praegune kellaaeg 30.11.2026 06:03:33
xpoint
05.01.2009 12:49:28
Windows ei käivitu kui video driverid on installitud |
Windows ei käivitu kui video driverid on installitud. Kui driverid maha lasen siis töötab. Event Vieweris on mingi selline tekst
The description for Event ID ( 108 ) in Source ( nv ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: \Device\Video0; display; nv4_disp.
Mis probleem olla võiks sest eile töötas jumala ilusti.
