sõnum  |
Andrus Luht
itimees.ee
| Kommentaarid: 376 loe/lisa |
318 |
Spezz
| Kommentaarid: 65 loe/lisa |
61 |
AJ
12.12.2009 23:58
First generation Intel SSDs to retire in August
http://www.nordichardware.com/news,10400.html
Intel haven't been all that kind to those to jumped at the first wave of SSDs. After Intel launched the second generation of SSDs sporting 34nm technology the so called G1 units have ended up the shadow. Intel recently released a new firmware with TRIM support for the 34nm drives, something the G1 drives still lack and will most likely never get. Intel is even planning the retirement of the first generation of SSD in August next year.
We know that Intel will release new and updated version of its 34nm drives in Q2 2010 and then it will stop taking orders for its G1 drives. The last shipment of 50nm solid state drives will head out on August 7th.
What kind of treatment the G1 owners will get until then, and after the retirement, is hard to say. Since the support has already been a bit poor we have no real hope for it to improve. Intel's decision will affect all X25-M and X18-M models made with 50nm technology. |
| Kommentaarid: 37 loe/lisa |
36 |
24.12.2009 07:49
Hea uudis ja kaks halba uudist.
Hea uudis on see, et tulevad uued 34nm protsessil põhinevad X-25E SSD-d mahtudega 100,200 ja 400GB
Halvad uudised on esiteks need, et nad tulevad alles Q4 2010 seega umbes aasta pärast alles ja veel halvem uudis on see, et nad põhinevad MLC tehnoloogial mitte SLC nagu senised X-25E märgistusega Inteli SSD-d
Seega ilmselt ohverdati kiirus mahu kasuks
Intel's new SSDs are codenamed Lyndonville
http://www.fudzilla.com/content/view/16960/1/
| Kommentaarid: 83 loe/lisa |
73 |
AJ
36 |
73 |
1dumbpcuser
11.01.2010 11:27
Intel's 40GB Value SSD Selling at $129.99
TomsHW
| Kommentaarid: 87 loe/lisa |
83 |
AJ
11.01.2010 22:02
Intel details SSD plans for 2010
http://techreport.com/discussions.x/18272
We met with Intel at CES last week to discuss the company's plans for new solid-state drives in 2010. After a year that saw the X25 series make Intel the market leader in retail and e-tail, the chip giant is planning to lower prices with an eye towards moving greater SSD volumes in the mainstream market. A new generation of drives based on die-shrunk flash memory will apparently enable the next wave of discounts. Intel says its forthcoming batch of client and enterprise SSDs will use flash memory built on a 2x-nano process, although it wasn't more specific about the fabrication tech.
While it didn't reveal when those new drives will arrive, we can apparently expect higher capacities than are available with Intel's existing X25-series SSDs. Support for the 6Gbps Serial ATA standard isn't on the menu until 2011, though. That's when Intel will have core-logic chipsets designed to take advantage of the higher transfer rates enabled by the new SATA spec.
Without a faster host interface, new Intel SSDs won't be pushing more than 300MB/s. Intel did, however, say that it was concentrating on improving sequential write speeds to saturate the existing 3Gbps pipe. Sequential write performance has been a relative weak point for the last two generations of X25-M drives.
Since it's focusing on mainstream adoption this year, Intel is also looking at making disk cloning easier for those who buy its drives. We've already seen Kingston bundle offer an easy upgrade kit that includes disk-cloning software, and I wouldn't be surprised if Intel comes up with a similar retail kit of its own. |
36 |
73 |
Terror
11.04.2010 08:00
x25-V seerial on maru aeglane kirjutamis kiirjus ju? Või ei anna see praktikas eriti tunda?
_________________ Väiksemagabariidilised trei, frees ning keevitustööd. PS. |
| Kommentaarid: 98 loe/lisa |
89 |
DVDRW
11.04.2010 12:19
Vaatasin ka seepärast alguses sellest kettast kaarega mööda, aga pärast sain aru.
x25-V seerial on aeglane suurte failide kirjutamiskiirus (testitud 44MB/s), kuid siiski on see tsipa 2,5" 7200rpm läptopist kiirem.
See annaks tunda suure faili kopeerimisel SATA kettalt SSDle ja videotöötlusel kompressimata video salvestamisel SSD-le. Sellist olukorda eriti ette ei tule ja ei ole vaja, sest ketas on ju niigi sellejaoks väike (40GB). Selleks sobib paremini eraldi SATA 2x1TB RAID0
See ka ainuke puudus selle SSD juures aga IOPS on võrreldes teiste SSDd-ega sigahea (mõjutab arvuti erksust ja multitaskingu kiirust).
Kui raha rohkem võib kaaluda läpakale X25-M (2x kiirem suurte failide kirjutamisel) ja lauaarvutile 2x X25-V RAID0 ostmist.
| Kommentaarid: 21 loe/lisa |
20 |
Killhoven
OC`er
12.04.2010 12:31
Võtsin endale lauakasse süsteemikaks X25-M G2 80 ligi
Kiire küsimus. Te jooksutate seda ACHi või IDE modes?
kiire googeldamise järel sain teada, et üldjuhul (teise firma ketastega) on IDE kiirem. Siin üks IDE/ACHI võrdlus.
Samas Inteli puhul soovitatakse NCQ pärast ACHI mode (lubab hot-swaping, eriline improvement pidi väikeste random lugemistega olema).
SATA Controller Mode Conclusion
In conclusion, Benchmark Reviews has demonstrated that IDE controller mode on the Intel ICH10 SATA-3.0 interface is superior at delivering the fastest SSD bandwidth speeds and best operational IOPS performance. While there were some rare exceptions, IDE-mode offered better SSD test results overall. Some enthusiasts have a combination of SSD and HDD in their computer system, so unless the AHCI-specific features of hot-swappable drives or Native Command Queuing (NCQ) are needed then basic IDE-mode is the best choice for SATA-based Solid State Drive storage devices.
But what about SSD TRIM?
TRIM is non-specific to SATA controller modes, and will work equally well in both IDE and AHCI-mode. Benchmark Reviews will soon publish a detailed report that illustrates the recovery levels for each of the SSD controllers tested here. |
Siin juttu, kuidas peale installi seda enableda (Win install keerab kinni kuna ei vaja installeerimisel).
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 338 loe/lisa |
296 |
tqz
12.04.2010 15:13
| Mina kasutan AHCI-d, alguses oli IDE-s. Tavakasutuses aru ei saa, et vahet oleks, aga AHCI-s on Windows Experience Indexi HDD skoor kõrgem (7,5 IDE vs 7,7 AHCI).
| Kommentaarid: 54 loe/lisa |
52 |
Spezz
12.04.2010 19:30
| Kas mitte AHCI modes TRIM support kaduma ei lähe?
61 |
Killhoven
OC`er
12.04.2010 19:31
| Spezz kirjutas: |
| Kas mitte AHCI modes TRIM support kaduma ei lähe? |
Ei.
296 |
Spezz
12.04.2010 21:54
| Killhoven kirjutas: |
| Spezz kirjutas: |
Ei. |
Ok, lugesin pisut. TRIM toimib tõepoolest, eeldusel, et kasutatakase Microsofti AHCi native draiverit. Kindlam valik on siiski IDE.
61 |
12.04.2010 23:32
Annaks tootja enda AHCI draiver märgatava kiiruseelise?
Sest kui vahe jääks kuni 10% piiresse siis ma pigem võtaks NCQ
73 |
Killhoven
OC`er
13.04.2010 07:03
Veel üks hea lugu, miks ACHI hea on ja kuidas seda peale Win XP installi enableda. Win 7 õpetus siin.
Põhimõte siis selles, et ACHI modes Win ei saa installida - seda peab tegema IDE modes. Kui peale installi BIOS-ist ACHI peale keerata, siis ei tule Win aga enam üles (Win disableb ACHI driverid). Vaja on ennem Win-is paar liigutust ära teha ja need on õpetuses kenasti kirjas.
E: ACHI is a good thing
296 |
Andrus Luht
itimees.ee
318 |
Killhoven
OC`er
13.04.2010 07:59
| Andrus Luht kirjutas: |
| Killhoven, mina olen AHCI mode's installinud nii XP'd, Vista't kui ka 7't. Töötab suurepäraselt... |
Huvitav. Ilmselt on sellele mingi loogiline seletus (tehnoloogiliselt aegunud artiklid - uued mobod?). Peab uurima ja täna-homme saan ka ise proovida
296 |
Spezz
13.04.2010 10:14
| XP puhul oli vist vaja F6 vajutada ja draiverid diskilt sööta?
61 |
DonNiger
13.04.2010 10:42
Ei saa nüüd pihta, kumb parem siis on - IDE või ACHI mode?
| Kommentaarid: 140 loe/lisa |
114 |
tqz
13.04.2010 11:46
| AHCI peaks pisut kiirem olema.
52 |
DonNiger
13.04.2010 12:17
Selle järgi aga IDE
Siin juttu, kuidas peale installi seda enableda (Win install keerab kinni kuna ei vaja installeerimisel). |
114 |
tqz
13.04.2010 12:29
Kas see punane tekst käib Intel X25 kohta või on see mingi üldine jutt?
Sinu enda tsiteeritud postiski on öeldud, et Inteli puhul soovitatakse AHCI-d, kuna random lugemised on sellega kiiremad.
Ise pole nende vahet testinud, kuid googeldades leidsin sellise võrdluse:
52 |
