praegune kellaaeg 18.11.2026 00:49:10
AMD
23.08.2008 12:31:52
Häda wifi tööle saamisega |
Wifi kaardi peaks olema lspci järgi selline
Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
dmesg näitab
iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, 1.2.26kds
iwl3945: Copyright(c) 2003-2008 Intel Corporation
iwl3945 0000:04:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
iwl3945 0000:04:00.0: setting latency timer to 64
iwl3945: Detected Intel Wireless WiFi Link 3945ABG
iwl3945: Tunable channels: 13 802.11bg, 23 802.11a channels
iwl3945 0000:04:00.0: PCI INT A disabled
Ja draiveriks nimi peaks olema iwl3945
Kui kõik hästi läheb, siis saab võrgu tööle pärast järgmise käske:
/etc/init.d/net.wlan0 start
dhclient wlan0 |
Ja kui ei lähe hästi, siis ei oska enam midagi teha :\
# ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr 00:19:d2:85:d3:eb
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) |
# iwconfig wlan0
wlan0 IEEE 802.11abg ESSID:"Midaiganes"
Mode:Managed Frequency:2.417 GHz Access Point: Not-Associated
Tx-Power=15 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0 |
Ühenduda tahaks sellise asja külge:
iwlist wlan0 scan väljund:
Cell 03 - Address: 00:18:84:24:76:FA
ESSID:"Midaiganes"
Mode:Master
Channel:2
Frequency:2.417 GHz (Channel 2)
Quality=88/100 Signal level:-44 dBm Noise level=-127 dBm
Encryption key:on
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (1) : TKIP
Authentication Suites (1) : PSK
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
48 Mb/s; 54 Mb/s
Extra:tsf=0000000a07ad0181
Extra: Last beacon: 653ms ago |
/etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=1000
network={
ssid="Midaiganes"
scan_ssid=1
key_mgmt=WPA-PSK
psk="1234567890"
Pärast /etc/init.d/net.wlan0 start'i tekib dmesg'i
iwl3945 0000:04:00.0: restoring config space at offset 0x1 (was 0x100102, writing 0x100106)
firmware: requesting iwlwifi-3945-1.ucode
Registered led device: iwl-phy0:radio
Registered led device: iwl-phy0:assoc
Registered led device: iwl-phy0:RX
Registered led device: iwl-phy0:TX
wlan0: authenticate with AP 00:18:84:24:76:f9
wlan0: authenticated
wlan0: associate with AP 00:18:84:24:76:f9
wlan0: authenticate with AP 00:18:84:24:76:fa
wlan0: authentication with AP 00:18:84:24:76:fa timed out
wlan0: authentication with AP 00:18:84:24:76:fa timed out |
viimased read jäävad lõpmatuseni korduma
Äkki keegi aitaks selle asja tööle saada...
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
| Kommentaarid: 335 loe/lisa |
145 :: |
12 |
sander85
24.08.2008 00:20:59
antud kaardile peaks olema ka ipw3945 draiver, mis on aegajalt end paremini tõestand, peale dmesgi ei teeks paha ka näiteks syslogi read võrguga ühendamise kohta.. ja kas distro on profiilis mainitud gentoo või on see midagi muud?
_________________ Think of how stupid the average person is, and realize half of them are stupider than that.
-- G. Carlin |
AMD
24.08.2008 09:32:10
Distroks on gentoo jah.
Hetkel hakkas kõik ilust tööle
# /etc/init.d/net.wlan0 start
net.wlan0 | * Bringing up interface wlan0
net.wlan0 | * Starting wpa_supplicant on wlan0 ...
net.wlan0 |ioctl[SIOCSIWAUTH]: Operation not supported [ ok ] # see rida tundub kahtlane siiski...
net.wlan0 | * Starting wpa_cli on wlan0 ... [ ok ]
net.wlan0 | * Backgrounding ... ...
net.wlan0 | * WARNING: net.wlan0 has started, but is inactive
# dmesg lõpp
wlan0: associate with AP 00:18:84:24:76:fa
wlan0: RX AssocResp from 00:18:84:24:76:fa (capab=0x431 status=0 aid=1)
wlan0: associated
wlan0: deauthenticated
wlan0: RX ReassocResp from 00:18:84:24:76:fa (capab=0x431 status=0 aid=1)
wlan0: associated
# dhclient wlan0
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:19:d2:85:d3:eb
Sending on LPF/wlan0/00:19:d2:85:d3:eb
Sending on Socket/fallback
DHCPREQUEST on wlan0 to 255.255.255.255 port 67
DHCPACK from 192.168.10.1
bound to 192.168.10.130 -- renewal in 18551 seconds.
Aga eks ma proovi teist draiverit ka siis.
145 :: |
12 |
Allstar
07.11.2010 12:59:00
Kas see on normaalne, et WPA2 võrgus olles encryption key läheb off'i peale? Mingi perioond iwconfig näitab, et võtmeks 256 bit kood ent natukese aja pärast läheb alati maha. Peale mida pean jälle käsitsi üles tooma käsuga iwconfig wlan0 enc [2]. Kuidas teha et see oleks nõnda jäädavalt?
_________________ Allstar |
| Kommentaarid: 56 loe/lisa |
52 |
