praegune kellaaeg 11.11.2026 13:47:04
mark11
15.06.2008 13:27:22
elu ei õpeta, PHP probleem |
olen selle probleemiga kaua jamanud, mitte just probleem aga sattusin asja taha millest jagu ei saa mitte kuidagi
nimelt siis on klass
<?php
class tree_class {
private $nodes;
function __construct() {
$this->nodes = array ();
function add($row_ID, $subRow_ID = 0, $row_name = "", $row_position = 0) {
if (array_key_exists($row_ID, $this->nodes))
return 0;
$this->nodes[$row_ID] = array (
"subRow_ID" => $subRow_ID,
"row_name" => $row_name,
"row_position" => $row_position
return 1;
function iterate() {
foreach ($this->nodes as $rowID => $rowData) {
if ($rowData['subRow_ID'] == 0) {
// We have found one of the 'Root nodes'
// Lets start printing all that node has
echo "<b>".$rowData['row_name']."</b> <br>";
unset($this->nodes[$rowID]);
$this->print_f(0, 1,$rowID);
function print_f($node_ID, $node_LEVEL, $rowID) {
foreach($this->nodes as $rowIDx => $rowData) {
if($rowData['subRow_ID'] == 0) continue;
if($node_ID == 0) $node_ID = $rowID;
if($rowData['subRow_ID'] == $node_ID) {
echo str_repeat("-",$node_LEVEL)." ".$rowData['row_name']." <br>";
unset($this->nodes[$rowIDx]);
return $this->print_f($rowIDx, ++$node_LEVEL, $rowID);
unset($this->nodes[$node_ID]);
//return $this->print_f(0, 1, $rowID);
$hi = new tree_class();
$hi->add(1, 0, "Links", 0);
$hi->add(2, 1, "My home", 0);
$hi->add(3, 2, "Pictures of home", 0);
$hi->add(4, 1, "Munad", 0);
$hi->iterate();
mida ma sooviksin oleks see,et tekiks niiöelda ilus LOOP mis skännib kõik läbi ja displayb kõik ilusasti järjest..
tulemus peaks olema selline:
Links
- My home
-- Pictures of my home
- Munad
ning ühesõnaga lõpmatu menüü.. saaks moodustada selliseid asju:
Links
- My home
-Pictures of my home
-Something cool
-ultracool things
- Munad
Hacking
-Cracking
-Tutorials
- Hook
linnumees
m6mm
15.06.2008 16:43:44
mark11, võiksid endale termini "rekursioon" selgeks teha.
function iterate($s = 1, $subRowID = 0)
for($i = 1; $i < sizeof($this->nodes) + 1; $i++)
if($this->nodes[$i]['subRow_ID'] == $subRowID)
$output .= str_repeat('-', $s) .' ' . $this->nodes[$i]['row_name'] . '<br>';
$output .= $this->iterate($s + 1, $i); // look for children only for this node
}//if
}//for i
return $output;
}//iterate
ning
echo $hi->iterate();
annab tulemuseks
- Links
-- My home
--- Pictures of home
-- Munad
lahenduse eest papp kanna siis pangaarvele
| Kommentaarid: 35 loe/lisa |
34 |
