praegune kellaaeg 07.08.2026 18:07:58
jpt
11.08.2008 10:56:52
Probleem piltide úleslaadimisega teatud lehele |
Niisiis,
úritades laadida pilti ühele veebis asuvale fotokontole tekib párast faili valimist ja "upload"-nupu vajutamist koheselt silme ette tavaline "connection closed by remote server" error.
Mujale piltide úles laadimine probleeme ei tekita, ainult sellele lehele. Teiste arvutite taga on úleslaadimine antud lehele ja kontole vóimalik. Úhenduste vahetamine ei aita.
Asi páris kindlalt arvutis, mis toimub?
Error!
Connection closed by remote server
You tried to access the address http://*****.com/upload, which is
currently unavailable.
Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy
to connect to the Internet. Reload the page. |
Ei osanud teemat kusagile mujale teha. Siiani tegutsenud rohkem muudes alamfoorumites... Kui tarvis, palun liigutada teemat...
viimati muutis jpt 25.03.2014 20:06:38, muudetud 1 kord |
| Kommentaarid: 22 loe/lisa |
22 |
airm
11.08.2008 12:50:10
Mängi proxy-aadressidega.
Kui on peal, võta maha.
Kui maas, vaheta proxy-aadresse brouseris
| Kommentaarid: 56 loe/lisa |
50 |
jpt
16.08.2008 02:28:07
| Tánud, probleem lahenenud.
22 |
