keevitaja
AM 10 aastat
09.02.2009 20:52:48
illustrator ei tunne fonte |
mingi imelik jama on. illustrator nagu ei tea fontidest midagi.
see rida on näiteks wordis kolme erineva fondiga kirjutatud ja siis illustratorisse pastetud. ja kusagilt nagu fonte valida kah ei saa.
| Kommentaarid: 51 loe/lisa |
40 |
punktiir
| Kommentaarid: 49 loe/lisa |
38 |
keevitaja
AM 10 aastat
09.02.2009 21:30:45
no seal on kirjas, et teatud fonte ei näita. mul ei näita illustrator ühtegi. samas ps-s on ok...
_________________ Hinnavaatlus ei ole koht arvamuse avaldamiseks! |
40 |
09.02.2009 21:56:43
| Ega sul liiga palju fonte korraga paigaldatud pole ?
| Kommentaarid: 85 loe/lisa |
keevitaja
AM 10 aastat
09.02.2009 21:58:32
max ehk 20 fonti olen ise paigaldanud. muud on need mis xp-s kohe olemas
40 |
punktiir
09.02.2009 23:34:25
kas AI preference reset ei aita?
Save your work and close Illustrator. Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings. (Your version of Illustrator will be in the foldr name.) Inside this folder is a file called AIPrefs. Drag this file to the trash, and restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
You can also reset Illustrators preferences by holding down Shift + Control + Alt while launching the program. If you get a dialog asking if you want to delete the Adobe Illustrator settings folder, click yes to proceed. Restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
Illustrator CS 2 allows you to save custom workspaces. Note that while this procedure resets the program preferences in Illustrator CS2 to defaults, it doesnt change the Workspace preferences, which are stored in a different file. To reset the workspace, go to Window > Workspace > Default, or choose one of your saved workspaces. |
38 |
keevitaja
AM 10 aastat
10.02.2009 02:05:03
see ei aita. olen seda juba proovinud. aga tegelt on asi palju huvitavam. type> all on ilusti fondid olemas. saab ka teksti panna. aga koos tekstiga ei lase saveda. annab mingit unknown errorit :d krdi pull, see sama versioon, sama iso, on mul ennem töötanud. ei tea, mis kamm on. olen ka uninstalli teinud ja pärast ka registri ning installi kataloogi puhtaks.
edit: panin cs3 peale ja see paistab töötavat. ei viitsinud rohkem selle anomaaliaga tegeleda.
40 |
Herr Kurm
10.02.2009 09:01:12
| keevitaja kirjutas: |
| see sama versioon, sama iso, |
äge
_________________ -logod, firmaidentiteet, küljendamine, flash-
-portfolio- |
| Kommentaarid: 25 loe/lisa |
19 |
keevitaja
AM 10 aastat
10.02.2009 12:27:43
mis siin ägedat on?
40 |
daetric
15.02.2009 21:03:40
| mis siin ägedat on? |
piraatlus
| Kommentaarid: 16 loe/lisa |
12 |
