praegune kellaaeg 13.09.2026 23:51:08
-Kaivo-
25.04.2009 07:44:02
All Aspect Warfare |
www.allaspectwarfare.com
An elite strike team with a thermo-nuclear weapon. Stranded. On a hostile and near desolate planet. Left for dead. What else could possibly go wrong?
The Terrans had been at war with the Gammulan race for years. In an attempt to change the tide of war and take the battle to the enemy, Galactic Command, the Terran military body, launched an all out attack on the Gammulan homeworlds of Gamma-1 and Gamma-2.
Deployed in a distant hostile territory on the other side of the known galaxy, GALCOM forces were met with repeated defeat and unprecedented losses. GALCOM deployed another fleet along with a decoy, the GCV-Excalibur, carrying a devastating orbit to surface weapon. The R.A.N.D.O.M (Random Access Nuclear Destruction of Obsolete Matter) weapon, otherwise known as the planet killer. A weapon which had only been used once before.
After an intense battle, a badly damaged GCV-Excalibur managed to slip through the Gammulan defenses and attempted to land on the nearby Gammulan planet of LV-115. Engaged by undetected planet based Surface To Orbit weaponry, the all but destroyed craft crash landed on the hostile planet. But not before deploying the devastating weapon.
Badly damaged, ninety percent crew loss and with the R.A.N.D.O.M weapon deployed and ticking, the intense planetside battles that ensue tell the story of a surviving group of four combat veterans stuck on a hostile planet, believed dead, hunted by the enemy and in a race against time to either locate and disarm the weapon or get off the planet before it detonates. Problem is, the only way off the planet is through an overwhelming enemy force. |
# PC System Requirements
* Windows XP SP3 or Vista SP1
* Intel Pentium 4 3.4Ghz, Intel Core 2 Duo E6600 2.4GHz or AMD Athlon 64 X2 3.0GHz
o Intel Core 2 Duo E8400 3.0GHz or better recommended
o AMD Phenom X3 2.1GHz or better recommended
* 1GB RAM (XP). 2GB (Vista)
* 256MB graphics card w/ Shader Model 3.0 support. 512MB or higher recommended
o nVidia GeForce 7900. GeForce 8600 GTS or better recommended
o ATI Radeon X1300. Radeon HD 2900 XT or better recommended
# DirectX 9.0c compatible sound card
# Multiplayer requires LAN or broadband connection
Midagi erilist ei paista olema aga kuna Fileplanetis pakutakse MP betat siis miks mitte järgi proovida ehk hakkab isegi meeldima:
Tiri beta SIIT
Pildid:
| Kommentaarid: 16 loe/lisa |
15 |
