praegune kellaaeg 05.11.2026 18:33:18
Osiris
17.11.2008 17:34:13
Website baker kalender |
Jõudu.
on siis üks website baker kalendrimoodul.
Kõik on hää - aga probleem selline:
Kui tahan lisada mingit uut sündmust siis lisamislehel tuleb see sisestamisasi nende kalendrikirjete lõppu.
Aga hea oleks kui nende ette.
Lisan ka pildi, et oleks ülevaade mida ütelda tahan:
Hetkel asub ta sellises kohas - ehk siis selle nimekirja all:
Aga oleks hea kui saaks seda koodi mudida nii, et asuks seal kus sellel pildil see punane kast.
Kood ise on selline:
Kahjuks iseseisvast mudimisest ei tulnud midagi välja.
<?php
require('../../config.php');
// Include WB admin wrapper script
$update_when_modified = true; // Tells script to update when this page was last updated
// Load Language file
if(LANGUAGE_LOADED) {
if(!file_exists(WB_PATH.'/modules/event_calendar/languages/'.LANGUAGE.'.php')) {
require(WB_PATH.'/modules/event_calendar/languages/EN.php');
} else {
require(WB_PATH.'/modules/event_calendar/languages/'.LANGUAGE.'.php');
<center>
<?php
if( $error != '' || $_GET['op'] == 'add' ){
$id = '';
$start_time_int = $_POST['start_time_int'];
$start_day = $_POST['start_day'];
$start_month = $_POST['start_month'];
$start_year = $_POST['start_year'];
$start_hour = $_POST['start_hour'];
$start_minute = $_POST['start_minute'];
$end_time_int = $_POST['end_time_int'];
$end_day = $_POST['end_day'];
$end_month = $_POST['end_month'];
$end_year = $_POST['end_year'];
$end_hour = $_POST['end_hour'];
$end_minute = $_POST['end_minute'];
$short_description = $_POST['long_description'];
$long_description = $_POST['short_description'];
$link_text = $_POST['link_text'];
$link_http = $_POST['link_http'];
$event_type = $_POST['event_type'];
$startdate_value = "";
$starttime_value = "";
$enddate_value = "";
<h1><?= $SMTEXT['admin']['add_new'] ?></h1>
<?php
} else {
<h1><?= $SMTEXT['admin']['edit_old'] ?></h1>
<?php
$event_id = $_GET['entry_id'];
$sql = "SELECT id,start_time,end_time,short_description,long_description,link_text,link_http,type FROM ".TABLE_PREFIX."mod_event_calendar WHERE id = $event_id;";
$query_entries = $database->query( $sql );
$entry = $query_entries->fetchRow();
$id = $entry['id'];
$start_time_int = $entry['start_time'];
$start_day = date("d",$start_time_int);
$start_month = date("m",$start_time_int);
$start_year = date("Y",$start_time_int);
$start_hour = date("H",$start_time_int);
$start_minute = date("i",$start_time_int);
$end_time_int = $entry['end_time'];
$end_day = date("d",$end_time_int);
$end_month = date("m",$end_time_int);
$end_year = date("Y",$end_time_int);
$end_hour = date("H",$end_time_int);
$end_minute = date("i",$end_time_int);
$short_description = $entry['short_description'];
$long_description = $entry['long_description'];
$link_text = $entry['link_text'];
$link_http = $entry['link_http'];
$event_type = $entry['type'];
$startdate_value = "$start_day.$start_month.$start_year";
$starttime_value = "$start_hour:$start_minute";
$enddate_value = "$end_day.$end_month.$end_year";
$endtime_value = "$end_hour:$end_minute";
if( stristr(TIME_FORMAT,' A') === false ){
$am = 0;
} else {
$am = 1;
<!-- Date picker from http://www.garrett.nildram.co.uk/calendar/scw.htm -->
<script type='text/JavaScript'>
<?php include 'scw.js'; ?>
// set the start date field value to be the same as the end date field value if needed
function setStartDate(txt){
if( document.new_event.startdate.value == '' ){
document.new_event.startdate.value = document.new_event.enddate.value;
// set the end date field value to be the same as the start date field value if needed
function setEndDate(txt){
if( document.new_event.enddate.value == '' ){
document.new_event.enddate.value = document.getElementById('startdate').value;
</script>
<form name="new_event" action="<?= $_SERVER['PHP_SELF'] ?>?page_id=<?= $page_id?>" method="post">
<table border="0">
<tr><td colspan="2" align="center">
<table border="0">
<tr><th> </th><th><?= $SMTEXT['admin']['day'] ?></th><th><?= $SMTEXT['admin']['time'] ?></th></tr>
<tr><td><b><?= $SMTEXT['admin']['start'] ?></b>*</td><td>
<input id='startdate' name='startdate' type='text' value='<?= $startdate_value ?>' size='20' onFocus='javascript:blur();' /><img src='<?= WB_URL."/modules/event_calendar/scw.gif" ?>' title='' alt='' onclick="scwNextAction=setEndDate.runsAfterSCW( this, '' ); scwShow(document.getElementById('startdate'),this);" />
</td>
<td>
<select name="starttime">
<option value=""></option>
<?php
for($h=0;$h<=23;$h++){
for($m=0;$m<60;$m=$m+15){
$value = '';
$showvalue = '';
if( $h > 12 && $am==1 ){
if( ($h-12) < 10 ){
$value = $h;
$showvalue = "0".($h-12);
} else {
$value = $h;
$showvalue = $h-12;
} else {
if( $h < 10 ) {
if( $am == 1 && $h == 0 ){
$value = $h;
$showvalue = "12";
} else {
$value = "0".$h;
$showvalue = "0".$h;
} else {
$value = $h;
$showvalue = $h;
$value .= ":";
$showvalue .= ":";
if( $m == 0 ){
$value .= "00";
$showvalue .= "00";
} else {
$value .= $m;
$showvalue .= $m;
if( $am==1 ) {
if( $h >= 12 ) {
$showvalue .= " pm";
} else {
$showvalue .= " am";
} else {
$showvalue .= "";
<option value="<?= $value ?>" <?= $value==$starttime_value?"selected":"" ?> ><?= $showvalue ?></option>
<?php
</select>
</td></tr>
<tr><td><b><?= $SMTEXT['admin']['end'] ?></b></td><td>
<input id='enddate' name='enddate' type='text' value='<?= $enddate_value ?>' size='20' onFocus='javascript:blur();' /><img src='<?= WB_URL."/modules/event_calendar/scw.gif" ?>' title='' alt='' onclick="scwNextAction=setStartDate.runsAfterSCW( this, '' ); scwShow(document.getElementById('enddate'),this);" />
</td>
<td>
<select name="endtime">
<?php
$value = '';
$showvalue = '';
if( ($h-12) < 10 ){
$value = $h;
} else {
$value = $h;
$showvalue = $h-12;
} else {
if( $h < 10 ) {
$value = $h;
$showvalue = "12";
} else {
$value = "0".$h;
} else {
$value = $h;
$showvalue = $h;
$value .= ":";
$showvalue .= ":";
if( $m == 0 ){
$value .= "00";
$showvalue .= "00";
} else {
$value .= $m;
$showvalue .= $m;
if( $am==1 ) {
if( $h >= 12 ) {
} else {
} else {
$showvalue .= "";
<option value="<?= $value ?>" <?= $value==$endtime_value?"selected":"" ?> ><?= $showvalue ?></option>
<?php
</select>
</td></tr>
</table>
</td></tr>
<tr><td colspan="2"> </td></tr>
<tr><th><?= $SMTEXT['admin']['short_description'] ?>*</th><td><input type="text" name="short_description" size="80" value="<?= $short_description ?>"></input></td></tr>
<tr><th valign="top"><?= $SMTEXT['admin']['long_description'] ?></th><td><textarea name="long_description" cols="77" rows="8"><?= $long_description ?></textarea></td></tr>
<tr><th><?= $SMTEXT['admin']['link_text'] ?></th><td><input type="text" name="link_text" size="80" value="<?= $link_text ?>"></input></td></tr>
<tr><th><?= $SMTEXT['admin']['link_http'] ?></th><td><input type="text" name="link_http" size="80" value="<?= $link_http ?>"></input></td></tr>
<tr><th><?= $SMTEXT['admin']['type'] ?></th><td>
<select name="event_type">
<option value=''></option>
<?php
$types = explode( ",", $SMTEXT['types'] );
foreach($types as $type){
<option name="<?= $type ?>" <?php if( $type == $event_type ) echo "selected"; ?>><?= $type ?></option>
<?php
</select></td></tr>
<input type="submit" value="<?= $SMTEXT['admin']['save'] ?>">
<input type="reset" value="<?= $SMTEXT['admin']['reset'] ?>">
</td></tr>
<tr><td colspan="2"><?= $SMTEXT['admin']['required_fields'] ?><br/><?= $SMTEXT['admin']['default_timeframe'] ?> <?= $SMTEXT['admin']['default_starttime'] ?> - <?= $SMTEXT['admin']['default_endtime'] ?></td></tr>
<tr><td colspan="2"><input type="hidden" name="op" value="save"></td></tr>
<?php
if( $id != '') {
<tr><td colspan="2"><input type="hidden" name="entry_id" value="<?= $id ?>"></td></tr>
<?php
</table>
</form>
</center>
103 |
