praegune kellaaeg 24.10.2026 15:41:16
SibulonHEA
28.08.2008 15:11:52
BSOD |
Mängin mingit suvalist mängu. Lihtsalt mingil hetkel kaovad mängul asjad ära ja siis viskab monitor pilti eest ja hakkab näitama Analog,Digital,Analog nurgas ja hetke pärast tuleb Blue Screen Of Death ja seal näitab mingid nvldmds.sys at E4353 to 453dg mingit sellist soga ja Mingi Memory Dump värki.
Halp!
_________________ Täielik Noob. |
heikis
28.08.2008 15:20:31
oled kindel, et nvldmds.sys ? sest google ei leia sellist lühendit isegi faililaiendita
kui ikka kurtma tulete, siis andke võimalikult täpselt veakoodid
| Kommentaarid: 339 loe/lisa |
291 |
725 |
SibulonHEA
28.08.2008 17:18:49
see faili nimi oli jah vale kuna see bsod oli nii vähe aega polnu aega pähe õppida .
aga leidsin sellise fixi.
> > I have found and fixed the problem today. This is what appears to
> > happen.
> > during the installation of the most current drivers 100.65 Vista, an
> > OLD file
> > nvlddmkm.sys is copied into windows/system32/drivers and not the
> > current one
> > in the install. As a result the new drivers are attempting to access a
> > file
> > dated 11/2006 instead of 2/2007 ver 7.15.11.0065 which is in the newest
> > WHQL
> > driver ver 100.65 vista 32.
> > Fix: Go to windows/system32/drivers and rename nvlddmkm.sys to
> > nvlddmkm.sys.old. Go to the nvidia directory and find the file
> > nvlddmkm.sy_
> > and copy it to windows/system32. Using the cmd window (DOS box) type
> > EXPAND.EXE nvlddmkm.sy_ nvlddmkm.sys. When the expansion is complete,
> > copy
> > the new nvlddmkm.sys to windows/system32/drivers and restart the
> > computer.
> > Your computer should now work properly.
> > You will notice that any uninstall and reinstall of nvidia drivers will
> > not
> > remove the old nvlddmkm.sys file and will not overwrite it with the
> > newer
> > version. You have to do it manually. I do not know why this happens
> > but who
> > cares as long it is fixed.
> > Good luck...
> > "Hohen" wrote:
> > > I have the same problem when I install vista, but there thi problem
> > also windows xp and the bug ar localized on "CPU to AGP" driver. I need
> > to install VIAGART file driver contained in VIA-Hyperion package....
> > maybe run under Vista.
> > > EggHeadCafe.com - .NET Developer Portal of Choice
> > > http://www.eggheadcafe.com
> hetaali
Kas see trikk on ohutu muidu?
