praegune kellaaeg 13.11.2026 13:58:54
sten1987
03.04.2009 09:59:55
läpakas teeb restardi |
Ühel hetkel tegi lihtsalt restardi. Läks uuesti tööl, jõudis isegi wifi ära ühendada ja messenger logida ning jälle restart. Mõnikord jõuab pikemalt käivituda teine kord restart kohene. Nüüd huvitav osa. Safe Mode'is töötab ning töötab ka võrguga (LAN kaabel). Vahetasin kõvaketta kus Ubuntu peal ning täpselt sama jama.
Error log:
Microsoft (R) Windows (R) 5.01. 2600 Service Pack 3 Uniprocessor Free.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
The Event log service was started.
The system detected that network adapter \DEVICE\TCPIP_{7DADD868-D864-4402-979E-320BDAADEAA2} was connected to the network, and has initiated normal operation over the network adapter.
The Apache service failed to start due to the following error:
The system cannot find the file specified.
The Fast User Switching Compatibility service was successfully sent a start control.
The Fast User Switching Compatibility service entered the running state.
The Telephony service entered the running state.
The Remote Access Connection Manager service was successfully sent a start control.
The Network Location Awareness (NLA) service was successfully sent a start control.
The MySql service terminated unexpectedly. It has done this 1 time(s).
The Network Location Awareness (NLA) service entered the running state.
The Application Layer Gateway Service service was successfully sent a start control.
The Application Layer Gateway Service service entered the running state.
The Remote Access Connection Manager service entered the running state.
The IMAPI CD-Burning COM Service service was successfully sent a start control.
The IMAPI CD-Burning COM Service service entered the running state.
The IMAPI CD-Burning COM Service service entered the stopped state.
Viimastel kordadel enam logis selliseid erroreid näha ei ole, ei ole üldse erroreid.
viimati muutis sten1987 03.04.2009 11:02:02, muudetud 1 kord |
siLc
03.04.2009 10:00:25
| Mälud on memtestiga üle lastud DOS-is?
sten1987
03.04.2009 11:03:38
Mure ikka päevakorras. Vahetasin mälu originaali vastu. Alguses töötas kõik väga hästi, mingi läksin arvutist eemale ~30min ja nüüd teeb jälle restarte.
Kas emaplaat?
03.04.2009 11:44:34
Paar võimalust veel:
- proovi, kuidas töötab ilma akuta
- proovi mõne teise laadijaga järgi.
- keera ekraani heledus maha. Klahvikombinatsiooniga (Fn + mingi kombinatsiooniklahv)saad seda muuta.
Pean siis silmas võimalusi, et:
- poolpidune aku koormab mingi pinge "maha".
- on tekkinud mingi laadija viga, mille tõttu laadija ei suuda täiskoormust peale anda.
- ekraani kõrgepingeskeem (inventer) koormab kas ise või teeb seda poolkutu taustvalgusti lamp.
sten1987
03.04.2009 14:24:08
Olen proovin nii aku kui laadi pealt. Proovisin ekraani eredust min peal ning üldse ilma ekraanita. Võib-olla on mingi ekraani probleem, sest ühe hinge juurest on plastik täiesti puruks?
Proovisin nüüd otse autolaadia pealt, töötas sain Messengeri sisse logida ja Firefoxi lahti, siis restart. Mulle jääb ikka arusaamatuks kuidas ta Safe Mode'is töötab. Järsku on viga WiFi kaardis?
XYZ
03.04.2009 15:51:39
- Safe modes ei laeta vigast draiverit.
- Safe modes mälukasutus väiksem ja ei jõuta kohe vigast kohta kasutama hakata.
sten1987
06.04.2009 10:06:38
| Kas oskate soovitada mingit softi millega saaks emaplaati testida, et täpsemalt arusaada milles viga. Ning kui vigane osa teada siis see mingil viisil välja lülitada?
themm
07.04.2009 21:13:32
| Kas tolmune pole arvuti cpu jahutus ning kas see üldse ringi käib?
sten1987
09.04.2009 22:18:22
| Vent käib ringi küll. Kuid kui nüüd mõelda siis võib-olla tõesti liiga palju (safe mode'is) Nädalavahetusel proovin puhastada.
