praegune kellaaeg 30.11.2026 00:22:41
eero6
13.03.2009 20:11:17
Wifi ühendusega ei saa osasid weebilehti lahti? |
Kasutan wifi internetti ja kaabliga seda jama olnud pole aga, ...
avastasin ühe jama, nimelt ei ava arvuti postimehe ja auto24 lehte, ütleb, et "The server at www.auto24.ee is taking too long to respond.Network Timeout. The requested site did not respond to a connection request and the browser has stopped waiting for a reply.
* Could the server be experiencing high demand or a temporary outage? Try again later.
* Are you unable to browse other sites? Check the computer's network connection.
* Is your computer or network protected by a firewall or proxy? Incorrect settings can interfere with Web browsing.
* Still having trouble? Consult your network administrator or Internet provider for assistance."
proovisin nii Firefoxi kui Internet Exploreriga ja ei saa. Päris tihti on veel sellist jama et kui kontrollin Windows Firewalli seadeid siis ta läheb ise On pealt Offi, olenemata kas exeptioni lahtris on linnuke või ei(kas peab olema)?
Kust kohast ja milliseid seadeid ma peaks muutma? Kui Exploreriga ühenduse kontrooli tegin siis annab infoks et :
Last diagnostic run time: 03/13/09 19:16:57 Network Adapter Diagnostic
Network location detection
info Using home Internet connection
info Redirecting user to support call
HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
info HTTP: Successfully connected to www.microsoft.com.
info HTTPS: Successfully connected to www.microsoft.com.
warn FTP (Passive): Error 12031 connecting to ftp.microsoft.com: The connection with the server was reset
warn FTP (Active): Error 12031 connecting to ftp.microsoft.com: The connection with the server was reset
error Could not make an FTP connection.
Ette tänades
