praegune kellaaeg 25.10.2026 17:51:31
haze
09.03.2009 21:29:44
Läpaka mälu kiirus |
| Kui läpakas on PC2700 sees. Kas sinna kõrvale võib ka midagi kiirema panna nt ddr2?
| Kommentaarid: 10 loe/lisa |
10 |
Anna tooli
09.03.2009 21:33:34
Ei, sobivad vaid järgmised SO-DIMM tüüpi:
PC-2100 266MHz DDRAM
PC-2700 333MHz DDRAM
PC-3200 400MHz DDRAM
300 |
Absona
| Kommentaarid: 11 loe/lisa |
haze
09.03.2009 22:42:44
Motherboard name IBM thinkpad t41p ja nii on. Motherboard ID DMI.
Siis on seal veel sellist infi
Field Value
Motherboard Properties
Motherboard ID <DMI>
Motherboard Name IBM ThinkPad T41p
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth 2667 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
10 |
