praegune kellaaeg 07.08.2026 21:34:57
Markspoiss
04.12.2008 19:09:01
mida tähendab headroom qos seadetes? |
tähendab mida sellega nagu regullida saab? seal on mingi protsentides antud värk.... defaultis on 10%
ja äkki viitsib keegi selle osa ära tõlkida et täpsemalt aru saaksin:)
* slow - for traffic that you wish to force to go slow even if the motorway (Internet connection) is otherwise empty.
* low - for traffic that can use up to 40% of the available lanes but if there is other traffic on the road this is limited to 15%.
* normal - can use 90% of the capacity of the road if the road is otherwise empty and at least 40% in busier conditions.
* high - also can use 90% of an otherwise empty road and is guaranteed 20% if the road is busy, BUT has first call on any spare capacity, then normal then low.
| Kommentaarid: 20 loe/lisa |
16 |
