praegune kellaaeg 08.08.2026 04:33:05
aer0x
16.02.2009 22:48:16
TG585 v7 + ST780 wl WDS tööle |
Oskab keegi öelda kuidas WDS 585 ja 780 vahel tööle panna? TG585-sse tuleb praegu dsl ja wifil krüpteeringut peal ei ole. Mõlemad ruuterid on üksteisel seal WDS listis ja mõlemal WDS enabled. ST780 on tehtud factory restore ja peale seda dhcp kinni keeratud. Kanalid on ka samad mõlemal. 780 ip muutsin ka ära et oleks erinev 585 omast. Aga siiski 585-te connectides on nett olemas ja kõik on ilus, aga 780 netti ei saa.
On mul mingid confimis etapid vahele jäänud?
edit: UP
edit: UP2
edit: UP3
edit: UP4
_________________ O_o |
| Kommentaarid: 18 loe/lisa |
16 |
kfl
05.08.2009 13:25:25
katsetan 2-e st780-ga
http://www.speedtouchturkiye.com/destek/ST780WL/guide/ST780sip_UserGuide.pdf ütleb, et wds kllient peab olema repiiter, ehk siis st780-e peab saama tööle ennem repeater modes
samas http://www.answers.com/topic/wireless-distribution-system, et peaks ka 2-e AP vahel töötama
ConfigGuide_WANConnect kuidas Ethernet-to-Ethernet/DMZ wisardi ette saaks, kas sellest oleks abi?
Kas kellelgi speedtussi cd? Kas sellel plaadil on wisard olemas?
milline peaks olema confi skeem?
milline peaks olema conf? praegu selline:
Name Type State Use UL Interfaces
loop ip connected 0
ethif1 physical connected 1 ethport1
ethif2 physical connected 1 ethport2
ethif3 physical connected 1 ethport3
ethif4 physical connected 1 ethport4
usbif1 physical connected 1 usbport
wlif1 physical connected 1 WLAN
ceoc dsl connected 0
bridge eth connected 2 RELAY, LocalNetwork
OBC bridge connected 1 bridge
ethport1 bridge connected 1 bridge
RELAY eth connected 1 Internet_ppp
FXS1 physical connected 0
FXS2 physical connected 0
FXO physical connected 0
atm_8_35 atm connected 1 ethoa_8_35
ethport2 bridge connected 1 bridge
ethport3 bridge connected 1 bridge
ethport4 bridge connected 1 bridge
usbport bridge connected 1 bridge
WLAN bridge connected 1 bridge
ethoa_8_35 eth connected 1 RELAY
Internet_ppp ppp not-connected 1 Internet
Internet *ip not-connected 0
LocalNetwork ip connected 0
wl_ssid0_wds1 physical connected 1 WL_0_wds1
WL_0_wds1 bridge connected 1 bridge |
kas teist ruuterit peaks näitama Local Network Devices all kui WDS on aktiviserunud?
tahaks ka asja tööle saada
_________________ Müügis: YARIS! ja FOCUS Tel: 1214*5100741*100 |
| Kommentaarid: 111 loe/lisa |
107 |
