praegune kellaaeg 17.11.2026 23:30:53
Kethmar
17.06.2008 22:28:31
Tiger CMS galerii kood. |
Tervist. Kunagi oli siin foorumis teema sarnane, aga seal ei leitud lõpplahendust, niisiis teen uue teema.
Nimelt mul on selline galerii:
http://www.friday.ee/kethmar/rammukad/?id=67
asi töötab TIGER CMS-i peal.
Kes seda kasutanud on, teab, et galerii kuvamiseks tuleb kood kirjutada sisuhaldus paneeli, minu kood seal on:
<?php gallery();?>
<table width="100%" border="0" cellspacing="0" cellpadding="0">
<?php if (!$_GET[gallery] == !"") { ?>
<tr>
<td valign="top"><strong>Pilt:<br>
<br>
</strong></td>
<td valign="top"><strong>Galerii nimi:<br>
<br>
</strong></td>
<td valign="top"><strong>Pilte:<br>
</strong></td>
</tr>
<?php } ?>
<?php foreach($data['gallerys'] as $val){ ?>
<tr>
<td>
<?php
$image = mysql_query("SELECT * FROM tiger_galeriiseos WHERE kategooria='".$val['id']."' ORDER BY rand() DESC LIMIT 1 ") or die(mysql_error());
while ($i = mysql_fetch_array($image)) {
<a href="<?php echo($_SERVER['PHP_SELF']); ?>?id=<?=$_GET['id'];?>&gallery=<?php echo($val['id']); ?>"><img src="gallery/pictures/<?php echo $i["pilt"]; ?>_thumb.jpg" width="100" height="100"/></a>
<?php } ?>
</td>
<td><a href="<?php echo($_SERVER['PHP_SELF']); ?>?id=<?=$_GET['id'];?>&gallery=<?php echo($val['id']); ?>"><?php echo($val['name']); ?></a></td>
<td><?php $pilte = mysql_result(mysql_query("SELECT COUNT(*) FROM tiger_galeriiseos WHERE kategooria='".$val['id']."' "), 0); ?><?=$pilte?></td>
</tr>
<tr>
<td> </td>
<td> </td>
<td> </td>
</tr>
<?php } ?>
</table>
<?php foreach($data['pictures'] as $val){ ?>
<?php if ($val['extension'] != ""): ?>
<?php mysql_query("UPDATE tiger_galeriikat SET vaatamisi=vaatamisi+1 WHERE id='1' ") or die(mysql_error()); ?>
<a href="gallery/pictures/<?php echo($val['id'].$val['extension']); ?>" onclick="ja siia nt mingi js, mis uue akna avab">
<img src="gallery/pictures/<?php echo($val['id']); ?>_thumb<?php echo($val['extension']); ?>" width="100" height="100"/></a>
<?php endif; ?>
<?php } ?> |
Keegi oskab rääkida, kuidas saaks sellest galeriist, nagu mul praegu on, teha sellise:
http://www.looduskeskus.ee/galerii/index.php
...kasutades seda koodi, mis ette andsin.
Kui keegi vaevub aitama, siis suured tänud, võib ka lihtsalt tarka juttu rääkida .
_________________ Kodulehekülg: http://kethmar.ee/university
Vajad veebilahendust või graafilist abi? Küsi pakkumist. HV Rahvale alati odavamalt. |
| Kommentaarid: 24 loe/lisa |
24 |
AMD
18.06.2008 09:59:38
Mis neil nagu vahet on?
Ma arvan, et kui sinu omale natuke css'i juurde kirjutada, siis on võimalik küllaltki sarnane tulemus saada.
_________________ From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel. |
| Kommentaarid: 335 loe/lisa |
145 :: |
12 |
Kethmar
18.06.2008 13:11:35
Eiei, ma mõtlen just seda, et kui pildile peale vajutada, siis ta näitab pilti leheküljel edasi, üleval on numbrid, mis näitavad, mitmes pilt on/saad kohe uue pildi valida jne.
24 |
