praegune kellaaeg 24.10.2026 21:48:54
Cuculus
19.02.2009 22:32:51
Win update ei toimi |
kas arvutis istub mingi kole viirus ?
Network policy settings prevent you from using this website to get updates for your computer.
If you believe you have received this message in error, please contact your system administrator.
Read more about steps you can take to resolve this problem (error number 0x8DDD0003) yourself
http://www.hot.ee/cuculuss//mis%20asja.jpg
vajutades sinna INstall updates from the Windows web site
lööd selle kasti ette
oskab keegi targem aidata ?
| Kommentaarid: 6 loe/lisa |
tsihh
| Kommentaarid: 59 loe/lisa |
58 |
Cuculus
20.02.2009 00:03:28
# Log on to the computer as a local administrator.
# Click Start, click Run, type gpedit.msc, and then click OK.
# In the left pane, expand User Configuration, expand Administrative Templates, and then click Start Menu and Taskbar.
# In the right pane, right-click Remove links and access to Windows Update, and then click Properties.
# Click Disabled, click Apply, and then click OK
see ei toimi
peab kolama netis veel ja otsima ..
