasin, siis jäi silma veider asi.
Nimelt on vaatamata manuaalsele seadistusele BIOS-es CPU kiirus mitte 3Ghz, vaid 3013Mhz. Samuti pole FSB mitte 200, vaid 200,8.
Teisi numbreid vaadates märkasin kah, et millegipärast on igale asjale natuke takti juurde lambist lisatud icon_neutral.gif
sõnum 20.05.2009 13:33:15 vasta tsitaadiga
sa oled keeranud mingit kordajat mis liigutab kogu süsteemi ja PSOD i saad sa ilmselt sellest, et mälud nt lähevad sellega kaasa ning sealt saad vea. ma nüüd ei tunne su plaati aga mulle tundub, et peaksid proovima nt mälusid tagasi hoida.. konkreetseks tegevuseks loe oma plaadi manuali, kuidas sa sealt asju eraldi kruvida saaksid.
aap14
aap14
sõnum 20.05.2009 13:37:57 vasta tsitaadiga
Kordajat, mis liigutab kogu süsteemi... Panin just kõik tagasi default-ile ja ikkagi näitab, et CPU 2500Mhz asemel 2511Mhz, FSB 200,8, Mälu kiirus 533Mhz asemel 535Mhz, Hyperstransport link 2000Mhz asemel 2008Mhz etc.
Äkki keegi oskab öelda, mis kordaja mul võib vähem kui 0.005 võrra paigast ära olla.
sõnum 20.05.2009 13:43:15 vasta tsitaadiga
seda ei tasu tähele panna, ilmselt voolust tulenevalt selline minimaalne erinevus.
Highlander
Highlander
sõnum 20.05.2009 13:50:34 vasta tsitaadiga
Kontrolli mälud ükshaaval üle - üks neist võib pange panna (kui neid on kaks)
Kommentaarid: 18 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 15
Noname
Noname
sõnum 21.05.2009 00:13:11 vasta tsitaadiga
mis kuradi toitplokk. tee memtesti, kettateste, load biosi def jne.
sõnum 21.05.2009 07:22:46 vasta tsitaadiga
Noname: Eks siis mine osta poest klokkimiseks mõni nõrguke, odava hinnaklassi toiteplokk, näiteks Codegen ja kuku klokkima, vaata mis juhtuma hakkab 8)
Nii, et ei ole mõtet mälusid peksta, kui klokkimise ajal ei suuda toide õigeid ja stabiilseid pingeid peale anda ja siis kukub emplaat Crashe laduma. 8)
aap14
aap14
sõnum 21.05.2009 17:04:10 vasta tsitaadiga
Nii. Nüüd siis viskas BSOD-i desktopil. Seekord aga error kood 0*0000008E.
Kiirelt google-it vaadates ütleb, et asi on tõenäoliselt mäludes. Peab siis seda kontrollima memtestiga täna öösel.
Edit: Kas keegi oskab öelda A-Data 1066+ extreme edition mälude default timinguid ja pinget?
BIOS-e default ei pruugi olla lihtsalt see, mis tehase poolt antud default on.
sõnum 21.05.2009 18:39:23 vasta tsitaadiga
http://www.adata-group.com/EN/product_show.php?ProductNo=AD21066EU
Noname
Noname
sõnum 21.05.2009 21:25:17 vasta tsitaadiga
tahanteada kirjutas:
sina mulle küll selliseid asju rääkima ei pea icon_lol.gif icon_lol.gif icon_lol.gif
aap14
aap14
sõnum 21.05.2009 21:32:58 vasta tsitaadiga
Dogbert kirjutas:
Seadistasin mälud vastavalt seal rippuvatele spetsifikatsioonidele ja ennäe imet, sai üle hulga aja üks mitmetunnine intensiivne lahing Forged Alliance-is maha peetud ilma BSOD-i, Freeze-i või musta ekraanita. icon_smile.gif Ja seda 3Ghz peal oleva prosega.
Ei tea kas timingud aitasid, kuid voldid tõstsin 2.1 pealt 2.2-le. Eks aeg näitab kui stabiilne süsteem tegelikult on.
