praegune kellaaeg 30.09.2026 02:20:07
krilf
21.02.2009 23:41:45
vistal probleem thumbnailsidega - ei näe enam pilte |
enne olid kõik pildid ilusti nähtaval, nüüd kõik ühesugused. thumbnailsi ei ole view menüüs.
tools-folder options-view "always show icons, never thumbnails" ja "display file icon on thumbnails" võtsin linnukesed ära ja hetkeks näitab pilte - siis lähevad kohe "kaardid" jälle tagurpidi
infoks veel, et disc cleanupiga kustutasin päeval Thumbnailsid ära. seal ütles veel, et kui kustutan siis, they will be automatically recreated as needed. kuidas saan siis tagasi ? teab keegi abistada?
svenman
27.02.2009 12:22:38
Google?!
Fix Found: Click through the following:
Start, Control Panel, System and Maintenance, Administrative Tools-Free up disk space, Files from all users, (C OK, Files to delete:CHECK THUMBNAILS OPTION, click OK.
Everything was back to normal! Clearing the thumbnail cache via this method worked for me.
By the way, this problem just appeared recently. I have been running Vista since it's initial release two years ago and only had a problem develop this week.
Something other than cache size (program update maybe) has caused this issue. Perhaps they can fix this issue in a future update.
I do not relish deleting cache on a regular basis just to perform a go around for a systemic issue.
Allikas: http://forums.techarena.in/vista-help/702036-2.htm
| Kommentaarid: 80 loe/lisa |
71 |
krilf
