praegune kellaaeg 25.11.2026 12:49:38
7 :: |
364 |
Gaspar
07.10.2008 13:30:07
Päris nii see pole.. |
Loe: http://groups.google.com/group/comp.os.minix/msg/b813d52cbc5a044b?dmode=source
Path: gmdzi!unido!fauern!ira.uka.de!sol.ctr.columbia.edu!zaphod.mps.ohio-state.edu!wupost!uunet!mcsun!news.funet.fi!hydra!klaava!torvalds
From: torva...@klaava.Helsinki.FI (Linus Benedict Torvalds)
Newsgroups: comp.os.minix
Subject: What would you like to see most in minix?
Summary: small poll for my new operating system
Keywords: 386, preferences
Message-ID: <1991Aug25.205708.9541@klaava.Helsinki.FI>
Date: 25 Aug 91 20:57:08 GMT
Organization: University of Helsinki
Lines: 20
Hello everybody out there using minix -
I'm doing a (free) operating system (just a hobby, won't be big and
professional like gnu) for 386(486) AT clones. This has been brewing
since april, and is starting to get ready. I'd like any feedback on
things people like/dislike in minix, as my OS resembles it somewhat
(same physical layout of the file-system (due to practical reasons)
among other things).
I've currently ported bash(1.08) and gcc(1.40), and things seem to work.
This implies that I'll get something practical within a few months, and
I'd like to know what features most people would want. Any suggestions
are welcome, but I won't promise I'll implement them
Linus (torva...@kruuna.helsinki.fi)
PS. Yes - it's free of any minix code, and it has a multi-threaded fs.
It is NOT protable (uses 386 task switching etc), and it probably never
will support anything other than AT-harddisks, as that's all I have .
| Kommentaarid: 4 loe/lisa |
DWL
07.10.2008 15:37:27
Õige kuupäev peaks olema 5.10.1991 ning siis teavitati linuxi kerneli esimese versiooni valmimisest.
http://groups.google.com/group/comp.os.minix/msg/2194d253268b0a1b?dmode=source
Path: gmdzi!unido!mcsun!news.funet.fi!hydra!klaava!torvalds
Subject: Free minix-like kernel sources for 386-AT
Keywords: 386, preliminary version
Message-ID: <1991Oct5.054106.4647@klaava.Helsinki.FI>
Date: 5 Oct 91 05:41:06 GMT
Lines: 55
Do you pine for the nice days of minix-1.1, when men were men and wrote
their own device drivers? Are you without a nice project and just dying
to cut your teeth on a OS you can try to modify for your needs? Are you
finding it frustrating when everything works on minix? No more all-
nighters to get a nifty program working? Then this post might be just
for you
As I mentioned a month(?) ago, I'm working on a free version of a
minix-lookalike for AT-386 computers. It has finally reached the stage
where it's even usable (though may not be depending on what you want),
and I am willing to put out the sources for wider distribution. It is
just version 0.02 (+1 (very small) patch already), but I've successfully
run bash/gcc/gnu-make/gnu-sed/compress etc under it.
Sources for this pet project of mine can be found at nic.funet.fi
(128.214.6.100) in the directory /pub/OS/Linux. The directory also
contains some README-file and a couple of binaries to work under linux
(bash, update and gcc, what more can you ask for . Full kernel
source is provided, as no minix code has been used. Library sources are
only partially free, so that cannot be distributed currently. The
system is able to compile "as-is" and has been known to work. Heh.
Sources to the binaries (bash and gcc) can be found at the same place in
/pub/gnu.
ALERT! WARNING! NOTE! These sources still need minix-386 to be compiled
(and gcc-1.40, possibly 1.37.1, haven't tested), and you need minix to
set it up if you want to run it, so it is not yet a standalone system
for those of you without minix. I'm working on it. You also need to be
something of a hacker to set it up , so for those hoping for an
alternative to minix-386, please ignore me. It is currently meant for
hackers interested in operating systems and 386's with access to minix.
The system needs an AT-compatible harddisk (IDE is fine) and EGA/VGA. If
you are still interested, please ftp the README/RELNOTES, and/or mail me
for additional info.
I can (well, almost) hear you asking yourselves "why?". Hurd will be
out in a year (or two, or next month, who knows), and I've already got
minix. This is a program for hackers by a hacker. I've enjouyed doing
it, and somebody might enjoy looking at it and even modifying it for
their own needs. It is still small enough to understand, use and
modify, and I'm looking forward to any comments you might have.
I'm also interested in hearing from anybody who has written any of the
utilities/library functions for minix. If your efforts are freely
distributable (under copyright or even public domain), I'd like to hear
from you, so I can add them to the system. I'm using Earl Chews estdio
right now (thanks for a nice and working system Earl), and similar works
will be very wellcome. Your (C)'s will of course be left intact. Drop me
a line if you are willing to let me use your code.
Linus
PS. to PHIL NELSON! I'm unable to get through to you, and keep getting
"forward error - strawberry unknown domain" or something. |
Gaspar
07.10.2008 15:50:04
Algne uudis nimega "Linus Torvalds alustas Linuxi arendamist" on ümber lükatud minu postitatud lingiga.
Nimelt kirjutab ta 25. augusti postituses, et alustas Linuxi arendamist/kirjutamist aprillis!
Linuxi sünnipäev on aga 17. september, 17/09/1991 ilmus kernel 0.0.1 internetti!
http://en.wikipedia.org/wiki/September_17
Sven
10.10.2008 10:40:19
| Ubuntu 8.04 kasutusel PC peal.... ülimalt pro värk!
| Kommentaarid: 35 loe/lisa |
mikk150
12.10.2008 19:25:13
| Svenx kirjutas: |
| Ubuntu 8.04 kasutusel PC peal.... ülimalt pro värk! |
18 päeva veel ja ubuntu 8.10
