praegune kellaaeg 05.11.2026 16:09:38
Osiris
11.09.2008 08:10:12
Squirrelmail ja parooli muutmine |
Jõudu.
On siis mailiserver kus jookseb veebikliendina squirrelmail.
Sai pandud peale paroolimuutmise lisaplugin - aga ei tööta millegipärast see.
Annab sellise teate:
Warning: fsockopen() [function.fsockopen]: unable to connect to localhost:106 (Connection refused) in //www/plugins/change_pass/options.php on line 140
Faili options.php 140 rida sisaldab sellist:
$pop_socket = fsockopen($poppass_server, $poppass_port, $errno, $errstr);
mis siis omakorda küsib vastavad andmed failist settings.php
<?php
global $imapServerAddress;
/* Use the address of the IMAP server as the default */
$poppass_server = $imapServerAddress;
$poppass_server = 127.0.0.1;
/* The default port for poppassd is 106 */
$poppass_port = 106;
Teab keegi kuidas seda asja lahendada?
Tegemist siis selle pluginaga http://www.squirrelmail.org/plugin_view.php?id=21
103 |
sander85
11.09.2008 19:12:16
see sama leht, mida näitasid, teine rida lehe sisus:
For a list of poppass daemons, see the included README file.
_________________ Think of how stupid the average person is, and realize half of them are stupider than that.
-- G. Carlin |
Osiris
11.09.2008 20:49:49
| sander85 kirjutas: |
For a list of poppass daemons, see the included README file. |
Kui see oleks aidanud - poleks ma siin seda teemat teinud
103 |
