group
21.10.2008 11:12:43
Kogemus Buffalo LinkStationi seadistamisega - kellelgi? |
Sai endale soetatud Buffalo LinkStation aga on mõned probleemid, millest ei saa jagu. Linkstation on ühendatud ruuteri külge ja ühtlasi toimib koduse failiserverina. Aeg ajalt oleks tarvis ka tööl failidele ligi pääseda. Selleks suunasin ruuteri pordid linkstationile. Kui nüüd proovida siseneda ip kaudu siis suunab küll kenasti serverile aga paraku setup-i osale.
Siit ka küsimus, et kuidas ma jõuan failideni?
kurask
| Kommentaarid: 68 loe/lisa |
group
21.10.2008 11:52:51
Suunamine on tehtud juba ruuteris 21 pordile või midagi taolist ja sinna ta ka suunab.
Usun, et viga on Linkstationi menüü settingutes. Seal on nimelt olemas FTP Server enable/disable setting, seega saan mina aru nii, et kui on enabled siis peakski kohe minema failide ossa.
Setup the LinkStation`s internal FTP Server.
In order to use the LinkStation as an anonymous FTP server, set the FTP Server function to Enable, the FTP Access User to Anonymous and select a shared folder to be accessible by FTP.
External USB Disks cannot be used as FTP shares.
In order to use the LinkStation as a registered user FTP server, set the FTP Server function to Enable, the FTP Access User to Registered Users and select the shared folders to be accessible by the registered user FTP from within the Registered Users Public Shared Folders.
The Reistered User and Anonymous User FTP Servers cannot be used at the same time.
In order to use the Registered Users FTP Server, a user must be setup on the Link Station
The User name and password setup on the LinkStation then become the user account and password for the FTP login.
User setup can be carried out from Security Setup -User Settings
When the Shared Folder has access restrictions, that shared folder cannot be accessed when using the Anonymous FTP Server.
However when using the registered Users FTP Server, the folder can be accessed only by users whom have access to that Shared Folder.
The FTP Access setting (Read Only -OR- Writable) takes priority over the actual Shared Folder setting when running an Anonymous FTP Server.
47th ronin
21.10.2008 20:20:40
ahem, järjekord käib vast niiviisi:
1. lased ftp serveri käima (shared folders, ftp server enable)
2. paned käima nägudekontrolli:
2.1 teed kasutajatunnused ftp-le ligi lubatavatele kasutajatele (user management, add local user)
2.2 lood ftp kasutajate jaoks kasutajagrupi (user groups, tähistad linnukesega kasutajad, kes gruppi kuuluvad)
3. määrad ftp kasutajate jaoks kasutatavad kaustad (shared folders setup)
4. täpsustad kasutajate õigusi nende kasutatavates kaustades (shared folders, edit, access restrictions)
põmst ongi vast kõik. muidugi, see on kõik kirja pandud webiliidese jaoks. isasem on äratada oma purgis telnet daemon, sinna sisse logida ja käsurea pealt kõik teha.
_________________ rgrds,
ronin, neljakümne seitsmes |
| Kommentaarid: 52 loe/lisa |
50 |
nuhk
22.10.2008 01:11:23
| FTP tarbeks portide suunamisel tuleks ruuteris suunata kettaseadmele tcp:20 ja tcp:21 mõlemad, mitte ainult 21.. ja see kehtib igasuguse ftp portide suunamise kohta.
| Kommentaarid: 8 loe/lisa |
group
22.10.2008 12:18:54
Probleem ei seisne mitte folderite loomises, vaid kuidas jõuda läbi weebi "setup" osa asemel oma dokumentideni. Mida ma pean kirjutama aadressi reale?
Praegu sisestades http://minulinkstationiaadress - siis jõuan ma Linkstation setup ossa.
Kas dokumentideni peaksin jõudma siis nii, et asendan http- ftp-ga? ( ftp://minulinkstationiaadress )
kurask
47th ronin
22.10.2008 20:18:00
kui vägisi üle webi tahad, siis tuleb ikka web access sisse lülida ning ftp-ga pole sel miskit pistmist. kui 'õuest' üle webi tahad, siis tuleb ruuteris sobilik portforward teha, nagu nuhk juba ülalpool ftp kohta vihjas.
50 |
kussu
22.10.2008 21:33:19
Pole küll Linkstationiga kokku puutunud, kuid Terastationiga käib nii nagu sharetud asjadel ikka
Start-Run-\\minulinkstationiaadress
| Kommentaarid: 69 loe/lisa |
68 |
group
22.10.2008 23:44:59
Start-Run-\\minulinkstationiaadress |
Tundudb, et see variant töötab, proovin homme ka teisest võrgust siis on kindel.
Kas tead ka lahendust sellele, et kui luua kaustadele paroolid, siis oma arvutist proovides kaustu avada nende paroolidega ei õnnestu. Küllaga saab kaustad avatud samade paroolidega mõnest teisest arvutist lähenedes?
kussu
23.10.2008 08:49:13
| group kirjutas: |
Kas tead ka lahendust sellele, et kui luua kaustadele paroolid, siis oma arvutist proovides kaustu avada nende paroolidega ei õnnestu. Küllaga saab kaustad avatud samade paroolidega mõnest teisest arvutist lähenedes? |
Pole paroole kasutanud, mul paikneb kast domeenis ja ligipääs ainult AD (Active Directory) kasutajatele ning see toimib.
68 |
Mudil
15.02.2009 23:41:14
| Oma kasutajakaustale saab ligi sellisel kujul kui kasutad IE-d. Mozilla jm. veebibrauser oskabki ainult setup avalehele suunata.
