peamaha
31.03.2009 22:08:18
ESAdvRemIntegrator has stopped working |
Loobib siis pidevalt seda silti, suht tüütavaks muutub, googeldasin ka veits, leidsin ühe foorumi topicu kus kaas-hplasel oli sama probleem, nimelt siis viitasid lahenduseotsijad HP-ga seonduvusele. Proovisin nende soovitusi aga kuhugi see mind ei viinud. Kellelgi soovitusi probleemist lahenemiseks?
kõrvale veel et äkki on kuidagi need kaks probleemi seotud https://foorum.hinnavaatlus.ee/viewtopic.php?p=5059095#5059095
01.04.2009 11:10:42
http://forums.techguy.org/random-discussion/556678-i-just-want-say-281.html
Good Morning All.. I did as you suggested Deb ..You are right it was plugged into the USB port.. mainly because it came with the USB cord as opposed to the PS2.. I know there is an adapter for that mouse to use a PS2 plug But I have not as yet found it.. I plugged in the HP mouse that came with the computer instead.. that was last night.. there were glitches that started as soon as I went into the regular mode.. so I went in in safe mode .. and then switched to regular mode.. so far (fingers Crossed and wood knocked on ) no problems I hope that there are not any more.. I did get zone alarm warning about ESAdvRemIntegrator which is apparently the HP popup for the extended service plan at least someone online thought that... I just set Zone alarm to not allow this one.. as it keeps popping up..and I don't need it..
Thank you soo soo much Deb and everyone.. Now I have to see about the updates that I uninstalled and I want to find out really why I can't uninstall KB938371 |
Keera service kinni ja vaata, mis juhtub. Netis jäi veel silma, et probleem seondub HP printeritega
| Kommentaarid: 751 loe/lisa |
564 |
peamaha
02.04.2009 14:32:26
| Betamax kirjutas: |
Keera service kinni ja vaata, mis juhtub. Netis jäi veel silma, et probleem seondub HP printeritega  |
HP printer on ka arvuti taga jah, andsid sita tasuta kaasa rsk, a kust ma selle service'i kinni saan keerata?
564 |
peamaha
05.04.2009 18:01:09
| Betamax kirjutas: |
| Run => msconfig all ei näita seda? |
hp service'i ja veel proovisin midagi kinni panna, sama moodi laseb edasi...
E: mingeid mõtteid veel? äkki saab kuskilt selle problemreportingu lihtsalt maha võtta.
