Lord Ami
12.08.2008 20:10:46
Pakkumine: ZoneAlarm ForceField tasuta! Ainult täna |
http://download.zonealarm.com/bin/free/sum/index.html#
Siit saate tasuta ZAFF mis kaitseb arvutit mitmel moel.Ei viitsi hakata tõlkima.
Virtual Browsing - Builds a protective shield around your web browser. It creates a temporary clone of your browser so that anything you do on the web runs in a protected shell, sealed off from your PC.
Browser Threat Immunity - Immunizes your browser against security holes in Internet Explorer and Firefox. Prevents web sites from installing spyware and other malicious software onto your computer without your knowledge.
Private Browser - Erases all cache, cookies, history and passwords from the current session when you close the browser. This prevents the next person who uses the computer from seeing where you've been.
Keylogger & Screengrabber Jamming - Keeps your keystrokes and click trails private. Discovers and blocks silent spyware from stealing your identity.
Dangerous Download Detection - Detects dangerous downloads and alerts you to problems before they begin. You can download files safely, and free from worry that they might harm your computer.
Anti-Phishing - Click where you want, your personal information remains secure. Dual-engine anti-phishing identifies and stops fraudulent websites that trick you into revealing personal data.
Spy Site Blocking- Prevents spyware from infiltrating your PC by detecting and blocking websites known to distribute spyware.
Website Safety Check - Checks the credentials on every website you visit, so you know if the website is a safe place to enter data and download files.
Spyware Flushing - Auto-cleans your Web browser memory each time you close it, wiping away spyware and other dangers.
On-The-Fly Encryption - Temporary file encryption protects the data you enter online from spyware for an additional measure of security.
Seamless Integration - Compatible with all popular web browsers, including Internet Explorer and Firefox on XP and Vista.
Security Software Compatibility - Run ZoneAlarm ForceField with your current antivirus or security suite, for an essential level of critical web protection you would not have otherwise. It is compatible with all security software currently on the market.
Fast and Easy to Use - Installs in seconds and runs fast so it won't slow you down. You can surf the web like always, knowing your PC is protected. ZoneAlarm ForceField runs automatically, without any setup or training.
Põhiliselt peaks ära hoima paroolilekked ja ka phishing pahavara, mille alla kuuluvad näiteks liba viiruse/nuhkvara jms tõrjed, kus püüdakse nakatunud arvuti kasutajat liba tõrjet ostma meelitada.Sellega aga kaasnevad suured kulud, kuna krediitkaart on sellega kurjamite valduses.
Eks proovige ise ära
PS: Tasuta versiooni saate siis, kui täna installite ja aktiveerite!
| Kommentaarid: 57 loe/lisa |
52 |
Anna tooli
12.08.2008 20:16:19
| Üritasin seal siis end kirja panna, kuid: An internal system error has occured.
300 |
Lord Ami
12.08.2008 20:18:24
Mul küll kõik korras
Kliki sinna suurele pildile...seal avaneb väike aken kuhu tuleb sisestada natuke andmeid.
Soovitan seda soojalt neile, kes koguaeg nende MSNi parooliõngitsejatega jagelevad
52 |
Anna tooli
12.08.2008 20:24:09
| Lord Ami kirjutas: |
| Kliki sinna suurele pildile...seal avaneb väike aken kuhu tuleb sisestada natuke andmeid. |
Enne tegingi seda.
Nüüd regasin end seal ära ning download link ilusasti e-kirjakastis
300 |
Lord Ami
12.08.2008 20:32:19
Kaldun arvama, et minu arvutis sellele programmile kohta pole
Liiga suur ressursiõgrad, ca 130MB ram selle ZAFFi 3 protsessi.
52 |
Anna tooli
12.08.2008 20:37:49
| Heh, mul kolme protsessiga ~7,2MB
300 |
svenman
12.08.2008 21:34:31
| 4,5 mega kolme protsessiga siinpool. Huvitav millest see sõltub?
| Kommentaarid: 80 loe/lisa |
71 |
Lord Ami
12.08.2008 21:51:20
Ei oska öelda.Hiljem proovin reinstalli
52 |
Anna tooli
12.08.2008 22:00:55
Võibolla kui jätta see ZA toolbar brauserile nähtavaks, röövib hirmsasti mälu
300 |
Lord Ami
12.08.2008 22:06:00
Võib-olla tõesti.Pole katsetanud
Homme teen "katseid"
AKLT teste läbis ZAFF edukalt.Isegi screenshoti omi
52 |
biomehanik
13.08.2008 02:07:23
aga on see siis ka väärt programm ? ja võib seda kasutada ka kui on Kaspersky Anti Virus masinas juba ? ja ehk oskab juba keegi siin soovitada veel spyware ja muu pahna eemdajat... kumb etem oleks kas spyware doctor või ad-aware või muud midagi ?
| Kommentaarid: 260 loe/lisa |
227 |
maxsimiljo
13.08.2008 02:10:26
| Vistal töötab ilusti?
| Kommentaarid: 28 loe/lisa |
28 |
biomehanik
13.08.2008 02:55:18
ma installisin ja lasin maha, ei meeldi siuke vidin ... tahad oma mp3 kasvõi tõmmata või misiganes siis küsib 2x jutti ikka kinnituseks et kas soovid ja tahad...ei osanud maha kah võtta ja ei tea kas saabki ... jutt siiski XP.st
227 |
RPG16
13.08.2008 02:59:09
| Installisin, täitsa meeldib see asi, winxp ja 1gb rammi, seega ei ole mälukasutus mingi probleem
| Kommentaarid: 203 loe/lisa |
166 |
svenman
13.08.2008 18:37:01
| Vista peal töötab nagu kulda.
71 |
17.08.2008 04:23:04
Liiga palju igasugu mõttetuid vidinaid sellele külge poogitud. Vahepeal proovisin nii ZA kui ka Comodot, aga mõlemaid jäingi seadistama. Lisaks ei meeldinud kummagi võrgupoliitika. Esimesed uuema aja tulemüüriprogrammid, kus pidin alla tirima kasutusjuhendid, et täpselt teada saada, mida üks või teine asi teeb. Sigh!
| Kommentaarid: 763 loe/lisa |
571 |
