praegune kellaaeg 24.10.2026 19:08:13
sinx33
17.11.2008 16:33:57
HP Color LaserJet CP1215 ja toonerite tahmasisaldus |
Tere!
Tekkis selline küsimus.
Kui mingi tooner peaks tühjaks saama, kas siis see printer hakkab näkku panema või saab ka nii printida, kui tooner(id) v.a MUST, on tühjad.
trip
20.11.2008 19:27:31
ja vastus sinu küsimusele asub kasutaja juhendi sees, inglise keele manuaal lk. 48
System Setup
Use the HP Color LaserJet CP1210 Series Toolbox System Settings options to configure
miscellaneous product settings.
* Jam recovery. If this option is on, the product automatically reprints pages that are damaged when
a jam occurs.
* Auto continue. If this setting is Off, the product waits indefinitely for you to respond to prompts
that require action. If this setting is On, the product continues printing after a specific length of time,
even if you have not responded to the prompt.
* Sleep time-out. Specify the length of time, in seconds, for the product to enter Sleep mode, after
no activity has occurred.
* Cartridge out override. Set the option whether to continue printing after a cartridge has reached
the threshold for end of life.
* Automatic resolution reduction. Set the option to automatically reduce the print resolution if the
page requires too much memory.
* Location. Select the appropriate country/region. |
303 |
sinx33
22.11.2008 16:07:37
| Selge! 8)
