praegune kellaaeg 27.10.2026 19:58:01
Cosakas
14.01.2009 15:58:10
WMP ei avane |
Mure järgmine et mediaplayer ei avane.Vajutan ikoonile ei juhtu midagi.Ei saa maha ka lasta ja uut ei lase peale panna ütleb et viimane versioon on olemas.
Mind aitas selline asi:
For the registering to work, you must run the command prompt as an administrator or log in to vista as an administrator. Go to accessories, right-click command prompt, and click run as administrator.
1. type regsvr32 jscript.dll and then press enter. you should get a confirmation message.
2. repeat and type regsvr32 vbscript.dll and then press enter.
3. type exit and press enter.
Your error with WMP 11 should now be fixed.
Kui kellelegi abiks peaks olema.
viimati muutis Cosakas 17.01.2009 15:17:55, muudetud 1 kord |
| Kommentaarid: 4 loe/lisa |
apelsin16
| Kommentaarid: 63 loe/lisa |
57 |
