praegune kellaaeg 07.11.2026 19:26:16
gynterk
06.10.2008 11:19:00
CNU-680 (Kõu) kukub küljest ära. |
Distro: Ubuntu hardy
Kernel: 2.6.24-19
Arhitektuur: x86_64
Libc6: 2.7-10
Seade: CNU-680
Seade töötab mõnda aega kenasti ja siis kukub mingi hetk küljest ära (logid allpool). Kas tegemist võib olla seadme enda veaga?
# Alguses töötab kenasti ja mingi hetk lihtsalt sureb ära
Oct 6 11:51:39 MyHostName kernel: [11161.765943] usb 2-1: new full speed USB device using uhci_hcd and address 68
Oct 6 11:51:39 MyHostName kernel: [11161.910020] usb 2-1: config 1 has an invalid interface number: 6 but max is 5
Oct 6 11:51:39 MyHostName kernel: [11161.910027] usb 2-1: config 1 has 4 interfaces, different from the descriptor's value: 6
Oct 6 11:51:39 MyHostName kernel: [11161.910030] usb 2-1: config 1 has no interface number 2
Oct 6 11:51:39 MyHostName kernel: [11161.910032] usb 2-1: config 1 has no interface number 3
Oct 6 11:51:39 MyHostName kernel: [11161.925120] usb 2-1: configuration #1 chosen from 1 choice
Oct 6 11:51:39 MyHostName kernel: [11161.928050] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Oct 6 11:51:39 MyHostName kernel: [11162.000738] scsi22 : SCSI emulation for USB Mass Storage devices
Oct 6 11:51:39 MyHostName kernel: [11162.014550] scsi23 : SCSI emulation for USB Mass Storage devices
Oct 6 11:51:44 MyHostName pppd[16935]: pppd 2.4.4 started by root, uid 0
Oct 6 11:51:44 MyHostName pppd[16935]: Using interface ppp0
Oct 6 11:51:44 MyHostName pppd[16935]: Connect: ppp0 <--> /dev/ttyACM0
Oct 6 11:51:44 MyHostName kernel: [11166.996285] scsi 22:0:0:0: CD-ROM CMOTECH Mass Storage 2.31 PQ: 0 ANSI: 0 CCS
Oct 6 11:51:44 MyHostName kernel: [11167.004604] sr3: scsi3-mmc drive: 0x/0x caddy
Oct 6 11:51:44 MyHostName kernel: [11167.004722] sr 22:0:0:0: Attached scsi generic sg2 type 5
Oct 6 11:51:44 MyHostName kernel: [11167.023230] scsi 23:0:0:0: Direct-Access CMOTECH Mass Storage 2.31 PQ: 0 ANSI: 6
Oct 6 11:51:44 MyHostName kernel: [11167.028202] sd 23:0:0:0: [sdb] 102401 512-byte hardware sectors (52 MB)
Oct 6 11:51:44 MyHostName kernel: [11167.031191] sd 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:51:44 MyHostName kernel: [11167.040181] sd 23:0:0:0: [sdb] 102401 512-byte hardware sectors (52 MB)
Oct 6 11:51:44 MyHostName kernel: [11167.043168] sd 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:51:44 MyHostName kernel: [11167.043182] sdb:
Oct 6 11:51:44 MyHostName kernel: [11167.053197] sd 23:0:0:0: [sdb] Attached SCSI removable disk
Oct 6 11:51:44 MyHostName kernel: [11167.053253] sd 23:0:0:0: Attached scsi generic sg3 type 0
Oct 6 11:51:45 MyHostName kernel: [11167.217889] sr: Sense Key : No Sense [current]
Oct 6 11:51:45 MyHostName kernel: [11167.217891] sr: Add. Sense: No additional sense information
Oct 6 11:51:45 MyHostName kernel: [11167.930673] sr: Sense Key : No Sense [current]
Oct 6 11:51:45 MyHostName kernel: [11167.930678] sr: Add. Sense: No additional sense information
Oct 6 11:51:45 MyHostName kernel: [11167.937663] sr: Sense Key : No Sense [current]
Oct 6 11:51:45 MyHostName kernel: [11167.937667] sr: Add. Sense: No additional sense information
Oct 6 11:51:45 MyHostName kernel: [11167.944779] sr: Sense Key : No Sense [current]
Oct 6 11:51:45 MyHostName kernel: [11167.944782] sr: Add. Sense: No additional sense information
Oct 6 11:51:45 MyHostName kernel: [11167.964621] sr: Sense Key : No Sense [current]
Oct 6 11:51:45 MyHostName kernel: [11167.964625] sr: Add. Sense: No additional sense information
Oct 6 11:51:52 MyHostName pppd[16935]: CHAP authentication succeeded
Oct 6 11:51:52 MyHostName pppd[16935]: local IP address 78.28.70.248
Oct 6 11:51:52 MyHostName pppd[16935]: remote IP address 192.168.51.13
Oct 6 11:51:52 MyHostName pppd[16935]: primary DNS address 81.21.240.1
Oct 6 11:51:52 MyHostName pppd[16935]: secondary DNS address 81.21.255.1
Oct 6 11:55:38 MyHostName kernel: [11399.841959] usb 2-1: reset full speed USB device using uhci_hcd and address 68
Oct 6 11:55:38 MyHostName kernel: [11400.404954] usb 2-1: reset full speed USB device using uhci_hcd and address 68
Oct 6 11:55:39 MyHostName kernel: [11400.971943] usb 2-1: reset full speed USB device using uhci_hcd and address 68
Oct 6 11:55:39 MyHostName kernel: [11401.496005] usb 2-1: reset full speed USB device using uhci_hcd and address 68
Oct 6 11:55:40 MyHostName kernel: [11401.906379] usb 2-1: USB disconnect, address 68
Oct 6 11:55:40 MyHostName pppd[16935]: Modem hangup
Oct 6 11:55:40 MyHostName kernel: [11401.907233] sd 23:0:0:0: [sdb] READ CAPACITY failed
Oct 6 11:55:40 MyHostName kernel: [11401.907238] sd 23:0:0:0: [sdb] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK,SUGGEST_OK
Oct 6 11:55:40 MyHostName kernel: [11401.907243] sd 23:0:0:0: [sdb] Sense not available.
Oct 6 11:55:40 MyHostName kernel: [11401.913503] VFS: busy inodes on changed media.
Oct 6 11:55:40 MyHostName kernel: [11401.915616] sd 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:55:40 MyHostName pppd[16935]: Connect time 3.8 minutes.
Oct 6 11:55:40 MyHostName pppd[16935]: Sent 83497 bytes, received 250562 bytes.
Oct 6 11:55:40 MyHostName kernel: [11401.915973] sd 23:0:0:0: [sdb] READ CAPACITY failed
Oct 6 11:55:40 MyHostName kernel: [11401.915976] sd 23:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
Oct 6 11:55:40 MyHostName kernel: [11401.915981] sd 23:0:0:0: [sdb] Sense not available.
Oct 6 11:55:40 MyHostName kernel: [11401.915995] sd 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:55:40 MyHostName kernel: [11401.917115] scsi 23:0:0:0: [sdb] READ CAPACITY failed
Oct 6 11:55:40 MyHostName kernel: [11401.917117] scsi 23:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
Oct 6 11:55:40 MyHostName kernel: [11401.917122] scsi 23:0:0:0: [sdb] Sense not available.
Oct 6 11:55:40 MyHostName kernel: [11401.917130] scsi 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:55:40 MyHostName kernel: [11401.917165] scsi 23:0:0:0: [sdb] READ CAPACITY failed
Oct 6 11:55:40 MyHostName kernel: [11401.917168] scsi 23:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
Oct 6 11:55:40 MyHostName kernel: [11401.917172] scsi 23:0:0:0: [sdb] Sense not available.
Oct 6 11:55:40 MyHostName kernel: [11401.917180] scsi 23:0:0:0: [sdb] Write Protect is off
Oct 6 11:55:40 MyHostName pppd[16935]: Connection terminated.
Oct 6 11:55:40 MyHostName pppd[16935]: Exit.
#Uuesti ühendamisel USB porti
Oct 6 12:01:48 MyHostName kernel: [11769.727230] usb 2-1: new full speed USB device using uhci_hcd and address 80
Oct 6 12:01:49 MyHostName kernel: [11770.286245] usb 2-1: new full speed USB device using uhci_hcd and address 81
Oct 6 12:01:49 MyHostName kernel: [11770.806310] usb 2-1: new full speed USB device using uhci_hcd and address 82
Oct 6 12:01:57 MyHostName kernel: [11778.152233] usb 2-1: new full speed USB device using uhci_hcd and address 83
Oct 6 12:01:57 MyHostName kernel: [11778.711237] usb 2-1: new full speed USB device using uhci_hcd and address 84
Oct 6 12:01:58 MyHostName kernel: [11779.274238] usb 2-1: new full speed USB device using uhci_hcd and address 85
Oct 6 12:01:58 MyHostName kernel: [11779.793312] usb 2-1: new full speed USB device using uhci_hcd and address 86
Oct 6 12:02:06 MyHostName kernel: [11787.375802] usb 2-1: new full speed USB device using uhci_hcd and address 87
Oct 6 12:02:13 MyHostName kernel: [11794.802582] usb 2-1: new full speed USB device using uhci_hcd and address 88
Oct 6 12:02:14 MyHostName kernel: [11795.361590] usb 2-1: new full speed USB device using uhci_hcd and address 89
Oct 6 12:02:14 MyHostName kernel: [11795.920583] usb 2-1: new full speed USB device using uhci_hcd and address 90
Oct 6 12:02:15 MyHostName kernel: [11796.439663] usb 2-1: new full speed USB device using uhci_hcd and address 91
Oct 6 12:02:32 MyHostName kernel: [11813.353545] usb 2-1: new full speed USB device using uhci_hcd and address 92
Oct 6 12:02:32 MyHostName kernel: [11813.916536] usb 2-1: new full speed USB device using uhci_hcd and address 93
Oct 6 12:02:33 MyHostName kernel: [11814.475553] usb 2-1: new full speed USB device using uhci_hcd and address 94
Oct 6 12:02:34 MyHostName kernel: [11814.994620] usb 2-1: new full speed USB device using uhci_hcd and address 95
Oct 6 12:02:49 MyHostName kernel: [11830.631767] usb 2-1: new full speed USB device using uhci_hcd and address 96
Oct 6 12:02:50 MyHostName kernel: [11831.193770] usb 2-1: new full speed USB device using uhci_hcd and address 97
Oct 6 12:02:50 MyHostName kernel: [11831.752776] usb 2-1: new full speed USB device using uhci_hcd and address 98
Oct 6 12:02:51 MyHostName kernel: [11832.272842] usb 2-1: new full speed USB device using uhci_hcd and address 99
Oct 6 12:03:18 MyHostName kernel: [11859.291731] usb 2-1: new full speed USB device using uhci_hcd and address 100
Oct 6 12:03:18 MyHostName kernel: [11859.850734] usb 2-1: new full speed USB device using uhci_hcd and address 101
Oct 6 12:03:19 MyHostName kernel: [11860.413730] usb 2-1: new full speed USB device using uhci_hcd and address 102
Oct 6 12:03:20 MyHostName kernel: [11860.932807] usb 2-1: new full speed USB device using uhci_hcd and address 103
Oct 6 12:04:20 MyHostName kernel: [11921.624722] usb 2-1: new full speed USB device using uhci_hcd and address 104
Oct 6 12:04:21 MyHostName kernel: [11922.184723] usb 2-1: new full speed USB device using uhci_hcd and address 105
Oct 6 12:04:21 MyHostName kernel: [11922.742730] usb 2-1: new full speed USB device using uhci_hcd and address 106
Oct 6 12:04:22 MyHostName kernel: [11923.261806] usb 2-1: new full speed USB device using uhci_hcd and address 107
Oct 6 12:05:11 MyHostName kernel: [11971.715689] usb 2-1: new full speed USB device using uhci_hcd and address 108
Oct 6 12:05:11 MyHostName kernel: [11972.282510] usb 2-1: new full speed USB device using uhci_hcd and address 109
Oct 6 12:05:12 MyHostName kernel: [11972.841516] usb 2-1: new full speed USB device using uhci_hcd and address 110
Oct 6 12:05:12 MyHostName kernel: [11973.360595] usb 2-1: new full speed USB device using uhci_hcd and address 111 |
