praegune kellaaeg 11.11.2026 20:18:13
Ohohh
20.06.2008 10:27:35
[C/C++] linux socketid |
Ma ei saa kuidagi socketeid korralikult tööle...
Leidsin sellise näidiskoodi:
See ei ole enam oma algsel kujul. Näiteks väline while tsükkel on minu lisatud (võibolla on valesti, kuna ei tea täpselt mida tuleb socketi uuesti ühendamisel välja kutsuda)
| c++:
/* * Description: * tcp server example * tcp echo server: listen tcp port 4000, and echo back the received data. * * What is shown in this example: * 1. How to program a tcp echo server * */ #include <stdio.h> #include <errno.h> #include <sys/socket.h> #include <arpa/inet.h> #include <netinet/in.h> #include <string.h> #include <unistd.h> #include <iostream> using namespace std; int main(int argc, char *argv[]) { int fd_listen, fd_client, ret; socklen_t size; struct sockaddr_in dest; char buf[1024]; /*create a socket*/ fd_listen = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP); if (fd_listen < 0) { printf("socket failed\n"); return 0; } /*use bind function to associate an address with a socket*/ bzero(&dest, sizeof(dest)); dest.sin_family = AF_INET; dest.sin_port = htons(4000); dest.sin_addr.s_addr = htonl(INADDR_ANY); bind(fd_listen, (struct sockaddr*)&dest, sizeof(dest)); //linger ling; //ling.l_linger = 0; //ling.l_onoff = 0; while (1) { /*listen 1 connect request*/ listen(fd_listen, 1); size = sizeof(dest); /*retrieve a connect request*/ //setsockopt(fd_listen, SOL_SOCKET, SO_LINGER, &ling, sizeof(linger)); fd_client = accept(fd_listen, (struct sockaddr*)&dest, &size); if (fd_client == -1) { printf("accept failed, errno: %d\r\n", errno); shutdown(fd_listen, SHUT_RDWR); return 0; } printf("accept: %s, port %d\r\n", inet_ntoa(dest.sin_addr), htons(dest.sin_port)); while(1) { /*when data received, send them back*/ ret = recv(fd_client, buf, sizeof(buf), 0); if (ret > 0) { if (buf[0] == 'q') break; send(fd_client, buf, ret, 0); } else if (ret == 0) { printf("disconnect by remote\r\n"); break; } else if (ret < 0) { printf("read from ethernet failed, errno: %d\r\n", errno); break; } } //close(fd_listen); //close(fd_client); shutdown(fd_listen, SHUT_RDWR); shutdown(fd_client, SHUT_RDWR); } return 0; }
Üldiselt antud kood töötab. Kui kirjutada käsureale "telnet 127.0.0.1 4000", siis ühendab ära ja kajab kõik sisestatud märgid tagasi.
Kui telneti sulgen siis teeb korraliku disconnecti ja võin kohe uuesti telnetiga ühenduda.
Kuid probleem tekib, kui disconnecti teeb serveri pool. Lisasin rea, et q tähe korral katkestatakse ühendus. Kuid tundub, et ühendust ei katkestata korralikult, kuna pärast sellist katkestamist on umbes minutine timeout, enne kui seda porti on uuesti võimalik kasutada (kui panin nüüd pordiks näiteks 4001, siis töötab kohe).
Ilmselt tuleb enne shutdown käsku veel midagi välja kutsuda.
Aga ühtki sellist socketi funktsiooni ei tundu sys/socket.h failis olevat ( http://opengroup.org/onlinepubs/007908775/xns/syssocket.h.html )
Lugesin netist, et option SO_LINGER, peaks sellega kuidagi seotud olema. Panin seda ühte ja teise kohta, kuid ei aidanud...
| Kommentaarid: 6 loe/lisa |
troglodyte
20.06.2008 15:48:57
Pead silmas siis seda, et peale serveri programmi sulgemist, ei ole võimalik enam samasse porti (4000) kohe uuesti bindida?
Sellest ümbersaamiseks socketile pealekeerata SO_REUSEADDR :
| c:
int opt = 1; getsockopt(fd_listen, SOL_SOCKET, SO_REUSEADDR, &opt, sizeof(opt));
man 2 setsockopt
| Kommentaarid: 34 loe/lisa |
34 |
Ohohh
20.06.2008 19:38:17
| troglodyte kirjutas: |
| c:
man 2 setsockopt |
Tänud! Proovin varsti järgi.
troglodyte
20.06.2008 19:40:28
| Ohjah, loodetavasti panid tähele väikest typot getsockopt vs setsockopt
34 |
Ohohh
20.06.2008 22:13:07
Suurepärane, töötab!
k2iguvahetaja
22.06.2008 10:19:30
| sourcecode kuskil pastebinis vms. ei saa? siit kopides on reanumbrid ees, mai viitsi neid ära kakkuda. uuriks ka värki.
| Kommentaarid: 45 loe/lisa |
38 |
JannoT
22.06.2008 11:30:26
| k2iguvahetaja kirjutas: |
| sourcecode kuskil pastebinis vms. ei saa? siit kopides on reanumbrid ees, mai viitsi neid ära kakkuda. uuriks ka värki. |
| ot: |
| Üritasid ka üldse copyda seda koodi? Numbreid ei anna copyda. Vähemasti ff3'ga mitte. Plus on olemas ka nupp märgi mis terve teksti ära märgib aga jällegi ilma numbritetta |
_________________ 011010000110100101101110011011100110000101110110011000010110000101110100011011000111010101110011 |
k2iguvahetaja
22.06.2008 19:27:35
| Jepjep, aga kui ma pasten tulevad ikkagi millegipärast numbrid ees? Vahet pole kas kasutan märgi nuppu või hiirega selectin.
38 |
Ohohh
23.06.2008 16:36:32
Seda peaks saama korralikult kopida:
* Description:
#include <stdio.h>
#include <errno.h>
#include <string.h>
#include <unistd.h>
#include <iostream>
socklen_t size;
char buf[1024];
/*create a socket*/
return 0;
int opt = 1;
setsockopt(fd_listen, SOL_SOCKET, SO_REUSEADDR, &opt, sizeof(opt));
while (1) {
return 0;
while(1) {
if (ret > 0) {
break;
break;
//close(fd_listen);
//close(fd_client);
return 0;
tanzanite
26.06.2008 16:10:35
| Jepjep, aga kui ma pasten tulevad ikkagi millegipärast numbrid ees? Vahet pole kas kasutan märgi nuppu või hiirega selectin. |
Üks võimalus sellistel puhkudel on kasutada quote/tsiteeri nuppu ... just saying.
andreie
28.06.2008 13:59:00
Saab ka lihtsamalt, tuleb soketi "fd_listen" avamine tsüklist ettepoole tõsta ja tsükli sees seda üldse mitte kinni panna.
_________________ Unix survives only because everyone else has done so badly. |
