praegune kellaaeg 10.11.2026 03:05:07
geek
| Kommentaarid: 42 loe/lisa |
41 |
oicu
27.11.2008 20:19:02
| milles see väljendub, et tööle ei lähe. mis vea sa saad?
| Kommentaarid: 9 loe/lisa |
9 |
geek
04.12.2008 11:04:35
Kasutan all olevat conf faili.
<?xml version="1.0" encoding="UTF-8"?>
<server xmlns="http://mina.apache.org/ftpserver/spring/v1"
xmlns:beans="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http://www.springframework.org/schema/beans/spring-beans-2.5.xsd
http://mina.apache.org/ftpserver/ftpserver-1.0.xsd"
id="myServer">
<db-user-manager>
<data-source>
<bean id="datasource" class="org.apache.commons.dbcp.BasicDataSource" >
<property name="driverClassName" value="com.mysql.jdbc.Driver" />
<property name="url" value="jdbc:mysql://localhost:3306/baas" />
<property name="username" value="root" />
<property name="password" value="a" />
</bean>
</data-source>
<insert-user>INSERT INTO FTP_USER (uid, userpassword,
homedirectory, enableflag, writepermission, idletime, uploadrate,
downloadrate) VALUES ('{uid}', '{userpassword}', '{homedirectory}',
'{enableflag}', '{writepermission}', {idletime}, {uploadrate},
{downloadrate})</insert-user>
<update-user>UPDATE FTP_USER SET
userpassword='{userpassword}',homedirectory='{homedirectory}',enableflag='{enableflag}',writepermission='{writepermission}',idletime
={idletime},uploadrate={uploadrate},downloadrate={downloadrate}
WHERE uid='{uid}'</update-user>
<delete-user>DELETE FROM FTP_USER WHERE uid = '{uid}'
</delete-user>
<select-user>SELECT uid, userpassword, homedirectory,
enableflag, writepermission, idletime, uploadrate, downloadrate FROM
FTP_USER WHERE uid = '{uid}'</select-user>
<select-all-users>SELECT uid FROM FTP_USER ORDER BY uid
</select-all-users>
<is-admin>SELECT uid FROM FTP_USER WHERE uid='{uid}' AND
uid='admin'</is-admin>
<authenticate>SELECT uid from FTP_USER WHERE uid='{uid}' AND
userpassword='{userpassword}'</authenticate>
</db-user-manager>
</server>
Viga mis selle peal tuleb
org.springframework.beans.factory.xml.XmlBeanDefinitionStoreException: Line 18 in XML document from file [C:\Documents and Settings\andres\My Doc
uments\T÷÷\ftpserver-1.0.0-M3\.\res\conf\conf.xml] is invalid; nested exception is org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid
content was found starting with element 'bean'. One of '{"http://www.springframework.org/schema/beans":bean, "http://www.springframework.org/sch
ema/beans":ref}' is expected.
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:404)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:342)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:310)
at org.springframework.beans.factory.xml.XmlBeanFactory.<init>(XmlBeanFactory.java:73)
at org.springframework.beans.factory.xml.XmlBeanFactory.<init>(XmlBeanFactory.java:61)
at org.apache.ftpserver.main.CommandLine.getConfiguration(CommandLine.java:132)
at org.apache.ftpserver.main.CommandLine.main(CommandLine.java:56)
Caused by: org.xml.sax.SAXParseException: cvc-complex-type.2.4.a: Invalid content was found starting with element 'bean'. One of '{"http://www.sp
ringframework.org/schema/beans":bean, "http://www.springframework.org/schema/beans":ref}' is expected.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator$XSIErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.reportSchemaError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.handleStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at org.springframework.beans.factory.xml.DefaultDocumentLoader.loadDocument(DefaultDocumentLoader.java:75)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:396)
... 6 more
Tundub et Apache'st ei saa asja. On kellelgi mõne teise ftp serveriga kogemusi ,kuidas SQL autientimisega tööle saada?
41 |
